Proximity Sensors Capacitive
Thermoplastic Polyester Housing
Types CA30CAN/CAF.....
• 4TH Generation TRIPLESHIELDTM
• Adjustable sensing distance: 2 - 20 mm flush or 4-30
mm non-flush
• Protection: short-circuit, transients and reverse polarity
• Dust and humidity compensation
• Dust or temperature alarm output
• Rated operational voltage: 10-40 VDC
• Output: DC 200 mA, NPN or PNP
• Standard Output: NO and NC
• LED indications for power-supply, output and stability
• IP67, IP68, IP69K, Nema 1, 2, 4, 4X, 5, 6, 6P, 12
• Cable and M12 connector versions available
Product Description
The CA30CA.. capacitive
proximity switches feature an
improved 4TH generation TRIPLESHIELDTM
technology.
Furthermore, these sensors
feature increased immunity
to electromagnetic interference (EMI), especially to frequency drives. Not only does
4TH generation TRIPLESHIELDTM feature an increased
EMI, but it also increases
the immunity to humidity and
dust. The implementation of
stability indication eases the
setup procedure, as both
Stable ON and Stable OFF
positions are indicated by
Ordering Key
the green and yellow LEDs.
The sensing distance is
increased by 20 – 25 %
allowing room for additional
stable detection.
The dust alarm function
gives an early warning that
the sensing surroundings
have to be cleaned.
The temperature alarm function raises an alarm if the
sensing surface goes beyond
60 degree Celsius.
The sensor housing is featuring IP69K as well as approval
by ECOLAB for cleaning and
disinfection agents.
CA30CAN25NAM1
Capacitive proximity switch
Housing diameter (mm)
Housing material
Housing length
Detection principle
Rated operating dist. (mm)
Output type
Output configuration
Connection type
Type Selection
Housing
diameter
M 30
M 30
M 30
M 30
M 30
M 30
M 30
M 30
M 30
M 30
M 30
M 30
M 30
Sensor
type
Output Output Connection Rated operating
type function
distance (Sn)
Flush
Flush
Flush
Flush
Flush
Flush
Flush
Non-Flush
Non-Flush
Non-Flush
Non-Flush
Non-Flush
Non-Flush
NPN
NPN
PNP
PNP
PNP
PNP
PNP
NPN
NPN
PNP
PNP
PNP
PNP
Specifications
NO+NC
NO+NC
NO+NC
NO+NC
NO
NC
NC
NO+NC
NO+NC
NO+NC
NO+NC
NO
NC
Cable
M12 Plug
Cable
M12 Plug
Cable
Cable
M12 Plug
Cable
M12 Plug
Cable
M12 Plug
Cable
Cable
Ordering no.
Standard
0 - 16 mm CA30CAF16NA
0 - 16 mm CA30CAF16NAM1
0 - 16 mm CA30CAF16PA
0 - 16 mm CA30CAF16PAM1
0 - 16 mm
0 - 16 mm
0 - 16 mm
0 - 25 mm CA30CAN25NA
0 - 25 mm CA30CAN25NAM1
0 - 25 mm CA30CAN25PA
0 - 25 mm CA30CAN25PAM1
0 - 25 mm
0 - 25 mm
Ordering no.
Dust alarm
Ordering no.
Temperature alarm
CA30CAF16PODU CA30CAF16POTA
CA30CAF16PCDU CA30CAF16PCTA
CA30CAF16PCM1DU
CA30CAN25PODU CA30CAN25POTA
CA30CAN25PCDU CA30CAN25PCTA
EN 60947-5-2
Rated operating distance (Sn)
Non-flush mounted sensor
Flush mounted sensor
0 - 25 mm (factory setting
25 mm),
(ref. target 75x75 mm ST37,
1 mm thick, grounded)
0 - 16 mm (factory setting
16 mm - non-flush mounted)
(ref. target 48x48 mm ST37,
Specifications are subject to change without notice (22.11.2017)
Sensitivity control
Electrical adjustment
Mechanical adjustment
Adjustable distance
Flush types
Non-flush types
Effective operating dist. (Sr)
Usable operating dist. (Su)
Adjustable by potentiometer
11 turns
16 turns
2 to 20 mm
4 to 30 mm
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
0.85 x Sr ≤ Su ≤ 1.15 x Sr
1
CA30CAN/CAF.....
Specifications (cont.)
EN 60947-5-2
Repeat accuracy (R)
≤ 5%
Hysteresis (H)
3 - 20%
Rated operational volt. (UB) 10 to 40 VDC (ripple incl.)
Ripple
≤ 10%
Output function
NPN or PNP
Output switching function
N.O. and N.C.
Rated operational current (Ie) ≤ 200 mA (continuous)
Capacitive load
100 nF
No-load supply current (Io)
≤ 12 mA
Voltage drop (Ud)
≤ 2.0 VDC @ 200 mA DC
Minimum operational
current (Im)
≥ 0.5 mA
OFF state current (Ir)
≤ 100 μA
Protection
Short-circuit, reverse
polarity, transients
Frequency of operating
cycles (f)
50 Hz
Response time OFF-ON (ton)
≤ 10 ms
Response time ON-OFF (toff) ≤ 10 ms
Power ON delay (tv)
≤ 200 ms
Indication
Target detected
LED, yellow
Power and detection stability LED, green
Environment
Installation category
III (IEC 60664, 60664A;
60947-1)
Degree of pollution
3 (IEC 60664, 60664A;
60947-1)
Degree of protection
IP 67, IP 68/60 min., IP69K*
(IEC 60529; 60943-1)
NEMA type
Operating temperature
-30 to +85°C ( -22 to +185°F)
Max. temperature on sensing face 120°C (248°F)
Storage temperature
-40 to +85°C (-40 to +185°F)
Rated insulation voltage
1 kVAC (rms)
IEC protection class III
Tightening torque
≤ 7.5 Nm
Connection
Cable
PVC,
Ø5.2 x 2 m, 4 x 0.34 mm2
Oil proof, grey
Plug (M1)
M12 x 1 - 4 pin
Temperature alarm output
60ºC ± 5ºC
Response time examples
TA = 25°C
16 sec @ TEXC = 800°C
390 sec @ TEXC = 80°C
TRIPLESHIELDTM
Exceeding the norms for
capacitive sensors
Electrostatic discharge
(EN61000-4-2)
Contact discharge
> 40 kV
Air discharge
> 40 kV
Electrical fast transients/burst
(EN 61000-4-4)
±4kV
Surge
(EN 61000-4-5)
Power-supply
> 2kV (with 500 Ω)
Sensor output
> 2kV (with 500 Ω)
Wire conducted disturbances
(EN 61000-4-6)
> 20 Vrms
Power-frequency magnetic
fields (EN 61000-4-8)
Continuous
> 60 A/m, 75.9 µ tesla
Short-time
> 600 A/m, 759 µ tesla
Radiated RF electromagnetic
fields (EN 61000-4-3)
> 20 V/m
Shock (IEC 60068-2-32)
30 G / 11ms, 3 pos, 3 neg
per axis
Rough handling shocks
(IEC 60068-2-31)
twice from 1 m
100 times from 0.5 m
Vibration (IEC 60068-2-6)
10 to 150 Hz, 1 mm / 15 G
Housing material
Body
PBT, grey,
30% glass reinforced
Cable gland
PA12, black
Fingernuts
PA12, black
Trimmershaft
Nylon
Weight
Cable version
190 g
Plug version
106 g
Approvals
cULus (UL508), ECOLAB
CE-marking
Yes
MTTFd
829 years @ 40°C (+104°F)
* The IP69K test according to DIN 40050-9 for high-pressure, high-temperature wash-down applications.
The sensor must not only be dust tight (IP6X), but also able to withstand high-pressure and steam cleaning.
The sensor is exposed to high-pressure water from a spray nozzle that is fed with 80°C water at 8’000–
10’000 KPa (80–100bar) and a flow rate of 14–6L/min. The nozzle is held 100 –150 mm from the sensor at
angles of 0°, 30°, 60° and 90° for 30s each. The test device sits on a turntable that rotates with a speed of 5
times per minute. The sensor must not suffer any damaging effects from the high pressure water in appearance and function.
90°
60°
30°
0°
2
CA30CAN/CAF.....
Adjustment Guide
The environments in which
capacitive
sensors
are
installed can often be unstable as regards temperature,
humidity, object distance
and industrial (noise) interference. This is why Carlo
Gavazzi offers, as a stand-
ard feature in all TRIPLESHIELD™ capacitive sensors,
a user-friendly sensitivity
adjustment instead of a fixed
sensing range. Likewise,
these sensors provide an
extended sensing range to
accommodate mechanically
demanding areas and temperature stability to ensure
high immunity to electromagnetic interference (EMI) and a
minimum need for adjusting
sensitivity if the temperature
varies.
Note:
The sensors are factory set
(default) to nominal sensing
range Sn.
Wiring Diagram
NPN
PNP Dust- or Temperature alarm on NC
BN
BN
BK
WH
10 - 40 VDC
200 mA
BK
10 - 40 VDC
200 mA
WH (DU/TA)
BU
BU
PNP
PNP Dust- or Temperature alarm on NO
BN
BN
BK
BK
10 - 40 VDC
200 mA
WH
10 - 40 VDC
200 mA
WH (DU/TA)
BU
BU
Detection Diagram
X
-0,39
Non-flush
Distance (inch)
-0,20
0,39
0,59
Distance (inch)
0,79
0,98
1,18
15
0,59
15
0,59
10
0,39
10
0,39
0,20
5
5
0,00
-0,20
-0,39
-0,20
0,39
0,59
0,79
0,98
1,18
Sensor front
0,79
(mm)
(inch)
0,98
-0,59
25
Sensor front
(mm)
-0,59
25
Flush
Y
Target
0,98
0,20
0,00
-0,20
-0,39
-10
-15
-0,59
-15
-0,59
-20
-0,79
-20
-0,79
-25
-15
-0,98
-25
-15
-10
-10
-5
10
15
30
Distance (mm)
-10
-5
(inch)
Sensor
-0,39
10
15
30
-0,98
Distance (mm)
3
CA30CAN/CAF.....
Detection Stability Indication
Target influence
Stable ON
Output ON
Output OFF
Stable OFF
Time
Green LED ON
Yellow LED ON
Output NO
Output NC
Dust alarm NO
>1 sec.
>1 sec.
>1 sec.
>2 sec.
Dust alarm NC
>1 sec.
>1 sec.
>1 sec.
>2 sec.
Dimensions
CA30CAF....
CA30CAF....M1
81
74
61
61
LED
LED
M12 x 1.0
M30 x 1.5 x 59.5
M30 x 1.5 x 59.5
CA30CAN....
CA30CAN....M1
81
74
61
61
LED
LED
14,5
M12 x 1.0
14,5
M30 x 1.5 x 45.5
M30 x 1.5 x 45.5
Cable
Plug
Back of sensor
Colour code
2
Sensitivity
adjustment
Green LED
Yellow LED
OUTPUT
1
3
DIST.
STABLE
1 Brown
2 White
3 Blue
4 Black
4
4
CA30CAN/CAF.....
Installation Hints
Capacitive sensors have a
unique ability to detect al
most any material in liquid or
solid form. Capa
ci
tive sensors are able to detect me
tallic as well as non-metallic
objects. However, their traditional use is for non-metallic
materials such as:
• Plastics Industry
Resins, regrinds or mould
ed products.
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
• Chemical Industry
Cleansers, fertilizers, liquid soaps, corrosives and
petrochemicals.
• Wood Industry
Saw dust, paper products,
door and window frames.
• Ceramics & Glass
Industry
Raw materials, clay or
finished products, bottles.
Relief of cable strain
• Packaging Industry
Package inspection for level or contents, dry goods,
fruits and vegetables, dairy
products.
Materials are detected due to
their dielectric constant. The
bigger the size of an object,
the higher the density of ma
terial, the better or easier it is
to detect the object.
The nominal sensing distan
ce for a capacitive sensor
is referred to a grounded
metal plate (ST37). For addi
tional information regarding
dielectric ratings of materials please refer to Technical
Information.
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Not correct
Correct
The cable should not be pulled
Delivery Contents
Accessories
• Capacitive switch: CA30CAN/CAF.......
• User manual
• 2 x M30 fingernuts
• Screwdriver
• Packaging: Cardboard box
• Connector type CONB14NF-... -series.
• Mounting Brackets AMB30-S.. (straight),
AMB30-A.. (angled)
5
