Proximity Sensors Inductive
Thermoplastic Polyester Housing
Type IC 40, 40 x 40 x 118 mm
• Rotable-head, 5 positions
• Mounting dimensions in accordance with
DIN 43694
• Thermoplastic polyester housing
• Sensing distance: 30 mm
• LED-indication for power and output ON
• Fully protected
• DC types 4-wire NO & NC, 10-30 VDC
• AC/DC types 2-wire NO or NC, 20-250 VAC/DC
• AC type 2-wire NO & NC
Product Description
Ordering Key
Inductive proximity switch in
standard limit switch housing. Rugged polyester housing. Sensing face adjustable
Ind. prox. switch
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
Connection
in up to 5 positions. 2-wire
AC/DC for maximum efficiency.
IC40CNN30NAT1
Type Selection - DC
Rated
operating
dist. (Sn)
Ordering no.
Transistor NPN
Normally open & normally closed
Ordering no.
Transistor PNP
30 mm 1)
IC40CNN30NAT1
IC40CNN30PAT1
1)
For non-flush mounting
Type Selection - AC and AC/DC
Rated
operating
dist. (Sn)
Ordering no.
Power MOSFET
Normally open, AC/DC
Ordering no.
Power MOSFET
Normally closed, AC/DC
Ordering no.
Power MOSFET
Normally open & closed, AC
30 mm 1)
IC40CNN30COT1
IC40CNN30CCT1
IC40CNN30TAT12)
1)
2)
Delivered: NO
Specifications are subject to change without notice (27.08.13)
1
IC40CNN30....
Specifications
Transistor NPN/PNP
Power MOSFET output AC types
Rated operational voltage (UB)
Ripple
Rated operational current (Ie)
Continuous
10 to 30 VDC (rippled included)
≤ 15%
20 to 250 VAC/VDC (VAC: 45 to 65 Hz)
≤ 200 mA
Short-time
No-load supply current (Io)
Minimum load current
OFF-state current (Ir) (leakage)
Voltage drop (Ud)
Protection
Power ON delay
Frequency of operating cycles (f)
Indication for supply ON (LED 2)
Indication for output ON (LED 1)
Rated operating dist. (Sn)
Repeat accuracy (R)
Hysteresis (H) (Differential travel)
Effective operating dist. (Sr)
Usable operating dist. (Su)
Ambient temperature
Operating
Storage
Degree of protection
Shock resistance
Vibration resistance
Housing material
Terminal block
≤ 25 mA
50 µA
< 1.5 VDC
Reverse polarity, short-circuit
≤ 100 ms
≤ 100 Hz
LED, green
LED, red
30 mm
≤ 1%
3 to 20% of sensing distance
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
0.9 x Sr ≤ Su ≤ 1.1 x Sr
5 - 200 mA @ 25°C
5 - 160 mA @ 70°C
≤ 2 A, t ≤ 20 ms (Max. 1 pulse per s)
5 mA
≤ 2.5 mA
≤ 10.0 VAC; ≤ 8.0 VDC
Short-circuit (except for IC40CNN30TAT1)
≥ 100 ms
≤ 25 Hz AC; 40 Hz DC
LED, green
LED, red
30 mm
≤ 1%
-25° to +70°C (-13° to +158°F)
-30° to +80°C (-22° to +176°F)
IP 67(Nema 1, 3, 4, 6, 13)
30 G/ 11 ms
10 to 50 Hz/1 mm/5 min.
PBT
4 terminals for 2 x 2.5 mm2 wires,
self-lifting
M20 x 1.5
200 g
Yes
IP 67 (Nema 1, 3, 4, 6, 13)
30 G/ 11 ms
PBT
2 terminals for 2 x 2.5 mm2 wires,
self-lifting
M20 x 1.5
200 g
Yes
Cable gland
Weight
CE-marking
Wiring Diagrams
1
4
4
2
2
3
IC40CNN30NAT1
2
1
3
IC40CNN30PAT1
IC40CNN30....
Wiring Diagrams (cont.)
Dimensions
3
4
Top view
Internal
programmable
Side
view
IC40CNN30TAT1
IC40CNN30COT1
IC40CNN30CCT1
Installation Hints
Installation examples
Sensing surface on head
("top"); other orientations of
the sensing surface mean
deviations from nominal
sensing distance.
Figure 1
a (mm) ≥ 40
Sn (mm) ≤ 20
Figure 2
a (mm) ≥ 40
Sn (mm) ≤ 25
Figure 3
Flush mounting not
permitted
a
a
a
Adjacent mounting
To avoid cross-interference
when mounting the sensors
next to each other, the given
separations (a) should be
maintained.
Figure 4
a (mm) ≥ 120
a
a
3
很抱歉,暂时无法提供与“IC40CNN30PAT1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2388.112281+309.34407
