IC17CNC04PO-K
IC17CNC04PO-K
    CARLOGAVAZZI
    Module
    SENSOR PROX INDUCTIVE 4MM MODULE
IC17CNC04PO-K 数据手册
Proximity Sensors Inductive Rectangular Plastic Housings Types IC, Cable • • • • • • Plastic housing Sensing distance: 4 mm Non-flush mounting Output: Transistor, NPN/PNP, normally open Power supply: 10 to 30 VDC 2 m PVC cable Product Description Ordering Key Inductive proximity sensor in rectangular plast housing. This series is suitable for the control of axial and rotational movements. Output con- Ind. prox. switch Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration figured as PNP or NPN, normally open. Connection with 2 m PVC cable. IC 17 CNC 04 NO-K Type Selection Rated op. dist. (Sn) Connection Housing dimensions [mm] Ordering no. Transistor, NPN Normally open Ordering no. Transistor, PNP Normally open 4 mm Cable 17.5 x 17 x 28.5 IC 17 CNC 04 NO-K IC 17 CNC 04 PO-K Sensing distance Effective operating dist. (Sr) Usable operating dist. (Su) Ambient temperature Operating Storage Degree of protection Housing material CE-marking Connection 4 mm 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.85 x Sr ≤ Su ≤ 1.15 x Sr Specifications Rated operational volt. (UB) Ripple Rated operational current (Ie) Continuous No-load supply current (Io) Voltage drop (Ud) Frequency of op. cycles (f) Indication for output ON 10 to 30 VDC (ripple included) ≤ 10% ≤ 100 mA @ 25°C ≤ 12 mA (ON) < 1 V (@ Imax 500 Hz LED, yellow Specifications are subject to change without notice (18.05.10) -25° to +70°C (-13° to +158°F) -30° to +75°C (-22° to +167°F) IP 67 (Nema 1, 3, 4, 6, 13) Plastic Yes Cable, 2 m, PVC, AWG 26 1 IC, Cable Wiring Diagrams Dimensions LED 1 BN + 1 BN + 2 x Ø 3,3 17,5 10 4 BK 25,5 28,5 4 BK 3 BU 3 BU - NPN - Normally open - 17 PNP - Normally open Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 2 Specifications are subject to change without notice (18.05.10)
IC17CNC04PO-K 价格&库存
很抱歉,暂时无法提供与“IC17CNC04PO-K”相匹配的价格&库存,您可以联系我们找货
IC17CNC04PO-K
  • 1+1198.242561+155.21432
  • 10+992.9525110+128.62208
库存:10
