SLG5NT1586V
SLG5NT1586V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFDFN8
    IC PWR SWITCH N-CHANNEL 1:1 8DFN
SLG5NT1586V 数据手册
SLG5NT1586V Ultra-small 22.5 mΩ 2.5 A Integrated Power Switch with Reverse Blocking General Description Pin Configuration The SLG5NT1586V is a 22.5 mΩ 2.5 A single-channel load switch that is able to switch 1 to 5 V power rails. The product is packaged in an ultra-small 1.0 x 1.6 mm package. 1 ON 2 D 3 D 4 • 1.0 x 1.6 x 0.55 mm STDFN 8L package (2 fused pins for drain and 2 fused pins for source) • Logic level ON pin capable of supporting 0.85 V CMOS Logic • 22.5 mΩ RDSONwhile supporting 2.5 A • Power Good Output • Pb-Free / Halogen-Free / RoHS compliant • Operating Temperature: -40 °C to 85°C • Operating Voltage: 1.5 V to 5.5 V SLG5NT1586V Features VDD 8 GND 7 PG 6 S 5 S 8-pin STDFN (Top View) Applications • Notebook Power Rail Switching • Tablet Power Rail Switching • Smartphone Power Rail Switching Block Diagram 2.5 A @ 22.5 mΩ Reverse Blocking D VDD +1.5 to 5.5 V S Charge Pump Linear Ramp Control ON Silego Technology, Inc. 000-005NT1586-100 PG D CMOS Input Rev 1.00 Revised March 1, 2016 SLG5NT1586V Pin Description Pin # Pin Name Type Pin Description 1 VDD PWR VDD power for load switch control (1.5 V to 5.5 V) 2 ON Input Turns MOSFET ON (4 MΩ pull down resistor) CMOS input with VIL < 0.3 V, VIH > 0.85 V 3 D MOSFET Drain of Power MOSFET (fused with pin 4) 4 D MOSFET Drain of Power MOSFET (fused with pin 3) 5 S MOSFET Source of Power MOSFET (fused with pin 6) 6 S MOSFET Source of Power MOSFET (fused with pin 5) 7 PG Output 8 GND GND Power Good Output. Active High. Pin drives HIGH when VOUT > 95% VIN Ground Ordering Information Part Number Type Production Flow SLG5NT1586V STDFN 8L Industrial, -40 °C to 85 °C SLG5NT1586VTR STDFN 8L (Tape and Reel) Industrial, -40 °C to 85 °C 000-005NT1586-100 Page 2 of 8 SLG5NT1586V Absolute Maximum Ratings Parameter VDD TS ESDHBM WDIS Description Conditions Power Supply Storage Temperature ESD Protection Human Body Model Min. Typ. Max. Unit -- -- 7 V -65 -- 150 °C 2000 -- -- V -- -- 0.4 W -- -- 3.5 A Package Power Dissipation MOSFET IDSPK Peak Current from Drain to Source For no more than 1 ms with 1% duty cycle Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -40 °C to 85 °C (unless otherwise stated) Parameter Description Conditions VDD Power Supply Voltage -40 °C to 85 °C IDD Power Supply Current (PIN 1) RDSON IDS ISDLKG VD Static Drain to Source ON Resistance Operating Current ISD Leakage (Reverse Blocking Enabled) when OFF Min. Typ. Max. Unit 1.5 -- 5.5 V -- -- 1 μA when ON, No load -- 14 30 μA TA 25°C @ 100 mA -- 22.5 25 mΩ TA 70°C @ 100 mA -- 25.6 30 mΩ TA 85°C @ 100 mA -- 25.6 30 mΩ VD = 1.0 V to 5.5 V -- -- 2.5 A VS = 1. 0 V to 5.5 V, VD = 0 V, VDD = 0 V, @ 25°C -- 0.29 0.50 μA VS = 1. 0 V to 5.5 V, VD = 0 V, VDD = 0 V, @ 85°C -- 0.85 1.30 μA VS = 1. 0 V to 5.5 V, VD = 0 V, VDD = 0 V, @ -40°C -- 3.35 5.00 μA 1.0 -- VDD V 0 300 500 μs Drain Voltage TON_Delay ON pin Delay Time 50% ON to Ramp Begin TTotal_ON Total Turn On Time Example: VDD = VD = 5 V, Source_Cap = 10 μF, RL = 20 Ω 2.1 2.6 3.1 ms Slew Rate Example: VDD = VD = 5 V, Source_Cap = 10 μF, RL = 20 Ω 1.4 1.95 2.2 V/ms -- -- 500 μF TSLEWRATE CAPSOURCE Source Cap Source to GND ON_VIH High Input Voltage on ON pin 0.85 -- VDD V ON_VIL Low Input Voltage on ON pin -0.3 0 0.3 V VOL High Output Voltage on PG pin VDD = 5 V, IOL = -0.1 mA -- -- 0.4 V VOH High Output Voltage on PG pin VDD = 5 V, IOH = 0.1 mA VDD-0.4 -- VDD V Thermal shutoff turn-on temperature -- 125 -- °C THERMOFF Thermal shutoff turn-off temperature -- 100 -- °C THERMON THERMTIME Thermal shutoff time TOFF_Delay OFF Delay Time PGTRIGGER Power Good Trigger Level -- -- 1 ms 50% ON to VS Fall, VDD = VD = 5 V -- 8 -- μs VOUT % of VIN -- 92 -- % Notes: 1. Refer to table for configuration details. 000-005NT1586-100 Page 3 of 8 SLG5NT1586V TTotal_ON, TON_Delay and Slew Rate Measurement ON 50% ON 50% ON TOFF_DELAY 90% VS VS 90% VS TON_DELAY 10% VS 10% VS Slew Rate (V/ms) TFALL TTotal_ON 000-005NT1586-100 Page 4 of 8 SLG5NT1586V Package Top Marking System Definition ABC Serial Number Pin 1 Identifier 000-005NT1586-100 Page 5 of 8 SLG5NT1586V Package Drawing and Dimensions 8 Lead STDFN Package 1.0 x 1.6 mm (Fused Lead) IC Net Weight: 0.0025 g 000-005NT1586-100 Page 6 of 8 SLG5NT1586V Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STDFN 8L 1x1.6mm 0.4P FC Green 8 1.0 x 1.6 x 0.55 3,000 3,000 178 / 60 100 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 100 400 8 Part Pitch [mm] 4 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Package Length Width Type STDFN 8L 1x1.6mm 0.4P FC Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.12 1.72 0.7 4 4 1.55 1.75 3.5 8 Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 0.88 mm3 (nominal). More information can be found at www.jedec.org. 000-005NT1586-100 Page 7 of 8 SLG5NT1586V Revision History Date Version 03/01/2016 1.00 000-005NT1586-100 Change Production Release Page 8 of 8
SLG5NT1586V 价格&库存
很抱歉,暂时无法提供与“SLG5NT1586V”相匹配的价格&库存,您可以联系我们找货
