NEB6-12GM50-E2-V1
NEB6-12GM50-E2-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M12
    INDUCTIVE SEN 6MM PNP
NEB6-12GM50-E2-V1 数据手册
Inductive sensor NEB6-12GM50-E2-V1 < Increased operating distance < 6 mm quasi flush Dimensions 60 49.5 58 4 M12 x 1 17 LED ø 10.5 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 231715_eng.pdf Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation quasi flush Output polarity Assured operating distance 6 mm DC sa 0 ... 4.8 mm Actuating element mild steel, e. g. 1.0037, SR235JR (formerly St37-2) 18 mm x 18 mm x 1 mm Reduction factor rAl 0.28 Reduction factor rCu 0.2 Reduction factor r304 0.7 Reduction factor rBrass 0.35 Nominal ratings Installation conditions A in steel 1.0037 (St37): 2.4 mm in other metal: 1.2 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NEB6-12GM50-E2-V1 Technical Data B 12 mm C 18 mm F 24 mm Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 800 Hz Hysteresis H 0.06 ... 1.2 mm Reverse polarity protection yes Short-circuit protection pulsing Overload resistance yes Wire breakage protection yes Surge suppression yes Ripple 10 % Voltage drop Ud ≤2V Repeat accuracy R 0.3 mm Operating current IL 0 ... 200 mA , above 70°C max. 150 mA Off-state current Ir ≤ 10 µA No-load supply current I0 ≤ 15 mA Time delay before availability tv ≤ 50 ms Switching state indicator LED, yellow Functional safety related parameters MTTFd 1740 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates EAC conformity TR CU 020/2011 UL approval cULus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 85 °C (-13 ... 185 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 231715_eng.pdf Mechanical specifications Connection type Connector M12 x 1 , 4-pin Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Mass 20 g Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NEB6-12GM50-E2-V1 Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Installation B F A sensing face C metal-free zone support Accessories Mounting flange, 12 mm V1-G-2M-PUR Female cordset, M12, 4-pin, PUR cable V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 231715_eng.pdf BF 12 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NEB6-12GM50-E2-V1 价格&库存
很抱歉,暂时无法提供与“NEB6-12GM50-E2-V1”相匹配的价格&库存,您可以联系我们找货
