UA30CAD35PGTI
UA30CAD35PGTI
    CARLOGAVAZZI
    Cylinder,Threaded-M30
    SENSOR PROX ULTRA 250-3500MM CYL
UA30CAD35PGTI 数据手册
Ultrasonic Diffuse, Analogue and Digital Output Types UA30CAD......TI • Cylindrical M30 PBT housing • Sensing distance: 250-3500 mm • Power supply: 12 (15) to 30 VDC • Outputs: 0-10 VDC or 4-20 mA and one switching output NPN or PNP. • Linearity error 0.5% • Repeatability 0.2% • Beam angle. ±6° • Protection: Short-circuit, reverse polarity and overvoltage • Protection degree IP 67, Nema 4X • 2 m cable or M12 plug Product Description Ordering Key A family of diffuse ultrasonic sensors with sensing range from 250-3500 mm with a resolution as low as 2.0 mm. The sensor contains both an analogue and a digital output. The output is either 0-10V or 4-20 mA and the digital output NPN or PNP, NO or NC which forms a windows detection. Ultrasonic sensor Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection Teach-in The sensor is the ideal choice for distance measurement, level measurement, diameter measurement or loop control. Due to use of microprocessor control the digital filtering makes the sensor immune to most electromagnetic inter­ ferences. UA30CAD35NGM1TI Type Selection Housing diameter Connec- tion Rated operating dist. (Sn) Analog Digital output Ordering no. Output NPN/PNP M30 M30 M30 M30 M30 M30 M30 M30 Plug M12 Cable Plug M12 Cable Plug M12 Cable Plug M12 Cable 250-3500 250-3500 250-3500 250-3500 250-3500 250-3500 250-3500 250-3500 4-20 4-20 0-10 0-10 4-20 4-20 0-10 0-10 mm mm mm mm mm mm mm mm mA mA V V mA mA V V NPN NPN NPN NPN PNP PNP PNP PNP UA UA UA UA UA UA UA UA 30 30 30 30 30 30 30 30 CAD CAD CAD CAD CAD CAD CAD CAD 35 35 35 35 35 35 35 35 NG M1 TI NG TI NK M1 TI NK TI PG M1 TI PG TI PK M1 TI PK TI Specifications Rated operating distance (Sn) Reference target: 1 mm metal rolled finish, size 200 x 200 mm. 250 - 3500 mm Blind zone ≤ 250 mm Repeatability 0.2% Linearity error 0.5% Beam angle ±6˚ Sensitivity Push-button P1 (longest setpoint) P2 (shortest setpoint) Resolution 2 mm Temperature drift 0.1%/˚C @ -20˚ to +70˚ C Temperature compensation Yes Hysteresis (H) Min. 0.5% Specifications are subject to change without notice (12.05.2014) Rated operational voltage (UB) NG or PG versions 12 to 30 VDC NK or PK versions 15 to 30 VDC (ripple included) Ripple (Urpp) ≤ 5% No-load supply current (Io) 50 mA @ UB max Output current continuous digital output (Ie) Max. load capacity 100 nF 100 mA Output current short-time digital output (I) Max. load capacity 100 nF 100 mA Minimum operational current digital output (Im) 0.5 mA OFF-state current digital output (Ir) 10 μA 1 UA30CAD.. Specifications (cont.) Voltage drop digital output (Ud) ≤ 2.2 VDC @ 100 mA Protection Digital output Short-circuit, overvoltage pulses and reverse polarity Supply Overvoltage pulses and reverse polarity Analogue output Overvoltage pulses Analog output NG.. or PG.. types 4 to 20 mA NK.. or PK.. types 0 to 10 VDC Load 4 to 20 mA max. 500 Ω 0 to 10 VDC min. 3 kΩ Carrier frequency 112 kHz Operating frequency digital output (f) ≤ 2 Hz Response time OFF-ON digital output (tON) ≤ 250 mS Response time ON-OFF digital output (tOFF) ≤ 250 mS Response time analog output ≤ 500 mS Power ON delay ≤ 500 mS Output function, open collector By sensor type NPN or PNP Output switching function One open collector transis- tor and one analogue output to be configured as: - Windows function with N.O or N.C. output. - Analogue output with positive or negative slope. Indication Output ON Yellow LED Echo received Green LED Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock Rated insulation voltage Housing Material body Material front Material back, plug Material back, cable Material push-button Sealing around push-button Material sealing front Connection Cable Plug Tightening torque Weight Cable version Plug version CE-marking Approvals Wiring Diagram Detection Range lll (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP67 (IEC 60529; 60947-1) Nema 4X -20° to +70°C (-4° to +158°F) -35° to +70°C (-31° to +158°F) 10 to 55 Hz, 1.0 mm/6G. (IEC/EN 60068-2-6) 30 g / 11 mS, 3 directions (IEC/EN 60068-2-27) < 500 VAC (rms) PBT Epoxy-glass resin Grilamid Grilamid TPE TPE TPE PVC, grey, 2 m, 4 x 0.34 mm2, Ø = 4.7 mm M12, 4-pin (CON. 14-series) ≤ 1.5 Nm 160 g 90 g Yes cULus (UL508) X U BK4 BU3 Voltage BN1 NPN: U BK4 WH2 BU3 I 400 BK4 BU3 Current BN1 I BK4 WH2 BU3 Y Sensor Parallel displacement (mm) PNP: Target 0 1.6 3.3 Distance (feet) 4.9 6.6 8.2 9.8 11.5 15.7 300 11.8 200 7.9 100 3.9 0 0 -100 -3.9 -200 -7.9 -300 -11.8 -400 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 Parallel displacement (inch) BN1 WH2 BN1 WH2 -15.7 Distance (m) 2 Specifications are subject to change without notice (12.05.2014) Green 89.8 69.6 Teach M 12 x 1 - 6g Yellow M 30 x 1.5 - 6g UA30CAD.. Teach 10 10 3 Green Teach Teach Yellow 89.8 69.6 Teach Green O 4.7 Yellow 89.8 69.6 M 12 x 1 - 6g Teach Cable M 30 x 1.5 - 6g Plug M 30 x 1.5 - 6g Dimensions 10 10 10 3 3 Teach M 30 x 1.5 - 6g Programming setup 89.8 69.6 Teach General set up Yellow Greenof sensing point P1 (longest distance) and Shortest distance (P2) independent on the sensor type or function. O 4.7 1) Mount the sensor in the selected application 2) Place a target in front of the sensor at the maximum required distance (P1), then press shortly on the teach-button, 10 3 the Yellow LED switch Off and then On again after maximum 2 seconds. The distance (P1) is now saved in the sensor, and the target can be moved. I) 3) Place the target at the minimum distance requested (P2), then press shortly on the teach-button, the yellow LED turn Off then flash 5 times . The distance (P2) is now saved in the sensor and the target can be moved. II) I) P1 can be set to a maximum exceeding the family specification for the sensor by removing the target in front of the sensor, push and hold the teach-button more than one second and the sensing distance is set at a unique distance for this sensor only. Do not use this function for an analogue output. II) The second switch point can be set to minimum by setting the target within the blind zone close to the sensor head or by covering the sensor head with your hand while teaching P2. Sensors with 1 digital output and one analogue output UA..CAD..PG/PK/NG or NK types 1) The factory setting is Normally Open N.O. for the digital output and positive slope for the analogue output. Digital output distance 2) To reverse the slope to negative and reverse the N.O. output to Normally Closed N.C. Push the teach-button for 8 second until the yellow LED flash fast release the teach button and the LED will flash 5 times to acknowledge the change in function. Digital output 3) To switch back to positive slope or N.O. output, repeat step 2. Specifications are subject to change without notice (12.05.2014) 3 Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Delivery Contents Accessories • Ultrasonic sensor: UA30CAD.... • Installation instruction • Mounting: 2 x M30 Nuts 2 x rubber washers • Packaging: Carton box 35 x 107 x 173 mm • Connector type CONM14NF.. series 4 Specifications are subject to change without notice (12.05.2014)
UA30CAD35PGTI 价格&库存
很抱歉,暂时无法提供与“UA30CAD35PGTI”相匹配的价格&库存,您可以联系我们找货
