NBN40-L3M-A2-C3-V1
NBN40-L3M-A2-C3-V1
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 40MM PNP
NBN40-L3M-A2-C3-V1 数据手册
Inductive sensor NBN40-L3M-A2-C3-V1 < < < < < 40 mm non-flush 4-wire DC Weld Immune Active surface thermoset 2-way LED indicator Dimensions LED gn LED ye 7 M12 x 1 20 30 28 LED ye 67 40 40 28 8 46 ø 5.5 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 183739_eng.pdf 60 Technical Data General specifications Switching function complementary Output type Rated operating distance PNP sn Installation 40 mm non-flush Output polarity DC Assured operating distance sa 0 ... 32.4 mm Actual operating distance sr 36 ... 44 mm Reduction factor rAl 0.35 Reduction factor rCu 0.3 Reduction factor r304 0.73 Reduction factor rBrass 0.43 Output type 4-wire Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBN40-L3M-A2-C3-V1 Technical Data Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 5 Hz Hysteresis H typ. 5 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA No-load supply current I0 ≤ 20 mA Time delay before availability tv 80 ms Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 1190 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 85 °C (-13 ... 185 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Mechanical specifications Connection type Connector plug M12 x 1 , 4-pin Housing material GD-ZnAl4Cu1, Coated metal fixing flange, coated. Sensing face Duroplast Degree of protection IP67 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 183739_eng.pdf Connection 1 L+ 4 2 3 L- Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBN40-L3M-A2-C3-V1 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Accessories Female cordset, M12, 4-pin, PUR cable V1-G-2M-PUR Female cordset, M12, 4-pin, PUR cable MHW 01 Modular mounting bracket MH 02-L Mounting aid Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 183739_eng.pdf V1-W-2M-PUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBN40-L3M-A2-C3-V1 价格&库存
很抱歉,暂时无法提供与“NBN40-L3M-A2-C3-V1”相匹配的价格&库存,您可以联系我们找货
