NBN3-F31-E8-V1
NBN3-F31-E8-V1
    PEPPERL+FUCHS(倍加福)
    INDUCTIVE SEN 3MM PNP
NBN3-F31-E8-V1 数据手册
Inductive sensor NBN3-F31-E8-V1 < Direct mounting on standard actuators < Fixed setting Dimensions 33.5 10 5 36 9 5.4 7 I LED M12 x 1 30 65 II 14 25 Technical Data Release date: 2021-02-22 Date of issue: 2021-02-22 Filename: 047570_eng.pdf General specifications Switching function 2 x normally open (NO) Output type Rated operating distance PNP sn Installation 3 mm flush mountable Output polarity DC Assured operating distance sa 0 ... 2.43 mm Actual operating distance sr 2.7 ... 3.3 mm typ. Reduction factor rAl 0.5 Reduction factor rCu 0.4 Reduction factor r304 1 Reduction factor rSt37 1.2 Output type 3-wire Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 500 Hz Hysteresis H typ. 5 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBN3-F31-E8-V1 Technical Data Reverse polarity protection all connections Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 100 mA Off-state current Ir 0 ... 0.5 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 25 mA Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 780 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates EAC conformity TR CU 020/2011 UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection (system side) 4-pin, M12 x 1 connector Connector housing metal Housing material PBT Sensing face PBT Degree of protection IP67 Release date: 2021-02-22 Date of issue: 2021-02-22 Filename: 047570_eng.pdf Connection Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBN3-F31-E8-V1 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Matching System Components BT115A Activator for F31 series BT115X Activator for F31 series Accessories Activator for F31 series BT115B Activator for F31 series V1-G-2M-PUR Female cordset single-ended M12 straight A-coded, 4-pin, PUR cable grey V1-W-2M-PUR Female cordset single-ended M12 angled A-coded, 4-pin, PUR cable grey BT65A Activator for F31 series BT65X Activator for F31 series Release date: 2021-02-22 Date of issue: 2021-02-22 Filename: 047570_eng.pdf BT65B Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBN3-F31-E8-V1
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发射极,4脚集电极,5脚GND,6脚VCC。
4. 参数特性:工作电压范围为3V-15V,隔离电压为5000Vrms,响应时间为1us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
NBN3-F31-E8-V1 价格&库存
很抱歉,暂时无法提供与“NBN3-F31-E8-V1”相匹配的价格&库存,您可以联系我们找货
