Proximity Sensors Inductive
Long Body, Stainless Steel
Types IA, M8
• Miniature stainless steel housing
(cable or M8/M12 plug)
• Long body
• Sensing distance: 1,5 mm or 2,5 mm
• Power supply: 10 to 30 VDC
• Output: Transistor NPN/PNP, normally open or normally
closed
• Protection: Short-circuit
• LED-indication for output ON
• 2 m PVC cable, M8 or M12 plug
Product Description
Ordering Key IA 08 BLF 15 NO M5
Inductive
with long
figuration
both NO
Type: Ind. prox. switch
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
Connection
proximity sensor
body. Output confor NPN/PNP with
and NC types as
standard. M8 stainless steel
housing with 2 m PVC cable
or M8/M12 plug.
Type Selection
Rated
Conn.
operating type
dist. (Sn)
Ordering no.
Transistor PNP
Normally open
Ordering no.
Transistor PNP
Normally closed
1.5 mm 1) Cable
IA 08 BLF 15 NO
IA 08 BLF 15 NC
1.5 mm 1) Plug M8 IA 08 BLF 15 NO M5
IA 08 BLF 15 PO
IA 08 BLF 15 PO M5
IA 08 BLF 15 PC
IA 08 BLF 15 PC M5
Cable
IA 08 BLN 25 NO
IA 08 BLN 25 NC
Plug M8 IA 08 BLN 25 NO M5
IA 08 BLN 25 PO
IA 08 BLN 25 PO M5
IA 08 BLN 25 PC
IA 08 BLN 25 PC M5
IA 08 BLF 15 PO M1
IA 08 BLN 25 PO M1
IA 08 BLF 15 PC M1
IA 08 BLN 25 PC M1
2.5 mm
2.5 mm
Ordering no.
Transistor NPN
Normally open
1.5 mm 1) Plug M12 IA 08 BLF 15 NO M1
2.5 mm Plug M12 IA 08 BLN 25 NO M1
1)
Ordering no.
Transistor NPN
Normally closed
IA 08 BLF 15 NC M1
IA 08 BLN 25 NC M1
For flush mounting in metal
Specifications
Rated operational volt. (UB) 10 to 30 VDC (ripple included)
Ripple ≤ 10%
Rated operational current (Ie)
Continuous ≤ 200 mA @ + 25°C (+75°F)
No-load supply current (Io) ≤ 10 mA (ON)
Voltage drop (Ud) < 2,5 V (@ Imax)
Protection Short circuit
Frequency of operating
cycles (f) 2000 Hz
Indication for output ON LED, yellow
Repeat Accuracy ≤ 5%
Effective operating dist. (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn
Usable operating dist. (Su) 0.85 x Sr ≤ Su ≤ 1.15 x Sr
Specifications are subject to change without notice (20.02.18)
Ambient temperature
Operating -25° to +70°C (-13° to +158°F)
Storage -30° to +75°C (-22° to +167°F)
Degree of protection IP 67 (Nema 1, 3, 4, 6, 13)
Housing material Stainless steel, AISI 303
CE-marking Yes
Connection
IA08BL....O/C Cable, 2 m, PVC, AWG 26,
oil proof
IA08BL....O/C M5 Plug M8, CONB53 series
IA08BL....O/C M1 Plug M12, CONB1 series
Weight (cables/nuts included) AI...
36 g
AI...M1/M5
11 g
1
IA, M8
Dimensions
4
1
4
1
3
4
1
3
4
1
3
2
M8 x 1 x 43
42
.. ..BLF15..
45
37
60
60
4 x LED
4 x LED
LED
M8 x 1
M8 x 1
.. ..BLN25..
.. ..BLF15..M5
.. ..BLN25..M5
LED
3
3
40
45
M8 x 1 x 40
M8 x 1
M8 x 1
M8 x 1
M8 x 1
3
2
4 x LED
70
70
4 x LED
M12 x 1
M12 x 1
.. ..BLF15..M1
.. ..BLN25..M1
Wiring Diagrams
IA08BL..... - IA08BL.....M5
1 BN
1 BN
1 BN
1 BN
4 BK
4 BK
4 BK
4 BK
3 BU
3 BU
NPN - Normally open
3 BU
NPN - Normally closed
3 BU
PNP - Normally open
PNP - Normally closed
IA08BL.....M1
1 BN
1 BN
1 BN
1 BN
4 BK
2 BK
2 BK
4 BK
3 BU
3 BU
NPN - Normally open
3 BU
3 BU
PNP - Normally open
Installation Hints
To avoid interference from inductive voltage/
current peaks, separate the prox. switch
power cables from any other power cables,
e.g. motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
2
很抱歉,暂时无法提供与“IA08BLF15NO”相匹配的价格&库存,您可以联系我们找货
