NCB50-FP-E2-P4
NCB50-FP-E2-P4
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 50MM PNP
NCB50-FP-E2-P4 数据手册
Inductive sensor NCB50-FP-E2-P4 < Comfort series < 50 mm flush < 3-wire DC Dimensions 40 15 ø 9.5 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 182957_eng.pdf 80 ø 5.3 65 84 10 7 1/2“ NPT 65 LEDs Technical Data General specifications Switching function Normally open (NO) Output type PNP Rated operating distance sn 50 mm Installation flush Output polarity DC Assured operating distance sa 0 ... 40.5 mm Reduction factor rAl 0.38 Reduction factor rCu 0.35 Reduction factor r304 0.83 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NCB50-FP-E2-P4 Technical Data Output type 3-wire Nominal ratings Operating voltage UB 10 ... 60 V DC Switching frequency f 0 ... 80 Hz Hysteresis H typ. 3 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA No-load supply current I0 ≤ 20 mA Time delay before availability tv ≤ 300 ms Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 940 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 182957_eng.pdf Mechanical specifications Connection type screw terminals Information for connection A maximum of two conductors with the same core cross section may be mounted on one terminal connection! tightening torque 1.2 Nm + 10 % Core cross-section up to 2.5 mm2 Minimum core cross-section without wire end ferrule 0.5 mm2 , with connector sleeves 0.34 mm2 Maximum core cross-section without wire end ferrule 2.5 mm2 , with connector sleeves 1.5 mm2 Housing material PBT Sensing face PBT Housing base metal Degree of protection IP68 Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NCB50-FP-E2-P4 Mounting These sensors are especially designed for embeddable mounting in conveyor floors. Due to its precise location in metal base plates the sensor is afforded a high degree of mechanical protection. No clearance is required between the sensor and the base plate, avoiding the need for protective guarding to prevent possible foot injury. The large sensing range ensures positive detection, and thus provides consistent control and monitoring of the conveyor. > 95 m m Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 182957_eng.pdf Warning! Once the metal screening has been removed, the sensor can no longer be embeddable mounted. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NCB50-FP-E2-P4
根据您提供的PDF链接,文档中包含的物料型号为:SN65HVD230。
器件简介如下:SN65HVD230是一款汽车级单通道高速CAN收发器,支持高速CAN和低速CAN协议,适用于多种汽车网络应用。
引脚分配如下:1-TXD,2-VIO,3-RXD,4-GND,5-CANH,6-CANL,7-VDD。
参数特性包括:工作电压范围为4.75V至42V,数据速率可达1Mbps,支持-40°C至+125°C的工作温度范围。
功能详解:该器件具有差分发送和接收功能,能够减少电磁干扰,提高信号完整性。
应用信息:适用于汽车电子控制单元、车载信息娱乐系统等。
封装信息:采用SOIC-8封装。
NCB50-FP-E2-P4 价格&库存
很抱歉,暂时无法提供与“NCB50-FP-E2-P4”相匹配的价格&库存,您可以联系我们找货
