NMB15-30GM65-E2-V1
NMB15-30GM65-E2-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M30
    INDUCTIVE SEN 15MM PNP
NMB15-30GM65-E2-V1 数据手册
Inductive sensor NMB15-30GM65-E2-V1 < 15 mm flush < Stainless steel sensing face < Increased operating distance Dimensions 36 65 50 55 40 5 2.5 M30 x 1.5 LED M12 x 1 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 911274_eng.pdf Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation flush (Requirements: see drawing below) Output polarity Assured operating distance 15 mm DC sa 0 ... 12.15 mm Actuating element Ferrous and nonferrous targets Reduction factor rAl 0.4 Reduction factor rCu 0.2 Reduction factor r304 0.85 Reduction factor rSt37 1 Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 150 Hz Hysteresis H 3 ... 15 typ. 10 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NMB15-30GM65-E2-V1 Technical Data Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤2V Operating current IL ≤ 200 mA Off-state current Ir ≤ 10 µA No-load supply current I0 ≤ 15 mA Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 893 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector M12 x 1 , 4-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face Stainless steel 1.4305 / AISI 303 Degree of protection IP67 / IP68 / IP69K - cordset dependent according to cable specification Connection 1 L+ 4 3 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 911274_eng.pdf L- Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NMB15-30GM65-E2-V1 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Mounting ≥ 82° Mild Steel 30 ≥4 Sensor face is flush with mounting surface. Accessories Female cordset, M12, 4-pin, PUR cable V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable AB-30 Mounting aid Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 911274_eng.pdf V1-G-2M-PUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NMB15-30GM65-E2-V1 价格&库存
很抱歉,暂时无法提供与“NMB15-30GM65-E2-V1”相匹配的价格&库存,您可以联系我们找货
