NMB5-18GM65-E2-FE-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    INDUCTIVE SEN 5MM PNP SS
NMB5-18GM65-E2-FE-V1 数据手册
Inductive sensor NMB5-18GM65-E2-FE-V1 < < < < Stainless steel sensing face Sensing range 5 mm 3-wire DC Ferrous targets 65 42 50 55 4 M18x1 2.5 Dimensions LEDs 6 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 908440_eng.pdf 24 M12x1 Technical Data General specifications Switching function Normally open (NO) Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NMB5-18GM65-E2-FE-V1 Technical Data Output type PNP Rated operating distance sn 5 mm Installation flush Output polarity DC Assured operating distance sa 0 ... 4.05 mm Actuating element Ferrous targets Reduction factor rAl 0 Reduction factor rCu 0 Reduction factor r304 0.8 Reduction factor rSt37 1 Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 15 Hz Hysteresis H 3 ... 15 typ. 5 % Reverse polarity protection yes Short-circuit protection yes Voltage drop Ud ≤2V Operating current IL ≤ 200 mA Current consumption Off-state current < 14 mA Ir ≤ 10 µA Functional safety related parameters MTTFd 990 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means Operation indicator 4-way dual LED Green: power Yellow: output Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 908440_eng.pdf Ambient temperature -40 ... 70 °C (-40 ... 158 °F) Mechanical specifications Connection type Connector M12 x 1 , 4-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face Stainless steel 1.4305 / AISI 303 Degree of protection IP67 / IP68 / IP69K - cordset dependent according to cable specification Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NMB5-18GM65-E2-FE-V1 Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Accessories Female cordset, M12, 4-pin, PUR cable V1-G-2M-PUR Female cordset, M12, 4-pin, PUR cable AB-18 Mounting aid Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 908440_eng.pdf V1-W-2M-PUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NMB5-18GM65-E2-FE-V1 价格&库存
很抱歉,暂时无法提供与“NMB5-18GM65-E2-FE-V1”相匹配的价格&库存,您可以联系我们找货
