Proximity Sensors Inductive
Stainless Steel Housing
Types EI, AC, M12, M18, M30
• Stainless steel housing, cylindrical
• Diameter: M12, M18, M30
• Sensing distance: 2 to 15 mm
• Power supply: 20 to 250 VAC
• Output: SCR, make or break switching
• Protection: Overvoltage
• LED-indication for output ON
• Long or short housing
• 2 m cable or plug M12 (double keyed)
Product Description
Ordering Key
AC proximity switches constructed in stainless steel
(1.4301) housings. Sizes available are M12, M18 and M30.
Length of housing is selectable with 30 mm thread or 50
Type
Housing diameter (mm)
Rated operating dist. (mm)
Output type
Housing material
Body style
Plug
mm thread. Bright LED ring
utilizing a yellow LED clearly
gives indication of output status. Protection rating IP 67
ensures environmental compatibility.
EI 1202 TBOSL-6
Type Selection AC Types, Cable and M12 Plug
Housing
diameter
Body
style
Connection
Rated
operating
dist. (Sn)
Ordering no.
SCR
Make switching
Ordering no.
SCR
Break switching
M12
M12
M12
M12
Long
Long
Long
Long
Cable
Plug
Cable
Plug
2 mm 1)
2 mm 1)
4 mm 2)
4 mm 2)
EI 1202 TBOSL
EI 1202 TBOSL-6
EI 1204 TBOSL
EI 1204 TBOSL-6
EI 1202 TBCSL
EI 1202 TBCSL-6
EI 1204 TBCSL
EI 1204 TBCSL-6
M18
M18
M18
M18
M18
M18
M18
M18
Short
Short
Long
Long
Short
Short
Long
Long
Cable
Plug
Cable
Plug
Cable
Plug
Cable
Plug
5 mm 1)
5 mm 1)
5 mm 1)
5 mm 1)
8 mm 2)
8 mm 2)
8 mm 2)
8 mm 2)
EI 1805 TBOSS
EI 1805 TBOSS-6
EI 1805 TBOSL
EI 1805 TBOSL-6
EI 1808 TBOSS
EI 1808 TBOSS-6
EI 1808 TBOSL
EI 1808 TBOSL-6
EI 1805 TBCSS
EI 1805 TBCSS-6
EI 1805 TBCSL
EI 1805 TBCSL-6
EI 1808 TBCSS
EI 1808 TBCSS-6
EI 1808 TBCSL
EI 1808 TBCSL-6
M30
M30
M30
M30
M30
M30
M30
M30
Short
Short
Long
Long
Short
Short
Long
Long
Cable
Plug
Cable
Plug
Cable
Plug
Cable
Plug
10 mm 1)
10 mm 1)
10 mm 1)
10 mm 1)
15 mm 2)
15 mm 2)
15 mm 2)
15 mm 2)
EI 3010 TBOSS
EI 3010 TBOSS-6
EI 3010 TBOSL
EI 3010 TBOSL-6
EI 3015 TBOSS
EI 3015 TBOSS-6
EI 3015 TBOSL
EI 3015 TBOSL-6
EI 3010 TBCSS
EI 3010 TBCSS-6
EI 3010 TBCSL
EI 3010 TBCSL-6
EI 3015 TBCSS
EI 3015 TBCSS-6
EI 3015 TBCSL
EI 3015 TBCSL-6
Short = 30 mm thread
Long = 50 mm thread
Make switching = Normally Open (NO)
Break switching = Normally Closed (NC)
1)
2)
For flush mounting in metal
For non-flush mounting in metal
Specifications are subject to change without notice (20.08.01)
1
Specifications
Rated operational volt. (Ue)
(UB)
Rated operational current (Ie)
Continuous
Short-time
Minimum load current
OFF-state current (Ir)
Voltage drop (Ud)
Protection
Transient voltage
Power ON delay
Frequency of operating
cycles (f)
Indication for output ON
Assured operating dist. (Sa)
Repeat accuracy (R)
Hysteresis (H) (Differential travel)
Effective operating dist. (Sr)
24 to 240 VAC,
20 to 265 VAC, 50 to 60 Hz
10 - 500 mA
≤ 2.5 A, max. 20 ms
10 mA
≤ 2 mA
≤ 8 VAC at max. load
Transients
Level 3, 2.5 kV,
acc. to IEC 60255-5
(500 Ω, 0.5 J) (prepared)
≤ 100 ms
25 Hz
LED, yellow
0 ≤ Sa ≤ 0.81 Sn
≤ 5%
3 to 20% of sensing distance
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
0.9 x Sr ≤ Su ≤ 1.1 x Sr
Usable operating dist. (S)
Ambient temperature
Operating
Storage
Degree of protection
Housing material
Body
Front
Back
Connection
Cable
-25° to +70°C (-13° to +158°F)
-30° to +80°C (-22° to +176°F)
IP 67 (Nema 1, 3, 4, 6, 13)
Stainless steel (1.4301)
Grey thermoplastic polyester
Black thermoplastic polyester
2 m, 2 x 0.50 mm2,
grey PVC, oil proof
M12 x 1 (double keyed)
CONH6A-xx
EI 12
80 g
EI 18
130 g
EI 30
200 g
EI 12
7.5 Nm (x)
17.5 Nm (y)
EI 18 27.5 Nm
EI 30 100.0 Nm
UL, CSA
Yes
Plug
Cables for plug (-6)
Weight (cable excluded)
Tightening torque
Approvals
CE-marking
Dimensions
Type
EI 1202 TB..L
EI 1202 TB..L-6
EI 1204 TB..L
EI 1204 TB..L-6
EI 1805 TB..S
EI 1805 TB..S-6
EI 1805 TB..L
EI 1805 TB..L-6
EI 1808 TB..S
EI 1808 TB..S-6
EI 1808 TB..L
EI 1808 TB..L-6
A
B
mm
C
mm
66
74.5
70
78.5
57
55
77
75
65
63
85
83
4
8
8
8
M 12 x 1 x 50
M 12 x 1 x 50
M 12 x 1 x 50
M 12 x 1 x 50
M 18 x 1 x 30
M 18 x 1 x 30
M 18 x 1 x 50
M 18 x 1 x 50
M 18 x 1 x 30
M 18 x 1 x 30
M 18 x 1 x 50
M 18 x 1 x 50
Type
EI 3010 TB..S
EI 3010 TB..S-6
EI 3010 TB..L
EI 3010 TB..L-6
EI 3015 TB..S
EI 3015 TB..S-6
EI 3015 TB..L
EI 3015 TB..L-6
A
B
mm
C
mm
59
55.5
79
75.5
87.5
67.5
91
71
12
12
12
M 30 x 1.5 x 30
M 30 x 1.5 x 30
M 30 x 1.5 x 50
M 30 x 1.5 x 50
M 30 x 1.5 x 30
M 30 x 1.5 x 30
M 30 x 1.5 x 50
M 30 x 1.5 x 50
A
A
3
1
2
M12x1
B
Cable type
2
C
LED
B
C
LED
Plug type
Installation Hints
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
Wiring Diagrams
Power Supplies
Power supplies VAC:
2 BN
2 BN
3 BU
3 BU
TBCS
> SS 110
TBOS
3
很抱歉,暂时无法提供与“EI1805TBCSS”相匹配的价格&库存,您可以联系我们找货
