CA18CLC12BP
CA18CLC12BP
    CARLOGAVAZZI
    Cylinder,Threaded-M18
    SENSOR PROX CAP 12MM IP68 CYLIND
CA18CLC12BP 数据手册
Proximity Sensors Capacitive Thermoplastic Polyester Housing Types CA, M18, M30, DC, Teach-in LD™ E I H LES P I TR • Featuring TRIPLESHIELD™ Sensor Protection • Sensing distance: 0.5 - 12 mm (M18) and 1.0 - 30 mm (M30) • Teach-in of sensing distance via push-button or COM-input • Automatic detection of NPN or PNP load • Selectable make or break switching by means of Teach-in function • Protection: Short-circuit, transients and reverse polarity • Humidity compensation • Alarm output • 5 years of warranty Product Description Ordering Key CA18CLC12BPM1 switching points can be altered by means of the Teach-in function. 3-wire DC output with selectable make (NO) or break (NC) switching and NPN Alarm. Grey polyester housing with 2 m PVC cable or M12 plug. Capacitive proximity switch Housing diameter (mm) Housing material Housing length Detection principle Rated operating dist. (mm) Output type Output configuration Connection type Housing diameter Rated operating distance (Sn) Ordering no. Cable Ordering no. Plug M18 M 30 12 mm 30 mm CA18CLC12BP CA30CLC30BP CA18CLC12BPM1 CA30CLC30BPM1 Capacitive proximity switches with a sensing distance of either 8 mm flush mounted in metal or 12 mm nonflush mounted for the M18 version, and either 16 mm flush mounted in metal or 30 mm non-flush mounted for the M30 version. The Type Selection Specifications Sensing range (Sd) CA18CLC12 0.5 - 12 mm factory set at 8 mm CA30CLC30 1.0 - 30 mm factory set at 15 mm Sensitivity Adjustable (Teach-in) Effective operating dist. (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operating dist. (Su) 0.8 x Sr ≤ Su ≤ 1.2 x Sr Repeat accuracy (R) ≤ 5% Hysteresis (H) Depending on Teach-in Rated operational volt. (UB) 10 to 40 VDC (ripple incl.) Ripple ≤ 10% Rated operational current (Ie) ≤ 250 mA (continuous) No-load supply current (Io) ≤ 12 mA Voltage drop (Ud) ≤ 2.5 VDC @ max. load Protection Short-circuit, reverse polarity, transients TRIPLESHIELDTM protection-EMC IEC 1000-4-2/EN 61000-4-2 30 kV IEC 1000-4-3/EN 61000-4-3 > 15 V/m IEC 1000-4-4/EN 61000-4-4 3 kV IEC 1000-4-6/EN 61000-4-6 > 10 Vrms Specifications are subject to change without notice (25.01.2010) Frequency of operating cycles (f) Indication For output ON For safe/unsafe Environment Degree of protection Operating temperature Storage temperature Housing material Body Cable end Nuts Connection Cable Plug (M1) Cable for plug (M1) Weight Cable version - M18 / M30 Plug version - M18 / M 30 Approvals CE-marking 15 Hz LED, yellow LED, green IP 68 -20° to +85°C ( -4° to +185°F) -40° to +85°C (-40° to +176°F) Grey, thermoplastic polyester Polyester, softened Black, PA12 Grilamid Grey, 2 m, 4 x 0.25 mm2 Oil proof, PVC M12 x 1 CON.1A-series 110 g/160 g 30 g/70 g UL, CSA Yes 1 CA, M18, M30, DC, Teach-in Dimensions CA30 CA18 50 89.55 M18 x 1 50 23 M18 x 1 LED Cable 89.2 23 50 LED M12 Plug 99.2 23 M30 x 1.5 50 90.45 23 M30 x 1.5 LED Cable LED M12 x 1 Plug Adjustment Guide The environments in which capacitive sensors are installed can often be unstable regarding temperature, humidity, object distance and industrial (noise) interference. Because of this, Carlo Gavazzi offers as standard features in all TRIPLESHIELD™ capacitive sensors a user-friendly sensitivity adjustment instead of having a fixed sensing range, extended sensing range to accommodate mechanically demanding areas, temperature stability to ensure minimum need for adjusting sensitivity if temperature varies and high immunity to electromagnetic interference (EMI). Note: Sensors are factory set (default) to nominal sensing range Sn. • Chemical Industry Cleansers, fertilisers, liquid soaps, corrosives and petrochemicals. • Packaging Industry Package inspection for level or contents, dry goods, fruits and vegetables, dairy products. tive sensor is referenced to a grounded metal plate (ST37). For additional information regarding dielectric ratings of materials please refer to Technical Information. Installation Hints Capacitive sensors have the unique ability to detect almost all materials, either in liquid or solid form. Capacitive sensors can detect metallic as well as non-metallic objects, however, their traditional use is for non-metallic materials such as: • Plastics Industry Resins, regrinds or moulded products. To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables • Wood Industry Saw dust, paper products, door and window frames. • Ceramic & Glass Industry Raw material, clay or finished products, bottles. Relief of cable strain Materials are detected due to their dielectric constant. The bigger the size of an object, the higher the density of material, the better or easier it is to detect the object. Nominal sensing distance for a capaci- Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Not correct Correct The cable should not be pulled Delivery Contents Accessories • Capacitive switch: CA..CLC..BP.. • Packaging: Cardboard box • Installation & Adjustment Guide (MAN CAP ENG/GER) • Plugs CON.1A.. series. 2 For further information please refer to “Accessories. Specifications are subject to change without notice (25.01.2010) CA, M18, M30, DC, Teach-in Teach-in Guide Adjustment - Background No target present Press push-button >3 seconds until LED´s are flashing one time per second. The background will be calibrated when the push-button is released during the following 3 seconds Push-button LED - Green LED - Yellow Time (sec) 0 1 2 3 4 5 6 7 8 9 10 11 12 13 Adjustment - Object Target present Press push-button >6 seconds until LED´s are flashing two times per second. The object will be calibrated when the pushbutton is released during the following 3 seconds Push-button LED - Green LED - Yellow Time (sec) 0 1 2 3 4 5 6 7 8 9 10 11 12 13 Adjustment - NO - NC Press push-button >9 sec. until LED´s are flashing three times per second. The status of NO-NC will toggle when the pushbutton is released during the following 3 seconds Push-button LED - Green LED - Yellow Time (sec) 0 1 2 3 4 5 6 7 8 9 10 11 12 13 Releasing the push-button after 12 sec. returns the sensor to factory settings. Wiring Diagrams BN+ (1) The PNP- or NPN-load will automatically be detected. IALARM < 20mA By means of the Teach-in wire, the functions described in the Teach-in Guide can be setup. BK (4) ILOAD < 250mA WH (2) Teach-in BU- (3) It is possible to Teach-in more sensors at the same time by connecting the WH-wires in parallel to the common ”-” supply. (#): Plug connections Important: If alarm output (WH-wire) is unused, it has to be terminated to +supply Specifications are subject to change without notice (25.01.2010) 3
CA18CLC12BP
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
CA18CLC12BP 价格&库存
很抱歉,暂时无法提供与“CA18CLC12BP”相匹配的价格&库存,您可以联系我们找货
