CJ10-30GK-WS
CJ10-30GK-WS
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M30
    CAPACITIVE SEN 10MM NO
CJ10-30GK-WS 数据手册
Capacitive sensor CJ10-30GK-WS < 10 mm non-flush < The switching distance can be set over a wide range with the potentiometer Dimensions 60 5 5 1 M30 x 1.5 80 36 LED Technical Data Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 020051_eng.pdf General specifications Switching function Normally open (NO) Output type Rated operating distance Two-wire sn Installation non-flush Output polarity Assured operating distance 10 mm AC sa Output type 0 ... 7.2 mm 2-wire Nominal ratings Installation conditions A 18 mm B 10 mm C 20 mm F 60 mm Operating voltage UB 20 ... 253 V AC 1) Switching frequency f 0 ... 10 Hz Hysteresis H 2 ... 10 typ. 5 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Capacitive sensor CJ10-30GK-WS Technical Data Reverse polarity protection reverse polarity tolerant Voltage drop at IL Voltage drop IL = 100 mA, switching element on Ud Momentary current (20 ms, 0.1 Hz) typ. 7 V 0 ... 1200 mA Rated insulation voltage UBIS 1500 V Operating current IL 5 ... 200 mA Lowest operating current Im 5 mA Off-state current Ir 0.7 ... 1.5 mA typ. Time delay before availability tv ≤ 300 ms Switching state indicator LED, yellow Indicators/operating means Potentiometer sensitivity adjustment Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -25 ... 85 °C (-13 ... 185 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.75 mm2 Housing material PBT Sensing face PBT Degree of protection IP67 Note 1) In the temperature range below 0 °C, permissible operating voltage Ub 80...253 V Safety fuse ≤ 0.8 A (quick-blow) according to IEC 60127-2 Sheet 1 Recommendation: after a short circuit, check that the device is functioning correctly. Connection L BU N Installation B F sensing face C metal-free zone A Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 020051_eng.pdf BN support Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Capacitive sensor CJ10-30GK-WS Accessories Mounting flange, 30 mm Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 020051_eng.pdf BF 30 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
CJ10-30GK-WS 价格&库存
很抱歉,暂时无法提供与“CJ10-30GK-WS”相匹配的价格&库存,您可以联系我们找货
