NBB1.5-F79-E0
NBB1.5-F79-E0
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 1.5MM NPN
NBB1.5-F79-E0 数据手册
Inductive sensor NBB1,5-F79-E0 < Basic series < 1.5 mm flush < 3-wire DC Dimensions 4.7 4 2.6 5.6 8 16 7 4 8 Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 800000_eng.pdf Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance NPN sn Installation flush Output polarity Assured operating distance 1.5 mm DC sa 0 ... 1.215 mm Reduction factor rAl 0.3 Reduction factor rCu 0.2 Reduction factor r304 0.7 Nominal ratings Operating voltage UB 5 ... 30 V DC Switching frequency f 0 ... 1200 Hz Hysteresis H typ. 5 % Short-circuit protection Voltage drop pulsing Ud ≤ 1.5 V Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB1,5-F79-E0 Technical Data Operating current IL 0 ... 100 mA Off-state current Ir ≤ 10 µA No-load supply current I0 ≤ 15 mA Time delay before availability tv ≤ 20 ms Functional safety related parameters MTTFd 4830 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type flexible leads PVC , 500 mm Core cross-section 0.08 mm2 Housing material PA Sensing face PA Degree of protection IP67 Connection BN L+ BK BU Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 800000_eng.pdf L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBB1.5-F79-E0 价格&库存
很抱歉,暂时无法提供与“NBB1.5-F79-E0”相匹配的价格&库存,您可以联系我们找货
