ICB12S30N08PAM1
ICB12S30N08PAM1
    CARLOGAVAZZI
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 8MM CYLIND
ICB12S30N08PAM1 数据手册
ICB series - Inductive proximity sensors ICB series ICB series - 3 and 4-wire DC Inductive proximity sensors provide a reliable and cost effective solution for many applications in machinery and automation equipment. These robust sensors detect metal objects without physical contact, giving a wear-free solution in harsh environments. Inductive sensors are not influenced by dust, oil, water, or vibrations. Operating at high switching frequencies, they feature high resolution, excellent repeatability and precision, and exceptional resistance to shocks. What sets the ICB series apart is their onboard microprocessor that takes them into the world of digital technology, merging the benefits of sensing and data transmission. Furthermore, compared to today’s sensor technology, our innovative hot melt potting make these sensors the state-ofthe-art sensor of choice. Eco-friendly sensing ICB series represents a complete family of high performance inductive sensors, built to the highest-quality standards and resulting from over 50 years’ experience at Carlo Gavazzi in designing and producing proximity sensors. Several installation possibilities: • Flush and non-flush versions • NPN or PNP, NO or NC output • 2-meter oil resistant PVC cable or M12 disconnect plug The new range includes: • M12, M18 and M30 long or short barrel housings • Sensing range from 2 mm up to 40 mm • 3-wire and 4-wire DC Approvals: • All ICB sensors bear the cULus certification and CE mark • The ICB 3-wire DC serie are cCSAus certified for Hazardous Location All sensors come with: • Rugged nickel plated brass construction • Excellent LED output state visibility • Short circuit, reverse polarity and transients protection 2 CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. Main features A new generation of microprocessor All the ICB series sensors feature a new generation of microprocessor, that allows final calibration of the sensor at the end of the assembly process and provides: - Temperature stability over the whole temperature range - Increased EMC robustness - Greater reliability and repeatability - High precision and minimum deviation - Possibility of customization such as programmable outputs and switching frequencies Assured traceability and best application control The traceability is guaranteed by the permanently legible laser engraved part number and serial number on the plastic cap of the sensor. The LED in the new ICB series sensors is clearly visible from any direction both in the cable and in the plug-disconnect versions. In addition to the indication of the switching state, with the ICB sensors we have introduced a new function for the LED. When it blinks with a frequency of 2Hz the LED indicates a short-circuit or overload condition, thus simplifying troubleshooting. Environmentally friendly potting material In ICB12 and ICB18 families the potting material provides an ecofriendly design and high performance. This thermoplastic hotmelt filling is made from recycled corn by-product and allows: - Reduced impact on the environment - Higher resistance to mechanical stress and vibrations - No risk of breaking electronic components - Increased reliability and improved stability - Longer sensor lifetime CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. 3 ICB series Inductive proximity sensors Market applications Machine tool CNC machines repeat precise sequences and are able to produce the most complex pieces. Tool changing machines for example automatically change the specific tool. A drill machine has a variety of drill bits to make holes of several sizes. Inductive sensors are used to check the tool position when changing the tool or to verify the component moved to the correct location. ICB series represents a suitable solution thanks to: - The improved performance with vibrations and shocks - Reliable connection system between the cable and the barrel - Very high resolution and quick response time Achieved benefits: - Optimized and fast setup - Reliable and cost effective solution Agriculture Inductive sensors are mainly used for non contact detection of the position of a part on the machine or equipment itself. Thanks to its excellent quality and to the complete product range, ICB series is particularly suitable for the agricultural and earth-moving sectors. ICB series allows: - Personalized solution with customizable termination options - High durability and quality - Resistance to extreme conditions, such as oily and dusty environment Achieved benefits: - Reduced installation costs - Product reliability and durability - Complete range to satisfy application needs all Material handling systems Material handling systems interconnect the different processes of production, from the raw material to the final product. In these systems it is mandatory to ensure the automatic and reliable flow of goods. Inductive sensors are critical to obtaining the higher productivity and quality from the automated process. - High precision stability and temperature Achieved benefits: - Precise fit with customized solutions - Programmable sensing distance and frequency ICB series is an ideal choice very well thanks to: - Microprocessor technology 4 CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. ICB series - Triple sensing distance Sn = 40 mm The robust and highly reliable ICB series is now available in increased operating distance. In M12, M18 and M30 industrial standard nickel plated brass housings. The new sensors are extremely accurate and represent the best choice for non-contact detection of metallic targets at a distance up to 40 mm, the largest sensing distance available on the market for an inductive sensor. The powerful design of ICB offers the ideal solution in demanding installation conditions typical of industrial environments. The eco-friendly high performance potting material protects the electronic components and provides increased reliability with higher resistance to mechanical stress and vibrations than the traditional proximity sensors. ICB inductive proximity sensors thanks to an operating distance up to 3 times the standard, allows to position the sensor at an higher distance from a metal target. The result is an increased sensor’s lifetime especially when the metal target has greater tolerances, being the sensor well protected. All options already available in ICB standard and extended series are now also available in increased operating distance: The sensors are rated to IP67 and the mechanical design of the back part ensures an excellent sealing against water and humidity penetration. Thanks to the built in microcontroller, all sensors are individually compensated to ensure repeatable and highly accurate operation over the whole temperature range, granting the sensing distance between -25 and +70°C (-13° to +158°F). - Long and short barrel housings - Quasi-flush or non-flush mounting in metal - NO or NC - M12-plug or 2 m PVC cable versions - NPN or PNP switching outputs. CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. 5 ICB series Inductive proximity sensors Your benefits New design of the back part for cable version Strong cable strain releaf 7.5mm milling for easier installation 4 x 90° LED Laser printing ICB12 Quasi-flush: Sn 6 mm Non-flush: Sn 10 mm ICB18 Quasi-flush: Sn 12 mm Non-flush: Sn 20 mm ICB30 Quasi-flush: Sn 22 mm Non-flush: Sn 40 mm Longer sensing distance Installing the sensor at a longer distance from the moving metal objects reduces the risk of breakdowns granting much lower failure rate. Laser printing The most important information are permanently laser engraved on the front cap granting the best traceability. High operating frequency The high operating frequency allows high speed measurements in counting tasks or for monitoring rotational speed. Easy mounting Diagnostics The installation of the sensor is much easier thanks to the built-in setup function. By approaching the target to the sensor’s face the LED starts blinking when the effective operating distance (Sr) is between 80% and 100% of the rated operating distance and lights continuously when it is below 80%. Thus allowing the installer to position the proximity sensor at the correct distance from the target. 6 LED is clearly visible from any direction in both cable and plug disconnect version. Further to the indication for output ON the LED also has an additional diagnostic function. It flashes with a frequency of 3 Hz in case of shorts circuit or overload. CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. ICB: a complete range for any application Family Diameter Operating distance Switching frequency Output Connection ICB12 M12 2 to 10 mm up to 2000 Hz NPN-PNP Cable / Plug ICB18 M18 5 to 20 mm up to 1500 Hz NPN-PNP Cable / Plug ICB30 M30 10 to 40 mm up to 1000 Hz (except for ICB30 3X: ≤ 100 Hz) NPN-PNP Cable / Plug ICB12 ICB18 ICB30 Operating distance Family Operating distance (mm.) 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 1X ICB12 2X 3X 1X ICB18 2X 3X 1X ICB30 2X 3X Your sensor - your way Carlo Gavazzi is committed to providing the right solution to our OEM customers and their demanding application requirements. This means that we are ready to customize proximity sensors to meet these specific demands for almost any application. CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. 7 ICB series Inductive proximity sensors The new generation of inductive proximity sensors: ICB series ICB 12 S 30 F 04 N O M1 Housing 12 18 30 size: 12 Ø mm 18 Ø mm 30 Ø mm Housing length: S Short body L Long body Thread length: 30 30 mm ... 50 50 mm Detection principle: F Flush N Non-flush Sensing distance: 02 2 mm ... 40 40 mm Output type: N NPN P PNP Output configuration: O Normally open C Normally closed A Antivalent Connection: M1 M12 disconnect plug - 2 m PVC oil resistant cable 8 CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. ICB12 series (M12) Standard sensing range (1 X) Rated operating distance 2 mm 4 mm Installation type Flush Non-flush Barrel NPN Cable PNP 3-wire NPN Plug PNP Cable 4-wire Plug NO Short Long Short Long ICB12S30F02NO ICB12L50F02NO ICB12S30N04NO ICB12L50N04NO NC ICB12S30F02NC ICB12L50F02NC ICB12S30N04NC ICB12L50N04NC NO ICB12S30F02PO ICB12L50F02PO ICB12S30N04PO ICB12L50N04PO ICB12S30F02PC ICB12L50F02PC ICB12S30N04PC ICB12L50N04PC NC NO ICB12S30F02NOM1 ICB12L50F02NOM1 ICB12S30N04NOM1 ICB12L50N04NOM1 NC ICB12S30F02NCM1 ICB12L50F02NCM1 ICB12S30N04NCM1 ICB12L50N04NCM1 NO ICB12S30F02POM1 ICB12L50F02POM1 ICB12S30N04POM1 ICB12L50N04POM1 NC ICB12S30F02PCM1 ICB12L50F02PCM1 ICB12S30N04PCM1 ICB12L50N04PCM1 NPN NO+NC ICB12S30F02NA ICB12L50F02NA ICB12S30N04NA ICB12L50N04NA PNP NO+NC ICB12S30F02PA ICB12L50F02PA ICB12S30N04PA ICB12L50N04PA NPN NO+NC ICB12S30F02NAM1 ICB12L50F02NAM1 ICB12S30N04NAM1 ICB12L50N04NAM1 PNP NO+NC ICB12S30F02PAM1 ICB12L50F02PAM1 ICB12S30N04PAM1 ICB12L50N04PAM1 Extended sensing range (2 X) Rated operating distance 4 mm 8 mm Installation type Flush Non-flush Barrel NPN Cable PNP 3-wire NPN Plug PNP Cable 4-wire Plug NO Short Long Short Long ICB12S30F04NO ICB12L50F04NO ICB12S30N08NO ICB12L50N08NO NC ICB12S30F04NC ICB12L50F04NC ICB12S30N08NC ICB12L50N08NC NO ICB12S30F04PO ICB12L50F04PO ICB12S30N08PO ICB12L50N08PO ICB12S30F04PC ICB12L50F04PC ICB12S30N08PC ICB12L50N08PC NC NO ICB12S30F04NOM1 ICB12L50F04NOM1 ICB12S30N08NOM1 ICB12L50N08NOM1 NC ICB12S30F04NCM1 ICB12L50F04NCM1 ICB12S30N08NCM1 ICB12L50N08NCM1 NO ICB12S30F04POM1 ICB12L50F04POM1 ICB12S30N08POM1 ICB12L50N08POM1 NC ICB12S30F04PCM1 ICB12L50F04PCM1 ICB12S30N08PCM1 ICB12L50N08PCM1 NPN NO+NC ICB12S30F04NA ICB12L50F04NA ICB12S30N08NA ICB12L50N08NA PNP NO+NC ICB12S30F04PA ICB12L50F04PA ICB12S30N08PA ICB12L50N08PA NPN NO+NC ICB12S30F04NAM1 ICB12L50F04NAM1 ICB12S30N08NAM1 ICB12L50N08NAM1 PNP NO+NC ICB12S30F04PAM1 ICB12L50F04PAM1 ICB12S30N08PAM1 ICB12L50N08PAM1 Increased sensing range (3 X) Rated operating distance Installation type Barrel NPN Cable PNP 3-wire NPN Plug PNP NO 6 mm 10 mm Quasi-flush Non-flush Short Long Short Long ICB12S30F06NO ICB12L50F06NO ICB12S30N10NO ICB12L50N10NO NC ICB12S30F06NC ICB12L50F06NC ICB12S30N10NC ICB12L50N10NC NO ICB12S30F06PO ICB12L50F06PO ICB12S30N10PO ICB12L50N10PO NC ICB12S30F06PC ICB12L50F06PC ICB12S30N10PC ICB12L50N10PC NO ICB12S30F06NOM1 ICB12L50F06NOM1 ICB12S30N10NOM1 ICB12L50N10NOM1 NC ICB12S30F06NCM1 ICB12L50F06NCM1 ICB12S30N10NCM1 ICB12L50N10NCM1 NO ICB12S30F06POM1 ICB12L50F06POM1 ICB12S30N10POM1 ICB12L50N10POM1 NC ICB12S30F06PCM1 ICB12L50F06PCM1 ICB12S30N10PCM1 ICB12L50N10PCM1 CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. 9 ICB series Inductive proximity sensors ICB18 series (M18) Standard sensing range (1 X) Rated operating distance 5 mm 8 mm Installation type Flush Non-flush Barrel NPN Cable PNP 3-wire NPN Plug PNP Cable 4-wire Plug NO Short Long Short Long ICB18S30F05NO ICB18L50F05NO ICB18S30N08NO ICB18L50N08NO NC ICB18S30F05NC ICB18L50F05NC ICB18S30N08NC ICB18L50N08NC NO ICB18S30F05PO ICB18L50F05PO ICB18S30N08PO ICB18L50N08PO ICB18S30F05PC ICB18L50F05PC ICB18S30N08PC ICB18L50N08PC NC NO ICB18S30F05NOM1 ICB18L50F05NOM1 ICB18S30N08NOM1 ICB18L50N08NOM1 NC ICB18S30F05NCM1 ICB18L50F05NCM1 ICB18S30N08NCM1 ICB18L50N08NCM1 NO ICB18S30F05POM1 ICB18L50F05POM1 ICB18S30N08POM1 ICB18L50N08POM1 NC ICB18S30F05PCM1 ICB18L50F05PCM1 ICB18S30N08PCM1 ICB18L50N08PCM1 NPN NO+NC ICB18S30F05NA ICB18L50F05NA ICB18S30N08NA ICB18L50N08NA PNP NO+NC ICB18S30F05PA ICB18L50F05PA ICB18S30N08PA ICB18L50N08PA NPN NO+NC ICB18S30F05NAM1 ICB18L50F05NAM1 ICB18S30N08NAM1 ICB18L50N08NAM1 PNP NO+NC ICB18S30F05PAM1 ICB18L50F05PAM1 ICB18S30N08PAM1 ICB18L50N08PAM1 Extended sensing range (2 X) Rated operating distance 8 mm 14 mm Installation type Flush Non-flush Barrel NPN Cable PNP 3-wire NPN Plug PNP Cable 4-wire Plug NO Short Long Short Long ICB18S30F08NO ICB18L50F08NO ICB18S30N14NO ICB18L50N14NO NC ICB18S30F08NC ICB18L50F08NC ICB18S30N14NC ICB18L50N14NC NO ICB18S30F08PO ICB18L50F08PO ICB18S30N14PO ICB18L50N14PO ICB18S30F08PC ICB18L50F08PC ICB18S30N14PC ICB18L50N14PC NC NO ICB18S30F08NOM1 ICB18L50F08NOM1 ICB18S30N14NOM1 ICB18L50N14NOM1 NC ICB18S30F08NCM1 ICB18L50F08NCM1 ICB18S30N14NCM1 ICB18L50N14NCM1 NO ICB18S30F08POM1 ICB18L50F08POM1 ICB18S30N14POM1 ICB18L50N14POM1 NC ICB18S30F08PCM1 ICB18L50F08PCM1 ICB18S30N14PCM1 ICB18L50N14PCM1 NPN NO+NC ICB18S30F08NA ICB18L50F08NA ICB18S30N14NA ICB18L50N14NA PNP NO+NC ICB18S30F08PA ICB18L50F08PA ICB18S30N14PA ICB18L50N14PA NPN NO+NC ICB18S30F08NAM1 ICB18L50F08NAM1 ICB18S30N14NAM1 ICB18L50N14NAM1 PNP NO+NC ICB18S30F08PAM1 ICB18L50F08PAM1 ICB18S30N14PAM1 ICB18L50N14PAM1 Increased sensing range (3 X) Rated operating distance Installation type Barrel NPN Cable PNP 3-wire NPN Plug PNP 10 NO 12 mm 20 mm Quasi-flush Non-flush Short Long Short Long ICB18S30F12NO ICB18L50F12NO ICB18S30N20NO ICB18L50N20NO NC ICB18S30F12NC ICB18L50F12NC ICB18S30N20NC ICB18L50N20NC NO ICB18S30F12PO ICB18L50F12PO ICB18S30N20PO ICB18L50N20PO NC ICB18S30F12PC ICB18L50F12PC ICB18S30N20PC ICB18L50N20PC NO ICB18S30F12NOM1 ICB18L50F12NOM1 ICB18S30N20NOM1 ICB18L50N20NOM1 NC ICB18S30F12NCM1 ICB18L50F12NCM1 ICB18S30N20NCM1 ICB18L50N20NCM1 NO ICB18S30F12POM1 ICB18L50F12POM1 ICB18S30N20POM1 ICB18L50N20POM1 NC ICB18S30F12PCM1 ICB18L50F12PCM1 ICB18S30N20PCM1 ICB18L50N20PCM1 CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. ICB30 series (M30) Standard sensing range (1 X) Rated operating distance 10 mm 15 mm Flush Non-flush Installation type Barrel NPN Cable PNP 3-wire NPN Plug PNP Cable 4-wire Plug NO Short Long Short Long ICB30S30F10NO ICB30L50F10NO ICB30S30N15NO ICB30L50N15NO NC ICB30S30F10NC ICB30L50F10NC ICB30S30N15NC ICB30L50N15NC NO ICB30S30F10PO ICB30L50F10PO ICB30S30N15PO ICB30L50N15PO ICB30S30F10PC ICB30L50F10PC ICB30S30N15PC ICB30L50N15PC NC NO ICB30S30F10NOM1 ICB30L50F10NOM1 ICB30S30N15NOM1 ICB30L50N15NOM1 NC ICB30S30F10NCM1 ICB30L50F10NCM1 ICB30S30N15NCM1 ICB30L50N15NCM1 NO ICB30S30F10POM1 ICB30L50F10POM1 ICB30S30N15POM1 ICB30L50N15POM1 NC ICB30S30F10PCM1 ICB30L50F10PCM1 ICB30S30N15PCM1 ICB30L50N15PCM1 NPN NO+NC ICB30S30F10NA ICB30L50F10NA ICB30S30N15NA ICB30L50N15NA PNP NO+NC ICB30S30F10PA ICB30L50F10PA ICB30S30N15PA ICB30L50N15PA NPN NO+NC ICB30S30F10NAM1 ICB30L50F10NAM1 ICB30S30N15NAM1 ICB30L50N15NAM1 PNP NO+NC ICB30S30F10PAM1 ICB30L50F10PAM1 ICB30S30N15PAM1 ICB30L50N15PAM1 Extended sensing range (2 X) Rated operating distance 15 mm 22 mm Flush Non-flush Installation type Barrel NPN Cable PNP 3-wire NPN Plug PNP Cable 4-wire Plug NO Short Long Short Long ICB30S30F15NO ICB30L50F15NO ICB30S30N22NO ICB30L50N22NO NC ICB30S30F15NC ICB30L50F15NC ICB30S30N22NC ICB30L50N22NC NO ICB30S30F15PO ICB30L50F15PO ICB30S30N22PO ICB30L50N22PO ICB30S30F15PC ICB30L50F15PC ICB30S30N22PC ICB30L50N22PC NC NO ICB30S30F15NOM1 ICB30L50F15NOM1 ICB30S30N22NOM1 ICB30L50N22NOM1 NC ICB30S30F15NCM1 ICB30L50F15NCM1 ICB30S30N22NCM1 ICB30L50N22NCM1 NO ICB30S30F15POM1 ICB30L50F15POM1 ICB30S30N22POM1 ICB30L50N22POM1 NC ICB30S30F15PCM1 ICB30L50F15PCM1 ICB30S30N22PCM1 ICB30L50N22PCM1 NPN NO+NC ICB30S30F15NA ICB30L50F15NA ICB30S30N22NA ICB30L50N22NA PNP NO+NC ICB30S30F15PA ICB30L50F15PA ICB30S30N22PA ICB30L50N22PA NPN NO+NC ICB30S30F15NAM1 ICB30L50F15NAM1 ICB30S30N22NAM1 ICB30L50N22NAM1 PNP NO+NC ICB30S30F15PAM1 ICB30L50F15PAM1 ICB30S30N22PAM1 ICB30L50N22PAM1 Increased sensing range (3 X) Rated operating distance Installation type Barrel NPN Cable PNP 3-wire NPN Plug PNP NO 22 mm 40 mm Quasi-flush Non-flush Short Long Short Long ICB30S30F22NO ICB30L50F22NO ICB30S30N40NO ICB30L50N40NO NC ICB30S30F22NC ICB30L50F22NC ICB30S30N40NC ICB30L50N40NC NO ICB30S30F22PO ICB30L50F22PO ICB30S30N40PO ICB30L50N40PO NC ICB30S30F22PC ICB30L50F22PC ICB30S30N40PC ICB30L50N40PC NO ICB30S30F22NOM1 ICB30L50F22NOM1 ICB30S30N40NOM1 ICB30L50N40NOM1 NC ICB30S30F22NCM1 ICB30L50F22NCM1 ICB30S30N40NCM1 ICB30L50N40NCM1 NO ICB30S30F22POM1 ICB30L50F22POM1 ICB30S30N40POM1 ICB30L50N40POM1 NC ICB30S30F22PCM1 ICB30L50F22PCM1 ICB30S30N40PCM1 ICB30L50N40PCM1 CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. 11 OUR SALES NETWORK IN EUROPE AUSTRIA Carlo Gavazzi GmbH Ketzergasse 374, A-1230 Wien Tel: +43 1 888 4112 Fax: +43 1 889 10 53 office@carlogavazzi.at FRANCE Carlo Gavazzi Sarl Zac de Paris Nord II, 69, rue de la Belle Etoile, F-95956 Roissy CDG Cedex Tel: +33 1 49 38 98 60 Fax: +33 1 48 63 27 43 french.team@carlogavazzi.fr ITALY Carlo Gavazzi SpA Via Milano 13, I-20020 Lainate Tel: +39 02 931 761 Fax: +39 02 931 763 01 info@gavazziacbu.it SPAIN Carlo Gavazzi SA Avda. Iparraguirre, 80-82, E-48940 Leioa (Bizkaia) Tel: +34 94 480 4037 Fax: +34 94 431 6081 gavazzi@gavazzi.es BELGIUM Carlo Gavazzi NV/SA Mechelsesteenweg 311, B-1800 Vilvoorde Tel: +32 2 257 4120 Fax: +32 2 257 41 25 sales@carlogavazzi.be GERMANY Carlo Gavazzi GmbH Pfnorstr. 10-14 D-64293 Darmstadt Tel: +49 6151 81000 Fax: +49 6151 81 00 40 info@gavazzi.de NETHERLANDS Carlo Gavazzi BV Wijkermeerweg 23, NL-1948 NT Beverwijk Tel: +31 251 22 9345 Fax: +31 251 22 60 55 info@carlogavazzi.nl SWEDEN Carlo Gavazzi AB V:a Kyrkogatan 1, S-652 24 Karlstad Tel: +46 54 85 1125 Fax: +46 54 85 11 77 info@carlogavazzi.se DENMARK Carlo Gavazzi Handel A/S Over Hadstenvej 40, DK-8370 Hadsten Tel: +45 89 60 6100 Fax: +45 86 98 15 30 handel@gavazzi.dk GREAT BRITAIN Carlo Gavazzi UK Ltd 4.4 Frimley Business Park, Frimley, Camberley, Surrey GU16 7SG Tel: +44 1 276 854 110 Fax: +44 1 276 682 140 sales@carlogavazzi.co.uk NORWAY Carlo Gavazzi AS Melkeveien 13, N-3919 Porsgrunn Tel: +47 35 93 0800 Fax: +47 35 93 08 01 post@gavazzi.no SWITZERLAND Carlo Gavazzi AG Verkauf Schweiz/Vente Suisse Sumpfstrasse 3, CH-6312 Steinhausen Tel: +41 41 747 4535 Fax: +41 41 740 45 40 info@carlogavazzi.ch FINLAND Carlo Gavazzi OY AB Ahventie, 4 B, FI-02170 Espoo Tel: +358 9 756 2000 Fax: +358 9 756 20010 myynti@gavazzi.fi PORTUGAL Carlo Gavazzi Lda Rua dos Jerónimos 38-B, P-1400-212 Lisboa Tel: +351 21 361 7060 Fax: +351 21 362 13 73 carlogavazzi@carlogavazzi.pt OUR SALES NETWORK IN THE AMERICAS USA Carlo Gavazzi Inc. 750 Hastings Lane, Buffalo Grove, IL 60089, USA Tel: +1 847 465 6100 Fax: +1 847 465 7373 sales@carlogavazzi.com CANADA Carlo Gavazzi Inc. 2660 Meadowvale Boulevard, Mississauga, ON L5N 6M6, Canada Tel: +1 905 542 0979 Fax: +1 905 542 22 48 gavazzi@carlogavazzi.com MEXICO Carlo Gavazzi Mexico S.A. de C.V. Calle La Montaña no. 28, Fracc. Los Pastores Naucalpan de Juárez, EDOMEX CP 53340 Tel & Fax: +52.55.5373.7042 mexicosales@carlogavazzi.com BRAZIL Carlo Gavazzi Automação Ltda.Av. Francisco Matarazzo, 1752 Conj 2108 - Barra Funda - São Paulo/SP Tel: +55 11 3052 0832 Fax: +55 11 3057 1753 info@carlogavazzi.com.br OUR SALES NETWORK IN ASIA AND PACIFIC SINGAPORE Carlo Gavazzi Automation Singapore Pte. Ltd. 61 Tai Seng Avenue #05-06 Print Media Hub @ Paya Lebar iPark Singapore 534167 Tel: +65 67 466 990 Fax: +65 67 461 980 info@carlogavazzi.com.sg MALAYSIA Carlo Gavazzi Automation (M) SDN. BHD. D12-06-G, Block D12, Pusat Perdagangan Dana 1, Jalan PJU 1A/46, 47301 Petaling Jaya, Selangor, Malaysia. Tel: +60 3 7842 7299 Fax: +60 3 7842 7399 sales@gavazzi-asia.com CHINA Carlo Gavazzi Automation (China) Co. Ltd. Unit 2308, 23/F., News Building, Block 1,1002 Middle Shennan Zhong Road, Shenzhen, China Tel: +86 755 83699500 Fax: +86 755 83699300 sales@carlogavazzi.cn HONG KONG Carlo Gavazzi Automation Hong Kong Ltd. Unit 3 12/F Crown Industrial Bldg., 106 How Ming St., Kwun Tong, Kowloon, Hong Kong Tel: +852 23041228 Fax: +852 23443689 MALTA Carlo Gavazzi Ltd Zejtun ITALY Carlo Gavazzi Controls SpA Belluno CHINA Carlo Gavazzi Automation (Kunshan) Co., Ltd. Kunshan HEADQUARTERS Carlo Gavazzi Automation SpA Via Milano, 13 I-20020 - Lainate (MI) - ITALY Tel: +39 02 931 761 info@gavazziautomation.com Printed on 100% recycled paper produced using post consumer de-inked waste. www.gavazziautomation.com LITHUANIA Uab Carlo Gavazzi Industri Kaunas Kaunas 8028275 BROCHURE ICB ENG R4 05/17 DENMARK Carlo Gavazzi Industri A/S Hadsten Specifications are subject to change without notice. Illustrations are for example only. OUR COMPETENCE CENTRES AND PRODUCTION SITES
ICB12S30N08PAM1 价格&库存
很抱歉,暂时无法提供与“ICB12S30N08PAM1”相匹配的价格&库存,您可以联系我们找货
