CBB8-18GS75-E2-V1
CBB8-18GS75-E2-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    CAPACITIVE SEN 8MM PNP
CBB8-18GS75-E2-V1 数据手册
Capacitive sensor CBB8-18GS75-E2-V1 < 8 mm flush < The switching distance can be set over a wide range with the potentiometer Dimensions 72 53 4 0.5 M18 x 1 88.5 24 M12 x 1 Technical Data Release date: 2020-09-02 Date of issue: 2020-09-03 Filename: 237038_eng.pdf General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn 1 ... 8 mm Installation flush Output polarity DC Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 100 Hz Reverse polarity protection reverse polarity protected Short-circuit protection Voltage drop pulsing Ud Temperature drift ≤ 1.5 V max. 20 % at -5 ... 55 °C (23 ... 131 °F) Operating current IL 0 ... 100 mA No-load supply current I0 ≤ 18 mA Time delay before availability tv max. 300 ms Indicators/operating means Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Capacitive sensor CBB8-18GS75-E2-V1 Technical Data LED green Operating display LED yellow indication switching state Potentiometer sensitivity adjustment Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 85 °C (-13 ... 185 °F) Mechanical specifications Connection type Connector M12 x 1 , 3-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face PBT Degree of protection IP67 Connection 1 L+ 4 3 L- Connection Assignment 1 4 Release date: 2020-09-02 Date of issue: 2020-09-03 Filename: 237038_eng.pdf 3 Wire colors in accordance with EN 60947-5-2 1 3 4 BN BU BK (brown) (blue) (black) Accessories BF 18 Mounting flange, 18 mm V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Capacitive sensor CBB8-18GS75-E2-V1 Accessories Female cordset, M12, 4-pin, PUR cable Release date: 2020-09-02 Date of issue: 2020-09-03 Filename: 237038_eng.pdf V1-G-2M-PUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
CBB8-18GS75-E2-V1 价格&库存
很抱歉,暂时无法提供与“CBB8-18GS75-E2-V1”相匹配的价格&库存,您可以联系我们找货
