Proximity Sensors Capacitive
LD™
E
I
H
Flat Pack Polycarbonate Housing
LES
P
I
TR
Type EC 5525, DC
• Featuring TRIPLESHIELD™ sensor protection
• Adjustable sensing distance 4-25 mm
• Rated operational voltage: 10-40 VDC
• Output: DC 200 mA, NPN or PNP
• Make and break switching function, LED indication
• Capacitive, Inductive and Photoelectric flat pack
series in PC housing, IP 67
• High noise immunity
• Universal flush and non-flush mountable
• Plug and cable versions
Product Description
Capacitive proximity switches
with sensing distance 16 mm
flush mounted and sensing
distance 25 mm non-flush
mounted by adjustment. 4wire DC output with both
make (NO) and break (NC)
Ordering Key
switching. Flat pack housing,
size (WxHxD) 35 x 55 x 15 mm
made in polycarbonate. Easy
mounting with only two M4
screws. Ideal for use in material handling and plastic machinery applications.
EC 55 25 NPA P-1
Housing
Rated operational distance
Output type
Housing material
Connection type
Type Selection
Housing
dimensions
WxHxD
Rated
operating dist.
(Sn)1)
Flush/non-flush
Ordering no.
Ordering no.
Ordering no.
Ordering no.
NPN/cable
NPN/plug
PNP/cable
PNP/plug
Make & break swit. Make & break swit. Make & break swit. Make & break swit.
35 x 55 x 15
16/25 mm
EC 5525 NPAP
1)
EC 5525 NPAP-1
EC 5525 PPAP
EC 5525 PPAP-1
Object: Grounded steel plate
Specifications
Rated operating dist. (Sn)
Sensitivity
Effective operating dist. (Sr)
Usable operating dist. (Su)
Repeat accuracy (R)
Hysteresis (H)
Rated operational volt. (UB)
Ripple
Rated operational current (Ie)
Continuous
No-load supply current (Io)
Voltage drop (Ud)
Protection
4 to 25 mm
factory set at 25 mm
Adj. 270° single turn pot.meter
0.9 x Sn ≤ Sr ≤ 1.1 x S
0.8 x Sr ≤ Sn > 1.2 x Sr
≤ 5%
3 to 20% of sensing distance
10 to 40 VDC (ripple incl.)
≤ 10%
≤ 200 mA
≤ 10 mA (no load)
≤ 2.5 VDC at max. load
Reverse polarity,
short-circuit, transients
Frequency of operating
cycles (f)
Indication for output ON
Environment
Degree of protection
Temperature
Operating temperature
Storage temperature
Housing material
Connection
Cable
Plug (-1)
Cable for plug (-1)
Weight (incl. nuts)
Approvals
CE-marking
Specifications are subject to change without notice (09.01.03)
50 Hz
LED, yellow
IP 67 (Nema 1, 3, 4, 6, 13)
-25 to +80°C ( -13 to +176°F)
-40 to +85°C (-40 to +185°F)
Polycarbonate (PC), grey
Grey, 2 m, 4 x 0.34 mm2
Oil proof, PVC
M12 x 1
CON.1A-series
125 g (cable version)
40 g (plug version)
UL, CSA
Yes
1
EC 5525, DC
Dimensions
35
35
57.5
4.5 3.5
4.5 3.5
Ø7.5
7
4.5
12
7
18
4.5
15
55
57.5
55
15
M12x1 plug
Ø6.8
24.5
Ø5.2
24.5
Ø3
Ø3
9.5
EC 5525 .PAP
9.5
LED
LED
Potentiometer
EC 5525 .PAP-1
Potentiometer
Wiring Diagrams
1 BN
1 BN
4 BK
2 WH
2 WH
4 BK
3 BU
NPN
3 BU
PNP
Adjustment Guide
The environments in which capacitive sensors are installed can
often be unstable regarding temperature, humidity, object distance
and industrial (noise) interference.
Because of this, Carlo Gavazzi
offers as standard features in all
TRIPLESHIELD™ capacitive sensors a user-friendly sensitivity
adjustment instead of having a
fixed sensing range, extended
sensing range to accommodate
mechanically demanding areas,
temperature stability to ensure
minimum need for adjusting sensitivity if temperature varies and
high immunity to electromagnetic
interference (EMI).
Sensitivity
adjustment
LED
Note:
Sensors are factory set (default)
to maximum rated sensing range.
Installation Hints
Capacitive sensors have the
unique ability to detect almost all
materials, either in liquid or solid
form. Capacitive sensors can
detect metallic as well as nonmetallic objects, however, their
traditional use is for non-metallic
materials such as:
• Wood Industry
Saw dust, paper products,
door and window frames.
• Plastic Industry
Resins, regrinds or moulded
products.
• Ceramic & Glass Industry
Raw material, clay or finished
products, bottles.
2
• Chemical Industry
Cleansers, fertilisers, liquid
soaps, corrosives and petrochemicals.
• Packaging Industry Package inspection for level or
contents, dry goods, fruits
and vegetables, dairy products.
for a capacitive sensor is referenced to a grounded metal plate
(ST37). For additional information
regarding dielectric ratings of
materials
please
refer
to
Technical Information.
Materials are detected due to
their dielectric constant. The bigger the size of an object, the
higher the density of material, the
better or easier it is to detect the
object. Nominal sensing distance
EC 5525, DC
Installation Hints (cont.)
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
Delivery Contents
Accessories
• Plugs CON.1A.. serie
Capacitive switch: EC55.. PAP(-1)
Screw driver
Packaging: Cardboard box
Installation & Adjustment Guide
For further information refer to “Accessories”.
3
很抱歉,暂时无法提供与“EC5525PPAP-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2807.084401+363.61561
- 5+2666.732315+345.43510
- 10+2582.5240510+334.52719
- 25+2498.3127925+323.61889
