EC3016PPASL-1
EC3016PPASL-1
    CARLOGAVAZZI
    Cylinder,Threaded-M30
    SENSOR PROX CAPACITIVE 16MM CYL
EC3016PPASL-1 数据手册
Proximity Sensors Capacitive LD™ E I Stainless Steel Housing SH PLE I R T Type EC, M30, DC • Featuring TRIPLESHIELD™ sensor protection • Rated operational voltage: 10-40 VDC • Adjustable sensing distance 2-16 mm or 4-25 mm • Output: DC 200 mA, NPN or PNP • Make and break switching function • LED indication • High noise immunity • Flush and non-flush types • Plug and cable versions available • AC versions in the same housing Product Description Ordering Key Capacitive proximity switc­ h­ es with either sensing di­ stance 16 mm flush mounted or sens­ ing distance 25 mm non-flush mounted. 4-wire DC output with both ma­ ke (NO) Capacitive prox­im­ity switch Housing diameter (mm) Rated operating dist. (mm) Output type Housing material Housing type Connection type and break (NC) switch­ing. M30 stainless steel housing with 2 m PVC cable or plug. Ideal for use in level and plas­tic ma­ chin­ery applications. EC 3025 PPA S L-1 Type Selection Housing Rated Mounting diameter operating dist. (Sn) 1) M30 M30 1) 16 mm 25 mm Ordering no. Ordering no. Ordering no. Ordering no. Transistor NPN/cable Transistor NPN/plug Transistor PNP/cable Transistor PNP/plug Make & break Make & break Make & break Make & break switching switching switching switching Flush (built-in) EC 3016 NPASL Non-flush EC 3025 NPASL EC 3016 NPASL-1 EC 3025 NPASL-1 EC 3016 PPASL EC 3025 PPASL EC 3016 PPASL-1 EC 3025 PPASL-1 Object: Grounded steel plate Specifications Rated operating dist. (Sn) 3016: 2 to 16 mm factory set at 16 mm 3025: 4 to 25 mm factory set at 25 mm Sensitivity Adj. multiturn pot.meter Effective operating dist. (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x S Usable operating dist. (Su) 0.8 x Sr ≤ Sn > 1.2 x Sr Repeat accuracy (R) ≤ 5% Hysteresis (H) 3 to 20% of sensing distance Rated operational volt. (UB) 10 to 40 VDC (ripple included) Ripple ≤ 10% Rated operational current (Ie) Continuous ≤ 200 mA No-load supply current (Io) ≤ 10 mA (no load) Voltage drop (Ud) ≤ 2.5 VDC at max. load Protection Reverse polarity, short-circuit, transients Specifications are subject to change without notice (30.05.2017) Frequency of operating cycles (f) 50 Hz Indication for output ON LED, yellow Environment Degree of protection IP 67 (Nema 1, 3, 4, 6, 13) Temperature Operating temperature -25° to +80°C (-13° to +176°F) Storage temperature -40° to +85°C (-40° to +185°F) Housing material Body Stainless steel (St 304) Front Grey, polyester Cable end Polyester Nuts Nickel plated brass Connection Cable Grey, 2 m, 4 x 0.34 mm2 Oil proof, PVC Plug (-1) M12 x 1 Cable for plug (-1) CON.1A-series Weight (incl. nuts) 3016: 140 g 3025: 150 g Approvals UL CE-marking Yes 1 EC, M30, DC Dimensions D C E E B M12x1 F Cable D B C SW A LED Type A SW Plug LED A B C D E F SW Ø mm mm mm mm mm mm EC 3016xPASL(-1) M30 x 1.5 x 50 EC 3025xPASL(-1) M30 x 1.5 x 50 28 28 50 13.6 15.4 62 13.6 15.4 5 5 36 36 Wiring Diagrams 1 BN 1 BN 4 BK 2 WH 2 WH 4 BK 3 BU NPN PNP 3 BU Adjustment Guide The environments in which capacitive sensors are install­ ed can often be un­stable re­ garding temperature, humi­dity­, object distance and industrial (noise) interference. Because of this, Carlo Ga­ vazzi offers as standard features in all TRIP­LESHIELD™ capacitive sensors a user-friendly sen­ sitivity adjustment instead of having a fixed sensing range, extend­ ed sen­ sing range to accommodate mechanically demand­ing are­as, temperature stability to en­sure minimum need for adjusting sensitivity if temperature varies and high immunity to elec­tro­magnetic interference (EMI). Note: Sensors are factory set (de­ fault) to maximum rated sens­ ing range. EC3016xPASL(-1) EC3025xPASL(-1) Sensitivity Adjustment (4-wire device backview) Max. Tripleshield Dist. Sensitivity Min. Installation Hints Capacitive sensors have the unique ability to detect al­ most all materials, either in li­ quid or solid form. Capa­ci­tive sensors can detect metallic as well as non-metallic ob­ jects, how­ever, their tradition­ al use is for non-metallic ma­ terials such as: • Plastic Industry Resins, regrinds or mould­ ed products. 2 • Chemical Industry Cleansers, fertilisers, liquid soaps, corrosives and pet­ rochemicals. • Wood Industry Saw dust, paper products, door and window frames. • Ceramic & Glass ­Industry Raw material, clay or finish­ ed products, bottles. • Packaging Industry Package inspection for level or contents, dry goods, fruits and vegeta­ bles, dairy products. Materials are detected due to their dielectric constant. The bigger the size of an object, the higher the density of ma­ terial, the better or easier it is to detect the object. Nominal sensing di­stan­ce for a capac­ itive sensor is referenced to a grounded me­tal plate (ST37). For addi­ tional information regarding di­elec­­tric ratings of materials please re­ fer to Technical Information. Specifications are subject to change without notice (30.05.2017) EC, M30, DC Installation Hints (cont.) To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Delivery Contents Accessories • Capacitive switch: EC 30.. PASL(-1) • Screw driver • 2 nuts • Packaging: Cardboard box • Installation & Adjustment Guide • Plugs CON.1A.. serie Specifications are subject to change without notice (30.05.2017) 3
EC3016PPASL-1
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,包括输入侧的发光二极管和输出侧的光敏三极管。
4. 参数特性:包括最大正向电流、最大反向电压等电气参数。
5. 功能详解:EL817通过光电效应实现信号传输,具有隔离和保护作用。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm。
EC3016PPASL-1 价格&库存
很抱歉,暂时无法提供与“EC3016PPASL-1”相匹配的价格&库存,您可以联系我们找货
