UB300-18GM40-E5-V1
UB300-18GM40-E5-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    ULTRASONIC SEN 35-350MM ANALOG
UB300-18GM40-E5-V1 数据手册
Ultrasonic sensor UB300-18GM40-E5-V1 < < < < < < Short design, 40 mm Function indicators visible from all directions Switch output 5 different output functions can be set Program input Temperature compensation Single head system M18 x 1 M12 x 1 Dimensions 24 4 LED 24.5 39.2 10 Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 220357_eng.pdf 50.2 Technical Data General specifications Sensing range 35 ... 300 mm Adjustment range 50 ... 300 mm Dead band 0 ... 35 mm Standard target plate 100 mm x 100 mm Transducer frequency approx. 390 kHz Response delay approx. 50 ms Indicators/operating means LED green Power on LED yellow indication of the switching state flashing: program function object detected Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Ultrasonic sensor UB300-18GM40-E5-V1 Technical Data LED red solid red: Error red, flashing: program function, object not detected Electrical specifications Operating voltage UB 10 ... 30 V DC , ripple 10 %SS No-load supply current I0 ≤ 20 mA Input Input type 1 program input operating distance 1: -UB ... +1 V, operating distance 2: +6 V ... +UB input impedance: > 4,7 kΩ program pulse: ≥ 1 s Output Output type 1 switching output E5, PNP NO/NC, programmable Rated operating current Ie 200 mA , short-circuit/overload protected Default setting Switch point A1: 50 mm Switch point A2: 300 mm Voltage drop Ud Repeat accuracy ≤3V ≤1 % Switching frequency f Range hysteresis H Temperature influence ≤ 13 Hz 1 % of the set operating distance ± 1.5 % of full-scale value Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007+A1:2012 IEC 60947-5-2:2007 + A1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Mechanical specifications Connection type Connector M12 x 1 , 4-pin Degree of protection IP67 Material Housing brass, nickel-plated Transducer epoxy resin/hollow glass sphere mixture; foam polyurethane, cover PBT Mass 25 g Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 220357_eng.pdf Connection Standard symbol/Connections: (version E5, pnp) U 1 (BN) + UB 2 (WH) Teach input 4 (BK) Switch output 3 (BU) - UB Core colours in accordance with EN 60947-5-2. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Ultrasonic sensor UB300-18GM40-E5-V1 Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Characteristic Curve Characteristic response curve Distance Y [mm] 100 1 50 3 0 2 -50 -100 0 50 100 150 200 250 300 350 400 450 500 550 600 650 700 Distance X [mm] Curve 1: flat surface 100 mm x 100 mm Curve 2: flat surface 10 mm x 10 mm Curve 3: round bar, Ø 25 mm Y X Programming Programmable output modes 1. Window mode, normally open mode A1 < A2: Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 220357_eng.pdf A1 object distance A2 2. Window mode, normally closed mode A2 < A1: A2 A1 3. One switch point, normally open mode A1 -> ∞: A2 4. One switch point, normally closed mode A2 -> ∞: A1 5. A1 -> ∞, A2 -> ∞: Object presence detection mode Object detected: Switch output closed No object detected: Switch output open Accessories UB-PROG2 Programming unit Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Ultrasonic sensor UB300-18GM40-E5-V1 Accessories Mounting aid for round steel ø 12 mm or sheet 1.5 mm ... 3 mm BF 18 Mounting flange, 18 mm BF 18-F Plastic mounting adapter, 18 mm BF 5-30 Universal mounting bracket for cylindrical sensors with a diameter of 5 ... 30 mm V1-G-2M-PVC Female cordset single-ended M12 straight A-coded, 4-pin, PVC cable grey V1-W-2M-PUR Female cordset single-ended M12 angled A-coded, 4-pin, PUR cable grey UVW90-K18 Ultrasonic -deflector M18K-VE Plastic nuts with centering ring for the vibration-free mounting of cylindrical sensors Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 220357_eng.pdf OMH-04 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4 Ultrasonic sensor UB300-18GM40-E5-V1 Teach-In Adjusting the switching points The ultrasonic sensor features a switch output with two teachable switching points. These are set by applying the supply voltage -UB or +UB to the TEACH-IN input. The supply voltage must be applied to the TEACH-IN input for at least 1 s. LEDs indicate whether the sensor has recognised the target during the TEACH-IN procedure. Switching point A1 is taught with -UB, A2 with +UB. Five different output functions can be set 1. Window mode, normally-open function 2. Window mode, normally-closed function 3. one switching point, normally-open function 4. one switching point, normally-closed function 5. Detection of object presence TEACH-IN window mode, normally-open function • Set target to near switching point • TEACH-IN switching point A1 with -UB • Set target to far switching point • TEACH-IN switching point A2 with +UB TEACH-IN window mode, normally-closed function • Set target to near switching point • TEACH-IN switching point A2 with +UB • Set target to far switching point • TEACH-IN switching point A1 with -UB TEACH-IN switching point, normally-open function • Set target to near switching point • TEACH-IN switching point A2 with +UB • Cover sensor with hand or remove all objects from sensing range • TEACH-IN switching point A1 with -UB TEACH-IN switching point, normally-closed function • Set target to near switching point • TEACH-IN switching point A1 with -UB • Cover sensor with hand or remove all objects from sensing range • TEACH-IN switching point A2 with +UB TEACH-IN detection of objects presence • Cover sensor with hand or remove all objects from sensing range • TEACH-IN switching point A1 with -UB • TEACH-IN switching point A2 with +UB Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 220357_eng.pdf LED Displays Displays in dependence on operating mode TEACH-IN switching point: Object detected No object detected Object uncertain (TEACH-IN invalid) Normal operation Fault Red LED Yellow LED off flashes On off on flashes off off Switching state Previous state Installation Conditions If the sensor is installed at places, where the environment temperature can fall below 0 °C, for the sensors fixation, one of the mounting flanges BF18, BF18-F or BF 5-30 must be used. In case of direct mounting of the sensor in a through hole using the steel nuts, it has to be fixed at the middle of the housing thread. If a fixation at the front end of the threaded housing is required, plastic nuts with centering ring (accessories) must be used. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 5
UB300-18GM40-E5-V1 价格&库存
很抱歉,暂时无法提供与“UB300-18GM40-E5-V1”相匹配的价格&库存,您可以联系我们找货
