NJ2-F-E02-1.025-V1
NJ2-F-E02-1.025-V1
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN CYLINDER POSITION
NJ2-F-E02-1.025-V1 数据手册
Inductive sensor NJ2-F-E02-1.025-V1 < < < < 4-wire DC Weld Immune Sensing range 2 mm 1000 psi rating Cylinder Position Switch Dimensions LEDs Ø48 35 2x Ø6.5 38 M12 x 1 Ø25 34.5 26.5 7 "X" Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 904474_eng.pdf Ø11.5 Technical Data General specifications Switching function Normally open (NO) Output type PNP/NPN Rated operating distance sn 2 mm Installation flush Output polarity DC Assured operating distance sa 0 ... 1.62 mm Reduction factor rAl 0.4 Reduction factor r304 0.85 Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 30 Hz Hysteresis H 10 ... 20 typ. 15 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NJ2-F-E02-1.025-V1 Technical Data Reverse polarity protection yes Short-circuit protection yes Voltage drop Ud ≤ 2 V DC Operating current IL ≤ 200 mA Off-state current Ir ≤ 100 µA No-load supply current I0 ≤ 35 mA Mag. Field strength, AC fields 250 mT Mag. Field strength, DC fields 100 mT Limit data Operating pressure dynamically 1000 psi Indicators/operating means LED green Power on LED yellow Output status Standard conformity Standards EN 60947-5-2 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector M12 x 1 , 4-pin Degree of protection IP67 Material Housing: zinc Probe: aluminum Note X = 1.025 in (26 mm) Connection 1 L+ 4 2 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 904474_eng.pdf 3 L- Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NJ2-F-E02-1.025-V1 Additional Information NPT Type Mounting Holes: 1000 and 3000 psi NPT Types: Mounting hole screw thread shall be 1/4" - 20. Minimum thread engagement depth is 0.250" (6.35 mm) Hole spacing is 35 mm center to center. Sensor through-hole Mounting hole (x2) Mounting hole spacing Cylinder End-Cap Overhead View Mounting Screws: Standard 1000 and 3000 psi models use two, self-locking 1/4"- 20 socket head cap screws (provided). Recommended tightening torque: 150 in lb (16.95 N-m). Important: When using spacers, make certain to maintain the 0.250" (6.35 mm) minimum mounting screw thread engagement. Accessories V1-G-2M-PVC Female cordset, M12, 4-pin, PVC cable SPACER 0.160 TO 0.375 : Spacer for cylinder switches X.XXX" Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 904474_eng.pdf SPACER 0.380 TO 0.875 : Spacer for cylinder switches X.XXX" Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NJ2-F-E02-1.025-V1 价格&库存
很抱歉,暂时无法提供与“NJ2-F-E02-1.025-V1”相匹配的价格&库存,您可以联系我们找货
