S-8244AARFN-CERT2U
S-8244AARFN-CERT2U
    ABLIC(艾普凌科)
    LSSOP8
    IC BATT PROT LI-ION 1-4CEL 8MSOP
S-8244AARFN-CERT2U 数据手册
S-8244 Series www.ablic.com BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) © ABLIC Inc., 2003-2020 Rev.7.1_00 The S-8244 Series is used for secondary protection of lithium-ion batteries with from one to four cells, and incorporates a high-precision voltage detector circuit and a delay circuit. Short-circuiting between cells makes it possible for serial connection of one to four cells.  Features (1) Internal high-precision voltage detector circuit • Overcharge detection voltage range: 3.700 V to 4.550 V: Accuracy of ± 25 mV (at +25°C) (at a 5 mV/step) Accuracy of ± 50 mV (at −40°C to +85°C) • Hysteresis: 5 types 0.38 ± 0.1 V, 0.25 ± 0.07 V, 0.13 ± 0.04 V, 0.045 ± 0.02 V, None (2) High-withstand voltage: Absolute maximum rating: 26 V (3) Wide operating voltage range: 3.6 V to 24 V (refers to the range in which the delay circuit can operate normally after overvoltage is detected) (4) Delay time during detection: Can be set by an external capacitor. (5) Low current consumption: At 3.5 V for each cell: 3.0 μA max. (+25°C) At 2.3 V for each cell: 2.4 μA max. (+25°C) (6) Output logic and form: 5 types CMOS output active “H” CMOS output active “L” Pch open drain output active “L” Nch open drain output active “H” Nch open drain output active “L” (CMOS / Nch open drain output for 0.045 V hysteresis models) (7) Lead-free (Sn 100%), halogen-free  Applications • Lithium ion rechargeable battery packs (secondary protection)  Packages • SNT-8A • TMSOP-8 1 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00  Block Diagram VCC SENSE Overcharge detection comparator 1 + - Reference voltage 1 VC1 Overcharge detection delay circuit Overcharge detection comparator 2 ICT + - Control logic Reference voltage 2 VC2 Overcharge detection comparator 3 + - CO Reference voltage 3 VC3 Overcharge detection comparator 4 + - Reference voltage 4 VSS Remark In the case of Nch open-drain output, only the Nch transistor will be connected to the CO pin. In the case of Pch open-drain output, only the Pch transistor will be connected to the CO pin. Figure 1 2 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) Rev.7.1_00 S-8244 Series  Product Name Structure 1. Product Name S-8244A xx xx - xxx xx U Environmental code U: Lead-free (Sn 100%), halogen-free IC direction of tape specifications*1 TF: SNT-8A T2: TMSOP-8 Product code*2 Package abbreviation PH: SNT-8A FM: TMSOP-8 Serial code Sequentially set from AA to ZZ *1. *2. Refer to the tape drawing. Refer to “3. Product Name List”. 2. Packages Package name SNT-8A TMSOP-8 Package PH008-A-P-SD FM008-A-P-SD Drawing code Tape Reel PH008-A-C-SD PH008-A-R-SD FM008-A-C-SD FM008-A-R-SD Land PH008-A-L-SD ⎯ 3 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00 3. Product Name List (1) SNT-8A Table 1 Product name S-8244AAAPH-CEATFU S-8244AABPH-CEBTFU S-8244AADPH-CEDTFU S-8244AAFPH-CEFTFU S-8244AAGPH-CEGTFU S-8244AAJPH-CEJTFU S-8244AASPH-CESTFU S-8244AATPH-CETTFU S-8244AAVPH-CEVTFU S-8244AAYPH-CEYTFU S-8244AAZPH-CEZTFU S-8244ABBPH-CFBTFU S-8244ABDPH-CFDTFU S-8244ABEPH-CFETFU S-8244ABHPH-CFHTFU S-8244ABMPH-CFMTFU Overcharge detection voltage Overcharge hysteresis voltage [VCU] [VCD] 4.450 ± 0.025 V 0.38 ± 0.1 V 4.200 ± 0.025 V 0V 4.200 ± 0.025 V 0V 4.350 ± 0.025 V 0.045 ± 0.02 V 4.450 ± 0.025 V 0.045 ± 0.02 V 4.500 ± 0.025 V 0.38 ± 0.1 V 4.350 ± 0.025 V 0.38 ± 0.1 V 4.200 ± 0.025 V 0.25 ± 0.07 V 4.275 ± 0.025 V 4.300 ± 0.025 V 4.280 ± 0.025 V 4.380 ± 0.025 V 4.150 ± 0.025 V 4.215 ± 0.025 V 4.280 ± 0.025 V 4.100 ± 0.025 V 0.045 ± 0.02 V 0.25 ± 0.07 V 0.25 ± 0.07 V 0.25 ± 0.07 V 0.045 ± 0.02 V 0V 0.045 ± 0.02 V 0.25 ± 0.07 V 4.550 ± 0.025 V 0.38 ± 0.1 V S-8244ABOPH-CFOTFU Remark Please contact our sales representatives for products other than the above. 4 Output logic and form CMOS output active “H” Nch open drain output active “H” Pch open drain output active “L” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “L” Nch open drain output active “L” CMOS output active “H” CMOS output active “H” CMOS output active “H” BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) Rev.7.1_00 S-8244 Series (2) TMSOP-8 Table 2 Product name S-8244AAAFM-CEAT2U S-8244AABFM-CEBT2U S-8244AACFM-CECT2U S-8244AAFFM-CEFT2U S-8244AAGFM-CEGT2U S-8244AAHFM-CEHT2U S-8244AAIFM-CEIT2U S-8244AAJFM-CEJT2U S-8244AALFM-CELT2U S-8244AANFM-CENT2U S-8244AAOFM-CEOT2U Overcharge detection voltage Overcharge hysteresis voltage [VCU] [VCD] 4.450 ± 0.025 V 0.38 ± 0.1 V 4.200 ± 0.025 V 0V 4.115 ± 0.025 V 0.13 ± 0.04 V 4.350 ± 0.025 V 0.045 ± 0.02 V 4.450 ± 0.025 V 0.045 ± 0.02 V 4.300 ± 0.025 V 0.25 ± 0.07 V 4.400 ± 0.025 V 0.045 ± 0.02 V 4.500 ± 0.025 V 0.38 ± 0.1 V 4.350 ± 0.025 V 0.25 ± 0.07 V 4.150 ± 0.025 V 0.25 ± 0.07 V 4.250 ± 0.025 V 0.25 ± 0.07 V 4.050 ± 0.025 V 0.25 ± 0.07 V 4.150 ± 0.025 V 0V 4.200 ± 0.025 V 0.25 ± 0.07 V 3.825 ± 0.025 V 0.25 ± 0.07 V 4.275 ± 0.025 V 0.045 ± 0.02 V 4.025 ± 0.025 V 0.25 ± 0.07 V 4.220 ± 0.025 V 0.045 ± 0.02 V 3.750 ± 0.025 V 0.25 ± 0.07 V 4.225 ± 0.025 V 0.045 ± 0.02 V 4.100 ± 0.025 V 0V 4.325 ± 0.025 V 0.045 ± 0.02 V 4.175 ± 0.025 V 0V 4.225 ± 0.025 V 0.38 ± 0.1 V 4.350 ± 0.025 V 0.38 ± 0.1 V S-8244AAPFM-CEPT2U S-8244AAQFM-CEQT2U S-8244AATFM-CETT2U S-8244AAUFM-CEUT2U S-8244AAVFM-CEVT2U S-8244AAXFM-CEXT2U S-8244ABAFM-CFAT2U S-8244ABCFM-CFCT2U S-8244ABGFM-CFGT2U S-8244ABIFM-CFIT2U S-8244ABJFM-CFJT2U S-8244ABKFM-CFKT2U S-8244ABNFM-CFNT2U S-8244ABPFM-CFPT2U Remark Please contact our sales representatives for products other than the above. Output logic and form CMOS output active “H” Nch open drain output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” Nch open drain output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” CMOS output active “H” Nch open drain output active “L” Nch open drain output active “L” Nch open drain output active “L” Nch open drain output active “L” Nch open drain output active “L” Nch open drain output active “L” 5 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00  Pin Configurations Table 3 Pin No. 1 SNT-8A Top view 2 CO 1 8 VCC ICT 2 7 SENSE VSS 3 6 VC1 VC3 4 5 VC2 3 4 5 6 7 8 Figure 2 Pin No. 1 2 TMSOP-8 Top view VCC 1 8 CO SENSE 2 7 ICT VC1 3 6 VSS VC2 4 5 VC3 3 4 5 6 7 Figure 3 6 8 Symbol Description CO FET gate connection pin for charge control Capacitor connection pin for overcharge detection ICT delay Input pin for negative power supply, VSS Connection pin for battery 4’s negative voltage Connection pin for battery 3’s negative voltage, VC3 Connection pin for battery 4’s positive voltage Connection pin for battery 2’s negative voltage, VC2 Connection pin for battery 3’s positive voltage Connection pin for battery 1’s negative voltage, VC1 Connection pin for battery 2’s positive voltage SENSE Connection pin for battery 1’s positive voltage VCC Input pin for positive power supply Table 4 Symbol Description VCC Input pin for positive power supply SENSE Connection pin for battery 1’s positive voltage Connection pin for battery 1’s negative voltage, VC1 Connection pin for battery 2’s positive voltage Connection pin for battery 2’s negative voltage, VC2 Connection pin for battery 3’s positive voltage Connection pin for battery 3’s negative voltage, VC3 Connection pin for battery 4’s positive voltage Input pin for negative power supply, VSS Connection pin for battery 4’s negative voltage Capacitor connection pin for overcharge detection ICT delay CO FET gate connection pin for charge control BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) Rev.7.1_00 S-8244 Series  Absolute Maximum Ratings Table 5 (Ta = 25°C unless otherwise specified) Item Input voltage between VCC and VSS Delay capacitor connection pin voltage Symbol VDS VICT Input pin voltage VIN Applied pin VCC ICT SENSE, VC1, VC2, VC3 (CMOS output) VCO (Nch open drain output) (Pch open drain output) SNT-8A Power PD dissipation TMSOP-8 Operating ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size : 114.3 mm × 76.2 mm × t1.6 mm (2) Name : JEDEC STANDARD51-7 CO output pin voltage Unit V V VSS −0.3 to VCC +0.3 V VSS −0.3 to VCC +0.3 VSS −0.3 to 26 VCC −26 to VCC +0.3 450*1 650*1 −40 to +85 −40 to +125 V V V mW mW °C °C CO ⎯ ⎯ ⎯ The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 700 Power Dissipation (PD) [mW] Caution Absolute maximum rating VSS−0.3 to VSS +26 VSS −0.3 to VCC +0.3 600 TMSOP-8 500 400 300 200 SNT-8A 100 0 0 50 100 150 Ambient Temperature (Ta) [°C] Figure 4 Power Dissipation of Package (When Mounted on Board) 7 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00  Electrical Characteristics Table 6 (Ta = 25 °C unless otherwise specified) Item Symbol Condition Min. Typ. Max. Unit Test Test circuit condition DETECTION VOLTAGE Overcharge detection voltage 1 *1 VCU1 3.7 V to 4.55 V Adjustment Overcharge detection voltage 2 *1 VCU2 3.7 V to 4.55 V Adjustment Overcharge detection voltage 3 *1 VCU3 3.7 V to 4.55 V Adjustment Overcharge detection voltage 4 *1 VCU4 3.7 V to 4.55 V Adjustment Overcharge hysteresis voltage 1 *2 Overcharge hysteresis voltage 2 *2 Overcharge hysteresis voltage 3 *2 Overcharge hysteresis voltage 4 *2 Detection voltage temperature coefficient *3 DELAY TIME Overcharge detection delay time OPERATING VOLTAGE Operating voltage between VCC and VSS *5 CURRENT CONSUMPTION Current consumption during normal operation Current consumption at power down VC1 sink current VC2 sink current VC3 sink current OUTPUT VOLTAGE*6 VCD1 VCD2 VCD3 VCD4 ⎯ ⎯ ⎯ ⎯ VCU1 −0.025 VCU2 −0.025 VCU3 −0.025 VCU4 −0.025 0.28 0.28 0.28 0.28 0.38 0.38 0.38 0.38 VCU1 +0.025 VCU2 +0.025 VCU3 +0.025 VCU4 +0.025 0.48 0.48 0.48 0.48 TCOE Ta = −40°C to +85°C*4 −0.4 0.0 C = 0.1 μF 1.0 ⎯ IOPE CO “H” voltage CO “L” voltage V 1 1 V 2 1 V 3 1 V 4 1 V V V V 1 2 3 4 1 1 1 1 +0.4 mV/°C ⎯ ⎯ 1.5 2.0 s 5 2 3.6 ⎯ 24 V ⎯ ⎯ V1 = V2 = V3 = V4 = 3.5 V ⎯ 1.5 3.0 μA 6 3 IPDN V1 = V2 = V3 = V4 = 2.3 V ⎯ 1.2 2.4 μA 6 3 IVC1 IVC2 IVC3 V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V V1 = V2 = V3 = V4 = 3.5 V −0.3 −0.3 −0.3 ⎯ ⎯ ⎯ 0.3 0.3 0.3 μA μA μA 6 6 6 3 3 3 VCO(H) at IOUT = 10 μA VCC −0.05 ⎯ ⎯ V 7 4 VCO(L) at IOUT = 10 μA ⎯ ⎯ VSS +0.05 V 7 4 tCU VDSOP VCU1 VCU2 VCU3 VCU4 ± 50 mV when Ta = −40°C to +85°C. 0.25 ± 0.07 V, 0.13 ± 0.04 V, 0.045 ± 0.02 V except for 0.38 V hysteresis models. Overcharge detection voltage or overcharge hysteresis voltage. Since products are not screened at high and low temperature, the specification for this temperature range is guaranteed by design, not tested in production. *5. After detecting the overcharge, the delay circuit operates normally in the range of operating voltage. *6. Output logic and CMOS or open drain output can be selected. *1. *2. *3. *4. 8 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) Rev.7.1_00 S-8244 Series  Test Circuits (1) Test Condition 1, Test Circuit 1 Set switches 1 and 2 to OFF for CMOS output product. Set switch 1 to ON and switch 2 to OFF for Nch open drain product. Set switch 1 to OFF and switch 2 to ON for Pch open drain product. • Product with CMOS output active “H”, Nch open drain output active “H” The overcharge detection voltage 1 (VCU1) is a voltage at V1; when the CO pin’s voltage is set to “H” by increasing V1 gradually, after setting V1 = V2 = V3 = V4 = 3.5 V. After that, gradually decreasing V1’s voltage to set CO = “L”, and the difference of this V1’s voltage and VCU1 is the overcharge hysteresis voltage 1 (VCD1). • Product with CMOS output active “L”, Nch open drain output active “L”, Pch open drain output active “L” The overcharge detection voltage 1 (VCU1) is a voltage at V1; when the CO pin’s voltage is set to “L” by increasing V1 gradually, after setting V1 = V2 = V3 = V4 = 3.5 V. After that, gradually decreasing V1’s voltage to set CO = “H”, and the difference of this V1’s voltage and VCU1 is the overcharge hysteresis voltage 1 (VCD1). (2) Test Condition 2, Test Circuit 1 Set switches 1 and 2 to OFF for CMOS output product. Set switch 1 to ON and switch 2 to OFF for Nch open drain product. Set switch 1 to OFF and switch 2 to ON for Pch open drain product. • Product with CMOS output active “H”, Nch open drain output active “H” The overcharge detection voltage 2 (VCU2) is a voltage at V2; when the CO pin’s voltage is set to “H” by increasing V2 gradually, after setting V1 = V2 = V3 = V4 = 3.5 V. After that, gradually decreasing V2’s voltage to set CO = “L”, and the difference of this V2’s voltage and VCU2 is the overcharge hysteresis voltage 2 (VCD2). • Product with CMOS output active “L”, Nch open drain output active “L”, Pch open drain output active “L” The overcharge detection voltage 2 (VCU2) is a voltage at V2; when the CO pin’s voltage is set to “L” by increasing V2 gradually, after setting V1 = V2 = V3 = V4 = 3.5 V. After that, gradually decreasing V2’s voltage to set CO = “H”, and the difference of this V2’s voltage and VCU2 is the overcharge hysteresis voltage 2 (VCD2). (3) Test Condition 3, Test Circuit 1 Set switches 1 and 2 to OFF for CMOS output product. Set switch 1 to ON and switch 2 to OFF for Nch open drain product. Set switch 1 to OFF and switch 2 to ON for Pch open drain product. • Product with CMOS output active “H”, Nch open drain output active “H” The overcharge detection voltage 3 (VCU3) is a voltage at V3; when the CO pin’s voltage is set to “H” by increasing V3 gradually, after setting V1 = V2 = V3 = V4 = 3.5 V. After that, gradually decreasing V3’s voltage to set CO = “L”, and the difference of this V3’s voltage and VCU3 is the overcharge hysteresis voltage 3 (VCD3). • Product with CMOS output active “L”, Nch open drain output active “L”, Pch open drain output active “L” The overcharge detection voltage 3 (VCU3) is a voltage at V3; when the CO pin’s voltage is set to “L” by increasing V3 gradually, after setting V1 = V2 = V3 = V4 = 3.5 V. After that, gradually decreasing V3’s voltage to set CO = “H”, and the difference of this V3’s voltage and VCU3 is the overcharge hysteresis voltage 3 (VCD3). 9 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00 (4) Test Condition 4, Test Circuit 1 Set switches 1 and 2 to OFF for CMOS output product. Set switch 1 to ON and switch 2 to OFF for Nch open drain product. Set switch 1 to OFF and switch 2 to ON for Pch open drain product. • Product with CMOS output active “H”, Nch open drain output active “H” The overcharge detection voltage 4 (VCU4) is a voltage at V4; when the CO pin’s voltage is set to “H” by increasing V4 gradually, after setting V1 = V2 = V3 = V4 = 3.5 V. After that, gradually decreasing V4’s voltage to set CO = “L”, and the difference of this V4’s voltage and VCU4 is the overcharge hysteresis voltage 4 (VCD4). • Product with CMOS output active “L”, Nch open drain output active “L”, Pch open drain output active “L” The overcharge detection voltage 4 (VCU4) is a voltage at V4; when the CO pin’s voltage is set to “L” by increasing V4 gradually, after setting V1 = V2 = V3 = V4 = 3.5 V. After that, gradually decreasing V4’s voltage to set CO = “H”, and the difference of this V4’s voltage and VCU4 is the overcharge hysteresis voltage 4 (VCD4). (5) Test Condition 5, Test Circuit 2 Set switches 1 and 2 to OFF for CMOS output product. Set switch 1 to ON and switch 2 to OFF for Nch open drain product. Set switch 1 to OFF and switch 2 to ON for Pch open drain product. • Product with CMOS output active “H”, Nch open drain output active “H” Rise V1 to 4.7 V momentarily within 10 μs after setting V1 = V2 = V3 = V4 = 3.5 V. The period from V1 having reached 4.7 V to CO = “H” is the overcharge detection delay time (tCU). • Product with CMOS output active “L”, Nch open drain output active “L”, Pch open drain output active “L” Rise V1 to 4.7 V momentarily within 10 μs after setting V1 = V2 = V3 = V4 = 3.5 V. The period from V1 having reached 4.7 V to CO = “L” is the overcharge detection delay time (tCU). (6) Test Condition 6, Test Circuit 3 Measure current consumption (I1) setting V1 = V2 = V3 = V4 = 2.3 V. This I1 is current consumption at power-down (IPDN). Measure current consumption (I1) setting V1 = V2 = V3 = V4 = 3.5 V. This I1 is current consumption during normal operation (IOPE), I2 is the VC1 sink current (IVC1), I3 is the VC2 sink current (IVC2), I4 is the VC3 sink current (IVC3). 10 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) Rev.7.1_00 S-8244 Series (7) Test Condition 7, Test Circuit 4 Measure setting switch 1 to OFF and switch 2 to ON. • Product with CMOS output active “H” Decrease V6 from VCC gradually after setting V1 = V2 = V3 = V4 = 4.6 V, the V6’s voltage when flowing I2 = −10 μA is the VCO(H) voltage. Increase V6 from 0 V gradually after setting V1 = V2 = V3 = V4 = 3.5 V, the V6’s voltage when flowing I2 = 10 μA is the VCO(L) voltage. • Product with CMOS output active “L” Decrease V6 from VCC gradually after setting V1 = V2 = V3 = V4 = 3.5 V, the V6’s voltage when flowing I2 = −10 μA is the VCO(H) voltage. Increase V6 from 0 V gradually after setting V1 = V2 = V3 = V4 = 4.6 V, the V6’s voltage when flowing I2 = 10 μA is the VCO(L) voltage. • Product with Pch open drain output active “L” Decrease V6 from VCC gradually after setting V1 = V2 = V3 = V4 = 3.5 V, the V6’s voltage when flowing I2 = −10 μA is the VCO(H) voltage. • Product with Nch open drain output active “H” Increase V6 from 0 V gradually after setting V1 = V2 = V3 = V4 = 3.5 V, the V6’s voltage when flowing I2 = 10 μA is the VCO(L) voltage. • Product with Nch open drain output active “L” Increase V6 from 0 V gradually after setting V1 = V2 = V3 = V4 = 4.6 V, the V6’s voltage when flowing I2 = 10 μA is the VCO(L) voltage. 11 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00 10 MΩ 10 MΩ SW1 S-8244 S-8244 VCC CO SENSE ICT SW2 V1 VC1 V VSS V4 V2 VC2 SW1 VCC CO SENSE ICT V1 VC1 VSS VC2 VC3 SW2 0.1 μF V2 VC3 10 MΩ V3 V V4 10 MΩ V3 Test Circuit 1 Test Circuit 2 I1 S-8244 I1 V1 V2 I2 I3 VCC CO SENSE ICT VC1 VC2 V5 S-8244 VSS VC3 V3 I4 V4 VCC CO SENSE ICT SW2 V1 VC1 VSS V2 VC2 VC3 V3 Test Circuit 3 Test Circuit 4 Figure 5 12 SW1 V V4 I2 V6 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) Rev.7.1_00 S-8244 Series  Operation Remark Refer to “  Battery Protection IC Connection Example”. 1. Overcharge Detection • Product with CMOS output active “H”, Nch open drain output active “H” During charging in the normal status, the voltage of one of the batteries exceeds overcharge detection voltage (VCU), and this status is maintained for overcharge detection delay time (tCU) or longer, CO gets “H”. This is overcharge status. Connecting a FET to the CO pin enables charge-control and the second protect. In this case, the IC maintains the overcharge status until the voltage of each of the batteries decreases, to the overcharge hysteresis voltage (VCD) from the overcharge detection voltage (VCU). • Product with CMOS output active “L”, Nch open drain output active “L”, Pch open drain output active “L” During charging in the normal status, the voltage of one of the batteries exceeds overcharge detection voltage (VCU), and this status is maintained for overcharge detection delay time (tCU) or longer, CO gets “L”. This is overcharge status. Connecting a FET to the CO pin enables charge-control and the second protect. In this case, the IC maintains the overcharge status until the voltage of each of the batteries decreases, to the overcharge hysteresis voltage (VCD) from the overcharge detection voltage (VCU). 2. Delay Circuit The delay circuit rapidly charges the capacitor connected to the delay capacitor connection pin up to a specified voltage when the voltage of one of the batteries exceeds the overcharge detection voltage (VCU). Then, the delay circuit gradually discharges the capacitor at 100 nA and inverts the CO output when the voltage at the delay capacitor connection pin goes below a specified level. Overcharge detection delay time (tCU) varies depending upon the external capacitor. Each delay time is calculated using the following equation. Min. tCU[s] = Delay Coefficient (10, Typ. 15, Max. 20) × CICT [μF] Because the delay capacitor is rapidly charged, the smaller the capacitance, the larger the difference between the maximum voltage and the specified value of delay capacitor pin (ICT pin). This will cause a deviation between the calculated delay time and the resultant delay time. Also, delay time is internally set in this IC to prevent the CO output from inverting until the charge to delay capacitor pin is reached to the specified voltage. If large capacitance is used, output may be enabled without delay time because charge is disabled within the internal delay time. Please note that the maximum capacitance connected to the delay capacitor pin (ICT pin) is 1 μF. 13 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00  Timing Chart VCD V1 battery V2 battery VCU Battery voltage VSS VCC CO pin voltage CMOS output active “H” and Nch open drain output active “H” products VSS VCC CO pin voltage CMOS output active “L” , Pch open drain output active “L” and Nch open drain output active “L” products VSS ICT pin voltage VSS Delay Figure 6 14 V3 battery V4 battery BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) Rev.7.1_00 S-8244 Series  Battery Protection IC Connection Example (1) Connection Example 1 SCP EB+ RVCC SENSE R1 BAT1 VCC CVCC C1 VC1 R2 BAT2 C2 VC2 R3 BAT3 ICT CICT C3 VC3 R4 BAT4 FET C4 VSS CO EB− Figure 7 Table 7 Constants for External Components 1 Symbol R1 to R4 C1 to C4 RVCC CVCC CICT Min. 0 0 0 0 0 Typ. 1k 0.1 100 0.1 0.1 Max. 10 k 1 1k 1 1 Unit Ω μF Ω μF μF Caution1. The constants may be changed without notice. 2. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. [For SCP, contact] Global Sales & Marketing Division, Dexerials Corporation Gate City Osaki East Tower 8F, 1-11-2 Osaki, Shinagawa-ku, Tokyo, 141-0032, Japan TEL +81-3-5435-3946 Contact Us: http://www.dexerials.jp/en/ 15 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00 (2) Connection Example 2 (for 3-cells) SCP EB+ RVCC SENSE R1 BAT1 VCC CVCC C1 VC1 R2 BAT2 C2 VC2 R3 BAT3 ICT CICT C3 VC3 FET VSS CO EB− Figure 8 Symbol R1 to R3 C1 to C3 RVCC CVCC CICT Table 8 Constants for External Components 2 Min. Typ. Max. 0 1k 10 k 0 0.1 1 0 100 1k 0 0.1 1 0 0.1 1 Unit Ω μF Ω μF μF Caution1. The constants may be changed without notice. 2. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. 16 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) Rev.7.1_00 S-8244 Series (3) Connection Example 3 (for 2-cells) SCP EB+ RVCC SENSE R1 BAT1 VCC CVCC C1 VC1 R2 BAT2 C2 VC2 ICT CICT VC3 FET VSS CO EB− Figure 9 Symbol R1, R2 C1, C2 RVCC CVCC CICT Table 9 Constants for External Components 3 Min. Typ. Max. 0 1k 10 k 0 0.1 1 0 100 1k 0 0.1 1 0 0.1 1 Unit Ω μF Ω μF μF Caution1. The constants may be changed without notice. 2. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. 17 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00 (4) Connection Example 4 (for 1-cell) SCP EB+ RVCC SENSE R1 BAT1 VCC CVCC C1 VC1 VC2 ICT CICT VC3 FET VSS CO EB− Figure 10 Table 10 Constants for External Components 4 Symbol R1 C1 RVCC CVCC CICT Min. 0 0 0 0 0 Typ. 1k 0.1 100 0.1 0.1 Max. 10 k 1 1k 1 1 Unit Ω μF Ω μF μF Caution1. The constants may be changed without notice. 2. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. 18 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) Rev.7.1_00 S-8244 Series  Precautions • This IC charges the delay capacitor through the delay capacitor pin (ICT pin) immediately when the voltage of one of batteries V1 to V4 reaches the overcharge voltage. Therefore, setting the resistor connected to the VCC pin to any value greater than the recommended level causes a reduction in the IC power supply voltage because of charge current of the delay capacitor. This may lead to a malfunction. Set up the resistor NOT to exceed the typical value. If you change the resistance, please consult us. • DO not connect any of overcharged batteries. Even if only one overcharged battery is connected to this IC, the IC detects overcharge, then charge current flows to the delay capacitor through the parasitic diode between pins where the battery is not connected yet. This may lead to a malfunction. Please perform sufficient evaluation in the case of use. Depending on an application circuit, even when the fault charge battery is not contained, the connection turn of a battery may be restricted in order to prevent the output of CO detection pulse at the time of battery connection. CMOS output active “H” and Nch open drain output active “H” products VCD V1 battery V2 battery V3 battery V4 battery VCU Battery voltage VSS VCC CO pin voltage CICT high CICT low VSS CICT low Setting voltage ICT pin voltage CICT high VSS Internal delay Delay • In this IC, the output logic of the CO pin is inverted after several milliseconds of internal delay if this IC is under the overcharge condition even ICT pin is either “VSS−short circuit,” “VCC−short circuit” or “Open” status. • Any position from V1 to V4 can be used when applying this IC for a one to three-cell battery. However, be sure to short circuit between pins not in use (SENSE−VC1, VC1−VC2, VC2−VC3, or VC3−VSS). • The application conditions for the input voltage, output voltage, and load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement of the products including this IC upon patents owned by a third party. 19 BATTERY PROTECTION IC FOR 1-SERIAL TO 4-SERIAL-CELL PACK (SECONDARY PROTECTION) S-8244 Series Rev.7.1_00  Characteristics (Typical Data) 1. Detection Voltage vs. Temperature Overcharge Detection Voltage vs. Temperature VCU = 4.45 V S-8244AAAFN 4.17 VCU−VCD [V] S-8244AAAFN 4.55 VCU [V] Overcharge Release Voltage vs. Temperature 4.45 VCD = 0.38 V 4.07 3.97 4.35 −40 −20 0 20 40 Ta [°C] 60 80 −40 100 −20 0 20 40 Ta [°C] 60 80 100 2. Current Consumption vs. Temperature Current Consumption during Normal Operation vs. Temperature S-8244AAAFN VCC = 14.0 V 2 1 VCC = 9.2 V S-8244AAAFN 3 IPDN [μA] IOPE [μA] 3 Current Consumption at Power Down vs. Temperature 2 1 0 0 −40 −20 0 20 40 Ta [°C] 60 80 100 −40 −20 0 3. Delay Time vs. Temperature Overcharge Detection Delay Time vs. Temperature S-8244AAAFN VCC = 15.2 V tCU [s] 3 2 1 0 −40 Caution 20 −20 0 20 40 Ta [°C] 60 80 100 Please design all applications of the S-8244 Series with safety in mind. 20 40 Ta [°C] 60 80 100 1.97±0.03 8 7 6 5 3 4 +0.05 1 0.5 2 0.08 -0.02 0.48±0.02 0.2±0.05 No. PH008-A-P-SD-2.1 TITLE SNT-8A-A-PKG Dimensions No. PH008-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.25±0.05 4.0±0.1 2.0±0.05 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 4 321 5 6 78 Feed direction No. PH008-A-C-SD-2.0 TITLE SNT-8A-A-Carrier Tape No. PH008-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PH008-A-R-SD-1.0 TITLE SNT-8A-A-Reel No. PH008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 0.52 2.01 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) 1. 2. 3. 4. 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.96 mm to 2.06mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) TITLE No. PH008-A-L-SD-4.1 SNT-8A-A -Land Recommendation PH008-A-L-SD-4.1 No. ANGLE UNIT mm ABLIC Inc. 2.90±0.2 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-8244AARFN-CERT2U
物料型号:S-8244系列
器件简介:S-8244系列是用于1至4节锂电池二次保护的电池保护集成电路,具备高精度电压检测电路和延时电路。支持电池间的短路连接。
引脚分配: - SNT-8A封装:CO(8)、VCC(1)、ICT(2)、SENSE(7)、VSS(3)、VC1(6)、VC2(5)、VC3(4) - TMSOP-8封装:VCC(1)、SENSE(2)、VC1(3)、VC2(4)、VC3(5)、VSS(6)、ICT(7)、CO(8)
参数特性: - 过充检测电压范围:3.700V至4.550V,精度±25mV(25°C时) - 迟滞电压:5种类型,0.38±0.1V、0.25±0.07V、0.13±0.04V、0.045±0.02V、无 - 高耐压:绝对最大额定值26V - 宽工作电压范围:3.6V至24V - 延迟时间:可由外部电容设置 - 低功耗:3.5V每节电池时最大3.0μA(25°C)、2.3V每节电池时最大2.4μA(25°C) - 输出逻辑和形式:5种类型,包括CMOS输出高电平、CMOS输出低电平、Pch开漏输出低电平、Nch开漏输出高电平、Nch开漏输出低电平
功能详解: - 过充检测:当任一电池电压超过设定的过充检测电压,并且持续时间达到设定的延迟时间,CO引脚将输出相应的逻辑电平,以实现过充保护。 - 延迟电路:当电池电压超过过充检测电压时,延迟电路会通过ICT引脚快速充电,并在达到特定电压后逐渐放电,以实现延迟输出。
应用信息:适用于锂离子充电电池包的二次保护。
封装信息:SNT-8A和TMSOP-8两种封装形式。
S-8244AARFN-CERT2U 价格&库存
很抱歉,暂时无法提供与“S-8244AARFN-CERT2U”相匹配的价格&库存,您可以联系我们找货
