ICB18L50N14NO
ICB18L50N14NO
    CARLOGAVAZZI
    Cylinder,Threaded-M18
    SENSOR PROX INDUCTIVE 14MM CYL
ICB18L50N14NO 数据手册
ICB, M18 Proximity Inductive Sensors Extended Range, Nickel-Plated Brass Housing Types ICB, M18 • Sensing distance: 8 to 14 mm • Flush or non-flush types • Short or long body versions • Rated operational voltage (Ub): 10 - 36 VDC • Output: DC 200 mA, NPN or PNP • Normally open or Normally closed • LED indication for output ON • Protection: reverse polarity, short circuit, transients • Cable or M12 plug versions • According to IEC 60947-5-2 • Laser engraved on front cap, permanently legible • CSA certified for Hazardous Locations Ordering Key Product Description A family of inductive proximity switches in industrial standard nickel-plated brass housings. They are able to handle applications where high sensing range is requested. Output is open collector NPN or PNP transistors. Type Housing style Housing material Housing size Housing length Thread length Detection principle Sensing distance Output type Output configuration Connection ICB18S30F08NOM1 Type Selection Connec- Body tion style Rated operating distance Sn Ordering no. NPN, Normally open Cable Cable Plug Plug Cable Cable Plug Plug 8 mm 1) 14 mm 2) 8 mm 1) 14 mm 2) 8 mm 1) 14 mm 2) 8 mm 1) 14 mm 2) ICB18S30F08NO ICB18S30F08PO ICB18S30N14NO ICB18S30N14PO ICB18S30F08NOM1 ICB18S30F08POM1 ICB18S30N14NOM1 ICB18S30N14POM1 ICB18L50F08NO ICB18L50F08PO ICB18L50N14NO ICB18L50N14PO ICB18L50F08NOM1 ICB18L50F08POM1 ICB18L50N14NOM1 ICB18L50N14POM1 1) Short Short Short Short Long Long Long Long For flush mounting in metal 2) Ordering no. PNP, Normally open Ordering no. NPN, Normally closed Ordering no. PNP, Normally closed ICB18S30F08NC ICB18S30F08PC ICB18S30N14NC ICB18S30N14PC ICB18S30F08NCM1 ICB18S30F08PCM1 ICB18S30N14NCM1 ICB18S30N14PCM1 ICB18L50F08NC ICB18L50F08PC ICB18L50N14NC ICB18L50N14PC ICB18L50F08NCM1 ICB18L50F08PCM1 ICB18L50N14NCM1 ICB18L50N14PCM1 For non-flush mounting in metal Specifications Rated operational voltage (Ub) 10 to 36 VDC (ripple incl.) Ripple ≤ 10% Output current (Ie) ≤ 200 mA @ 50°C (≤ 150 mA @ 50-70°C) OFF-state current (Ir) ≤ 50 μA No load supply current (Io) ≤ 15 mA Voltage drop (Ud) Max. 2.5 VDC @ 200 mA Protection Reverse polarity, short-circuit, transients Voltage transient 1 kV/0.5 J Power ON delay (tv) ≤ 20 ms Operating frequency (f) ≤ 1500 Hz Indication for output ON Activated LED, yellow NO version Target present NC version Target not present Indication for short circuit/ overload LED blinking (f = 2 Hz) Assured operating sensing distance (Sa) 0 ≤ Sa ≤ 0.81 x Sn Effective operating distance (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operating distance (Su) 0.9 x Sr ≤ Su ≤ 1.1 x Sr Repeat accuracy (R) ≤ 10% Differential travel (H) (Hysteresis) 1 to 20% of sensing dist. Ambient temperature Operating -25° to +70°C (-13° to +158°F) Storage -30° to +80°C (-22° to +176°F) Shock and vibration IEC 60947-5-2/7.4 Housing material Body Nickel-plated brass Front Grey thermoplastic polyester Specifications are subject to change without notice (16.01.2017) 1 ICB, M18 Specifications (cont.) Connection Cable Plug Degree of protection Weight (cable/nuts included) Cable Plug Dimensions Tightening torque Non-flush version Flush version From 0 to 7 mm > 7 mm Approvals cULus cCSAus Note: The terminal connector (version ...M1) was not evaluated. The suitability of the terminal connector should be determined in the end-use application. Ø4.1 x 2 m, 3 x 0.25 mm2, grey PVC, oil proof M12 x 1 IP 67 Approvals (cont.) EMC protection IEC 61000-4-2 (ESD) IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-6 IEC 61000-4-8 MTTFd Max. 150 g Max. 70 g See diagrams below 25 Nm 20 Nm 25 Nm (UL508) Ambient temperature Ta: -25° to +60°C CCC is not required for products with a maximum operating voltage of ≤ 36 V According to IEC 60947-5-2 8 KV air discharge, 4 KV contact discharge 3 V/m 2 kV 3V 30 A/m 850 years @ 50°C (122°F) As Process Control Equipment for Hazardous Locations. - Class I, Division 2, Groups A, B, C and D. - T5 up to 150mA, T4A for a load current > 150mA and up to 200 mA, Enclosure Type 4. Dimensions (mm) LED M18x1 30.0 20.1 10.0 30.0 53.0 20.1 63.0 Short body, flush version, cable Short body, non-flush version, cable LED (4 x 90°) 4 3 1 2 30.0 10.0 54.0 3 1 2 30.0 Short body, non-flush version, plug LED 7.5 LED M18x1 M18x1 4 64.0 Short body, flush version, plug 7.5 LED (4 x 90°) 7.5 M18x1 M18x1 7.5 50.0 10.0 73.1 Long body, flush version, cable 2 LED 7.5 M18x1 7.5 50.0 83.1 Long body, non-flush version, cable Specifications are subject to change without notice (16.01.2017) ICB, M18 Dimensions (mm) (cont.) LED (4 x 90°) 4 3 1 2 50.0 LED (4 x 90°) 7.5 M18x1 M18x1 7.5 10.0 4 3 1 2 50.0 74.0 84.0 Long body, flush version, plug Long body, non-flush version, plug Installation Flush sensor, when installed in damping material, must be according to Picture 1A. Picture 1A Non-flush sensor, when installed in damping material, must be according to Picture 1B. Picture 1B ≥ 3 x Sn Free zone or non-damping material Free zone or non-damping material ≥3xd d ≥ 3 x Sn ≥ 2 x Sn d Sn : nominal sensing distance d : sensor diameter (18 mm) Sn : nominal sensing distance d : sensor diameter (18 mm) Flush sensors, when installed together in damping material, must be according to Picture 2A. Picture 2A Non-flush sensors, when installed together in damping material, must be according to Picture 2B. Picture 2B d d d d : sensor diameter (18 mm) d d 2xd d d d : sensor diameter (18 mm) For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed (See Picture 3). Picture 3 ≥ 6 x Sn Sn : nominal sensing distance Specifications are subject to change without notice (16.01.2017) 3 ICB, M18 Wiring Diagram 1 BN + 1 BN + 1 BN + 1 BN + 4 BK 2 BK 2 BK 4 BK 3 BU 3 BU - NPN - Normally open - NPN - Normally closed Reduction Factors The rated operating distance is reduced by the use of metals and alloys other than Fe360. Picture 4 3 BU PNP - Normally open - 3 BU - PNP - Normally closed Accessories for Plug Versions The most important reduction factors for inductive proximity sensors are shown in Picture 4. Fe360 : Steel CrNi : Chrome-nickel CuZn : Brass Al : Aluminium Cu : Copper Sr : Effective operating distance 3-wire angled connector, 2 m cable 3-wire angled connector, 5 m cable 3-wire angled connector, 10 m cable 3-wire angled connector, 15 m cable 3-wire straight connector, 2 m cable 3-wire straight connector, 5 m cable 3-wire straight connector, 10 m cable 3-wire straight connector, 15 m cable PVC PUR CONB13NF-A2 CONB13NF-A2P CONB13NF-A5 CONB13NF-A5P CONB13NF-A10 CONB13NF-A10P CONB13NF-A15 CONB13NF-A15P CONB13NF-S2 CONB13NF-S2P CONB13NF-S5 CONB13NF-S5P CONB13NF-S10 CONB13NF-S10P CONB13NF-S15 CONB13NF-S15P For any additional information or different options, please refer to the “General Accessories Connector Cables -Type CONB1...” datasheets. Delivery Contents • Inductive proximity switch ICB. • 2 nuts NPB • Packaging: plastic bag 4 Specifications are subject to change without notice (16.01.2017)
ICB18L50N14NO 价格&库存
很抱歉,暂时无法提供与“ICB18L50N14NO”相匹配的价格&库存,您可以联系我们找货
