IN40-D0304K
IN40-D0304K
    SICK
    Cylinder,Threaded-M18
    SENSOR PROX INDUCTIVE 1-4MM CYL
IN40-D0304K 数据手册
Product data sheet IN40-D0304K IN4000 Standard NON-CONTACT SAFETY SWITCHES IN40-D0304K | IN4000 Standard NON-CONTACT SAFETY SWITCHES A B C D E F Ordering information Type Part no. IN40-D0304K 6037684 The devices conform to Category 3 as well as PFH D 1.0 × 10–8. Please check whether the device meets the safety requirements of your application as a result. If you have any questions, please consult your sales organization. Other models and accessories www.sick.com/IN4000_Standard Detailed technical data Features H I J K L M N O P Q R S T Sensor principle Inductive Number of safe outputs 1 Switching delay from state change T2 + 20 ms 1) Housing diameter M18 Enable zone 1 mm ... 4 mm 2) Safe switch off distance Sar 10 mm 2) Actuation directions 5 Active sensor surfaces 1 Monitoring time minimum dwell time ≥ 0.2 s 1) 2)  During this time the output is switched off (Logical “0”), see response range.  Dependent on material. The indicated values refer to steel ST37. Safety-related parameters Safety integrity level SIL3 (IEC 61508) SILCL3 (EN 62061) Category Category 3 (EN ISO 13849) Performance level PL e (EN ISO 13849) PFHD (mean probability of a dangerous failure per hour) 1.0 x 10-8 (EN ISO 13849) TM (mission time) 10 years (EN ISO 13849) 1) 20 years (EN ISO 13849) 2) Type Type 3 (EN ISO 14119) Actuator coding level Uncoded (EN ISO 14119) Classification in compliance with IEC/ EN 60947-5-3 PDF-M 1) 2) 2  At –25 °C ... +70 °C and 5 % ... 95 % relative air humidity.  At +10 °C ... +40 °C and 5 % ... 70 % relative air humidity. SAFETY SWITCHES | SICK Product data sheet | 2021-08-04 15:20:56 Subject to change without notice IN40-D0304K | IN4000 Standard NON-CONTACT SAFETY SWITCHES Functions Safe series connection With T-connector (without diagnostics) Interfaces Connection type Plug connector, M12, 4-pin Power indication ✔ Status display ✔ Electrical data Protection class III (EN 50178) Supply voltage Vs 24 V DC (19.2 V DC ... 30 V DC) Power consumption 15 mA Type of output Semiconductor, pulsed Mechanical data Design Cylindrical Housing diameter M18 Housing length 90.5 mm Thread length 65 mm Weight 0.06 kg Material Housing Specially coated brass (housing), PBT (cover) Installation type Flush Ambient data Enclosure rating IP69K (IEC 60529) Ambient operating temperature –25 °C ... +70 °C Storage temperature –25 °C ... +70 °C Vibration resistance 10 Hz ... 55 Hz, 1 mm (EN 60947-5-3) Shock resistance 30 g, 11 ms (EN 60947-5-3) Classifications ECl@ss 5.0 27272401 ECl@ss 5.1.4 27272401 ECl@ss 6.0 27272401 ECl@ss 6.2 27272401 ECl@ss 7.0 27272401 ECl@ss 8.0 27272401 ECl@ss 8.1 27272401 ECl@ss 9.0 27272401 ECl@ss 10.0 27272401 ECl@ss 11.0 27272401 ETIM 5.0 EC001818 ETIM 6.0 EC001818 2021-08-04 15:20:56 | Product data sheet  Subject to change without notice SAFETY SWITCHES | SICK 3 IN40-D0304K | IN4000 Standard NON-CONTACT SAFETY SWITCHES H I J K L M N O P Q R S T ETIM 7.0 EC001818 ETIM 8.0 EC001818 UNSPSC 16.0901 39122205 Dimensional drawing (Dimensions in mm (inch)) 90.5 M18 x 1 (3.56) M12 x 1 A B C D E F 65 (2.56) LED 8 x 45° 24 4 (0.16) Response range 1 2 3 4 5 ①  Sensor ②  Close range ③  Enable zone ④  Safe switch off distance Sar ⑤  Actuator Pin assignment Sensor connections 4 2 1 3 4 1 L+ (BN) 2 TE (WH) 3 L– (BU) 4 A (BK) SAFETY SWITCHES | SICK +24 V OUT GND safety controller IN Product data sheet | 2021-08-04 15:20:56 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
IN40-D0304K
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚发射极,4脚集电极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40至+85摄氏度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:常用于电源、通信、工业控制等领域。
7. 封装信息:采用DIP6封装。
IN40-D0304K 价格&库存
很抱歉,暂时无法提供与“IN40-D0304K”相匹配的价格&库存,您可以联系我们找货
