IQ08-02BPSKT0S
IQ08-02BPSKT0S
    SICK
    Module
    SENSOR PROX INDUCT 2MM IP68 MOD
IQ08-02BPSKT0S 数据手册
Product data sheet IQ08-02BPSKT0S IQY INDUCTIVE PROXIMITY SENSORS IQ08-02BPSKT0S | IQY INDUCTIVE PROXIMITY SENSORS A B C D E F Ordering information Type Part no. IQ08-02BPSKT0S 1055494 Other models and accessories www.sick.com/IQY Detailed technical data Features H I J K L M N O P Q R S T Housing Rectangular Dimensions (W x H x D) 8 mm x 40 mm x 8 mm Sensing range Sn 2 mm Safe sensing range Sa 1.62 mm Installation type Flush Switching frequency 2,000 Hz Connection type Connector M8, 3-pin Switching output PNP Output function NO Electrical wiring DC 3-wire Enclosure rating IP67, IP68 1) 1)  According to EN 60529. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC Ripple ≤ 10 % 1) Voltage drop ≤ 2 V 2) Current consumption 10 mA 3) Time delay before availability ≤ 100 ms Hysteresis 5 % ... 15 % Reproducibility ≤ 2 % 4) 5) 1) 2) 3) 4) 5) 2  Of VS.  At Ia max.  Without load.  Ub and Ta constant.  Of Sr. INDUCTIVE PROXIMITY SENSORS | SICK Product data sheet | 2021-07-21 16:50:03 Subject to change without notice IQ08-02BPSKT0S | IQY INDUCTIVE PROXIMITY SENSORS Temperature drift (of Sr) ± 10 % EMC According to EN 60947-5-2 Continuous current Ia ≤ 200 mA Short-circuit protection ✔ Reverse polarity protection ✔ Power-up pulse protection ✔ Shock and vibration resistance 30 g, 11 ms / 10 ... 55 Hz, 1 mm Ambient operating temperature –25 °C ... +75 °C Housing material Plastic, VISTAL® Sensing face material Plastic, VISTAL® Tightening torque, max. ≤ 1.5 Nm UL File No. NRKH.E348498 1) 2) 3) 4) 5)  Of VS.  At Ia max.  Without load.  Ub and Ta constant.  Of Sr. Safety-related parameters MTTFD 1,775 years DCavg 0 % Reduction factors Note The values are reference values which may vary Stainless steel (V2A, 304) Approx. 0.7 Aluminum (Al) Approx. 0.3 Copper (Cu) Approx. 0.2 Brass (Br) Approx. 0.3 Installation note Remark Associated graphic see "Installation" A 0 mm B 10 mm C 8 mm D 6 mm E 0 mm F 16 mm G 0 mm Classifications ECl@ss 5.0 27270101 ECl@ss 5.1.4 27270101 ECl@ss 6.0 27270101 ECl@ss 6.2 27270101 ECl@ss 7.0 27270101 2021-07-21 16:50:03 | Product data sheet  Subject to change without notice INDUCTIVE PROXIMITY SENSORS | SICK 3 IQ08-02BPSKT0S | IQY INDUCTIVE PROXIMITY SENSORS A B C D E F ECl@ss 8.0 27270101 ECl@ss 8.1 27270101 ECl@ss 9.0 27270101 ECl@ss 10.0 27270101 ECl@ss 11.0 27270101 ETIM 5.0 EC002714 ETIM 6.0 EC002714 ETIM 7.0 EC002714 ETIM 8.0 EC002714 UNSPSC 16.0901 39122230 Installation note A F A G E C B D H I J K L M N O P Q R S T G Connection diagram Cd-002 BN 1 BK 4 BU 4 3 + (L+) NO - (M) INDUCTIVE PROXIMITY SENSORS | SICK Product data sheet | 2021-07-21 16:50:03 Subject to change without notice IQ08-02BPSKT0S | IQY INDUCTIVE PROXIMITY SENSORS Dimensional drawing (Dimensions in mm (inch)) IQ08, connector 8.1 (0.32) 4.5 (0.18) (0.1) M3 3 49 (1.93) 3 40 (1.57) 20 (0.79) 10 (0.39) 8 (0.31)2 2.5 1 ①  Connection ②  LED indicator 270° ③  Threaded mounting hole M3 Recommended accessories Other models and accessories www.sick.com/IQY Brief description Type Part no. Head A: female connector, M8, 3-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 2 m YF8U13020VA1XLEAX 2095860 Head A: female connector, M8, 3-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m YF8U13050VA1XLEAX 2095884 Head A: female connector, M8, 3-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 2 m YG8U13020VA1XLEAX 2096165 Head A: female connector, M8, 3-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m YG8U13050VA1XLEAX 2096166 Head A: female connector, M8, 3-pin, straight Head B: Cable: unshielded DOS-0803-G 7902077 Head A: female connector, M8, 3-pin, angled Head B: Cable: unshielded DOS-0803-W 7902078 Plug connectors and cables 2021-07-21 16:50:03 | Product data sheet  Subject to change without notice INDUCTIVE PROXIMITY SENSORS | SICK 5 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
IQ08-02BPSKT0S 价格&库存
很抱歉,暂时无法提供与“IQ08-02BPSKT0S”相匹配的价格&库存,您可以联系我们找货
