IA08BSF15NOM5
IA08BSF15NOM5
    CARLOGAVAZZI
    Cylinder,Threaded-M8
    SENSOR PROX INDUCTIVE 1.5MM CYL
IA08BSF15NOM5 数据手册
Proximity Sensors Inductive Short body, Stainless Steel Housing Types IA, M8 • Miniature stainless steel housing M8 • Short body • Sensing distance: 1.5 mm or 2.5 mm • Power supply: 10 to 30 VDC • Output: Transistor NPN/PNP, normally open or normally closed • Protection: Short-circuit • LED-indication for output ON • 2 m PVC cable or M8 plug Product Description Ordering Key Miniature inductive proximity sensor with reduced body length. Output configuration for NPN/PNP with both NO Ind. prox. switch Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection and NC types as standard. M8 stainless steel housing. Connection with 2 m PVC cable or M8 plug. IA 08 BSF 15 NO M5 Type Selection Rated Conn. operating type dist. (Sn) Ordering no. Transistor NPN Normally open Ordering no. Transistor NPN Normally closed Ordering no. Transistor PNP Normally open Ordering no. Transistor PNP Normally closed 1.5 mm 1) 1.5 mm 1) Cable Plug IA 08 BSF 15 NO IA 08 BSF 15 NO M5 IA 08 BSF 15 NC IA 08 BSF 15 NC M5 IA 08 BSF 15 PO IA 08 BSF 15 PO M5 IA 08 BSF 15 PC IA 08 BSF 15 PC M5 2.5 mm 2.5 mm Cable Plug IA 08 BSN 25 NO IA 08 BSN 25 NO M5 IA 08 BSN 25 NC IA 08 BSN 25 NC M5 IA 08 BSN 25 PO IA 08 BSN 25 PO M5 IA 08 BSN 25 PC IA 08 BSN 25 PC M5 1) For flush mounting in metal Specifications Rated operational volt. (UB) Ripple Rated operational current (Ie) Continuous No-load supply current (Io) Voltage drop (Ud) Protection Frequency of operating cycles (f) Indication for output ON Repeat Accuracy Effective operating dist. (Sr) Usable operating dist. (Su) 10 to 30 VDC (ripple included) ≤ 10% ≤ 200 mA @ + 25°C (+75°F) ≤ 10 mA (ON) < 2,5 V (@ Imax) Short circuit 2000 Hz LED, yellow ≤ 5% 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.85 x Sr ≤ Su ≤ 1.15 x Sr Specifications are subject to change without notice (26.08.10) Ambient temperature Operating Storage Degree of protection Housing material Approvals CE-marking Connection Cable Plug -25° to +70°C (-13° to +158°F) -30° to +75°C (-22° to +167°F) IP 67 (Nema 1, 3, 4, 6, 13) Stainless steel, AISI 303 UL, CSA Yes 2 m, PVC, AWG 26, oil proof M8, CONH5A-xxx Serie 1 IA, M8 Dimensions M8 x 1 M8 x 1 M8 x 1 M8 x 1 3 3 22 30 25 30 30 30 45 45 LED x 4 LED x 4 LED LED M8 x 1 M8 x 1 IA 08 BSF 15 .. IA 08 BSN 25 .. IA 08 BSF 15 .. M5 IA 08 BSN 25 .. M5 Wiring Diagrams 1 BN + + 1 BN 1 BN + 1 BN + 4 BK 2 WH 2 WH 4 BK 3 BU 3 BU - NPN - Normally open - NPN - Normally closed 3 BU 3 BU PNP - Normally open PNP - Normally closed Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 2 Specifications are subject to change without notice (26.08.10)
IA08BSF15NOM5 价格&库存
很抱歉,暂时无法提供与“IA08BSF15NOM5”相匹配的价格&库存,您可以联系我们找货
