Proximity Sensors Inductive
Thermoplastic Polyester Housing
Types EI, AC, M18, M30
• Thermoplastic polyester housing, cylindrical
• Diameter: M18 and M30
• Sensing distance: 5 to 15 mm
• Power supply: 20 to 250 VAC
• Output: SCR, make or break switching
• Protection: Overvoltage
• LED-indication for output ON
• Long or short housing
• 2 m cable or M12 plug (double keyed)
Product Description
AC proximity switches constructed in rugged thermoplastic polyester housings.
Sizes available are M18 and
M30. Length of housing is
selectable with 30 mm
thread or 50 mm thread.
Ordering Key
Bright LED ring utilizing a
yellow LED clearly gives
indication of output status.
Protection rating IP 67
ensures environmental compatibility.
EI 1808 TBCPL-6
Type
Housing diameter (mm)
Rated operating dist. (mm)
Output type
Housing material
Body style
Plug
Type Selection AC Types, Cable and M12 Plug
Housing
diameter
Body
style
Connection
Rated
operating
dist. (Sn)
Ordering no.
SCR NO
M18
M18
M18
M18
Short
Long
Long
Long
Cable
Cable
Cable
Plug
5 mm 1)
5 mm 1)
8 mm 2)
8 mm 2)
EI 1805 TBOPS
EI 1805 TBOPL
EI 1808 TBOPL
M30
M30
Long
Long
Cable
Cable
10 mm 1)
15 mm 2)
EI 3010 TBOPL
EI 3015 TBOPL
1)
2)
Ordering no.
SCR NC
EI 1808 TBCPL
EI 1808 TBCPL-6
For flush mounting in metal
For non-flush mounting in metal
Specifications
Rated operational volt. (Ue)
(UB)
Rated operational current (Ie)
Continuous
Short-time
Minimum load current
OFF-state current (Ir)
Voltage drop (Ud)
Protection
Transient voltage
Power ON delay
Frequency of operating
cycles (f)
24 to 240 VAC
20 to 265 VAC, 50 to 60 Hz
10 - 500 mA
≤ 2.5 A, max. 20 ms
10 mA
≤ 2 mA
≤ 8 VAC at max. load
Transients
Level 3, 2.5 kV, acc. to
IEC 60255-5 (500 Ω, 0.5 J)
(prepared)
≤ 100 ms
25 Hz
Specifications are subject to change without notice (30.04.10)
Indication for output ON
Assured operating dist. (Sa)
Repeat accuracy (R)
Hysteresis (H)
(Differential travel)
Effective operating dist. (Sr)
Usable operating dist. (S)
Ambient temperature
Operating
Storage
Degree of protection
Housing material
Body
Back
LED, yellow
0 ≤ Sa ≤ 0.81 Sn
≤ 5%
3 to 20% of sensing distance
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
0.9 x Sr ≤ Su ≤ 1.1 x Sr
-25° to +70°C (-13° to +158°F)
-30° to +80°C (-22° to +176°F)
IP 67
(Nema 1, 3, 4, 6, 13)
Grey thermoplastic polyester
Black thermoplastic Polyester
1
EI, AC, M18, M30
Specifications (cont.)
Tightening torque
Connection
Cable
2 m, 2 x 0.50 mm2
grey PVC, oil proof
M12 x 1 (double keyed)
CONH6A-xx
EI 18
110 g
EI 30
180 g
Plug
Cables for plug (-6)
Weight (cable excluded)
EI 18
2.6 Nm
EI 30
7.5 Nm
UL, CSA
Yes
Approvals
CE-marking
Dimensions
Type
A
B (mm)
C (mm)
EI 1805 TB..S
EI 1805 TB..L
EI 1808 TB..L
EI 1808 TB..L-6
57
77
85
83
8
M 18 x 1 x 30
M 18 x 1 x 50
M 18 x 1 x 50
M 18 x 1 x 50
Type
A
B (mm)
C (mm)
EI 3010 TB..L
EI 3015 TB..L
79
91
M 30 x 1.5 x 50
M 30 x 1.5 x 50
A
A
3
1
2
M12x1
B
C
B
LED
Cable type
C
LED
Plug type
Wiring Diagrams
2 BN
2 BN
3 BU
3 BU
TBOS
TBCS
Installation Hints
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
Power Supplies
Power supplies VAC:
2
> SS 110
很抱歉,暂时无法提供与“EI1805TBOPL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+811.18535
- 3+796.25296
- 6+781.23593
- 国内价格
- 1+1054.54885
- 3+1028.18513
- 6+957.88188
