NMB5-18GM85-US-FE-V12
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    INDUCTIVE SEN 5MM NO
NMB5-18GM85-US-FE-V12 数据手册
Inductive sensor NMB5-18GM85-US-FE-V12 < < < < Stainless steel sensing face Sensing range 5 mm 2-wire AC/DC Ferrous targets 4 M18x1 2,5 Dimensions 90 13 LED 60 65 70 24 Release date: 2021-09-30 Date of issue: 2021-09-30 Filename: 900133_eng.pdf 1/2”-20 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance Two-wire sn Installation flush Output polarity Assured operating distance 5 mm AC/DC sa 0 ... 4.05 mm Actuating element Ferrous targets Reduction factor rAl 0 Reduction factor rCu 0 Reduction factor r304 0.4 - 0.7 Reduction factor rSt37 1 Reduction factor rBrass 0 Output type 2-wire Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NMB5-18GM85-US-FE-V12 Technical Data Nominal ratings Operating voltage DC UB 20 ... 300 V Operating voltage AC UB 20 ... 250 V Switching frequency f 15 Hz Hysteresis H 3 ... 15 typ. 5 % Reverse polarity protection yes Short-circuit protection yes Voltage drop Ud ≤7V Operating current IL 8 ... 200 mA Off-state current Ir ≤ 1.3 mA Error indicator LED, green/yellow (Alternate Flashing) - Short circuit/overload indication Functional safety related parameters MTTFd 950 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means Operation indicator Dual LED Green: power Yellow: output Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector plug 1/2"-20 UN , 3-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face Stainless steel 1.4305 / AISI 303 Degree of protection IP67 Release date: 2021-09-30 Date of issue: 2021-09-30 Filename: 900133_eng.pdf Connection 2 +/– 3 –/+ 1 Connection Assignment 1 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NMB5-18GM85-US-FE-V12 Wire colors 1 2 3 GN (green) RD/BK (red/black) RD/WH (red/white) Accessories Connecting cable, 1/2" - 20 UNF, 3-pin, irradiated PUR cable AB-18 Mounting aid Release date: 2021-09-30 Date of issue: 2021-09-30 Filename: 900133_eng.pdf V12-G-YE2M-PUR-H/S Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NMB5-18GM85-US-FE-V12 价格&库存
很抱歉,暂时无法提供与“NMB5-18GM85-US-FE-V12”相匹配的价格&库存,您可以联系我们找货
