THIS SPEC IS OBSOLETE
Spec No: 001-51592
Spec Title: STK14CA8 128KX8 AUTOSTORE NVSRAM
Sunset Owner: Girija Chougala (GVCH)
Replaced by: None
STK14CA8
128Kx8 AutoStore nvSRAM
Features
Description
[1]
25 , 35, 45 ns Read Access and Read/Write Cycle Time
Unlimited Read/Write Endurance
Automatic Nonvolatile STORE on Power Loss
Nonvolatile STORE Under Hardware or Software Control
Automatic RECALL to SRAM on Power Up
Unlimited RECALL Cycles
200K STORE Cycles
20-Year Nonvolatile Data Retention
Single 3.0V + 20%, -10% Operation
Commercial and Industrial Temperatures
Small Footprint SOIC and SSOP Packages (RoHS Compliant)
The Cypress STK14CA8 is a 1 Mb fast static RAM with a nonvolatile QuantumTrap storage element included with each memory
cell. This SRAM provides fast access and cycle times, ease of
use, and unlimited read and write endurance of a normal SRAM.
Data transfers automatically to the nonvolatile storage cells
when power loss is detected (the STORE operation). On power
up, data is automatically restored to the SRAM (the RECALL
operation). Both STORE and RECALL operations are also
available under software control.
The Cypress nvSRAM is the first monolithic nonvolatile memory
to offer unlimited writes and reads. It is the highest performing
and most reliable nonvolatile memory available.
Logic Block Diagram
VCC
Quantum Trap
1024 X 1024
ROW DECODER
A5
A6
A7
A8
A9
A12
A13
A14
A15
A16
VCAP
POWER
CONTROL
STORE
STATIC RAM
ARRAY
1024 X 1024
RECALL
STORE/
RECALL
CONTROL
HSB
SOFTWARE
DETECT
INPUT BUFFERS
DQ0
DQ1
DQ2
DQ3
DQ4
DQ5
DQ6
DQ7
A15 – A0
COLUMN I/O
COLUMN DEC
A0 A1 A2 A3 A4 A10 A11
G
E
W
Note
1. 25 ns speed in Industrial temperature range is over the operating voltage range of 3.3V+ 0.3V only.
Cypress Semiconductor Corporation
Document Number: 001-51592 Rev. *D
198 Champion Court
San Jose, CA 95134-1709
408-943-2600
Revised March 02, 2011
STK14CA8
Contents
Features............................................................................... 1
Description.......................................................................... 1
Logic Block Diagram.......................................................... 1
Contents .............................................................................. 2
Pinouts ................................................................................ 3
Pin Descriptions ................................................................. 3
Absolute Maximum Ratings .............................................. 4
DC Characteristics ............................................................. 4
Capacitance ........................................................................ 6
SRAM READ Cycles #1 and #2 .................................... 7
SRAM WRITE Cycles #1 and #2................................... 8
AutoStore/POWER UP RECALL ........................................ 9
Software Controlled STORE/RECALL Cycle .................. 10
Hardware STORE Cycle ................................................... 11
Soft Sequence Commands ............................................... 11
Mode Selection ................................................................. 12
nvSRAM Operation........................................................... 13
nvSRAM ...................................................................... 13
SRAM READ ............................................................... 13
SRAM WRITE ............................................................. 13
AutoStore Operation.................................................... 13
Hardware STORE (HSB) Operation............................ 13
Hardware RECALL (Power Up)................................... 13
Software STORE......................................................... 14
Software RECALL ....................................................... 14
Data Protection............................................................ 14
Noise Considerations .................................................. 14
Best Practices ............................................................. 14
Low Average Active Power ......................................... 15
Preventing AutoStore....................................................... 15
Package Diagrams............................................................ 17
Document History Page .................................................... 18
Sales, Solutions, and Legal Information ........................ 18
Worldwide Sales and Design Support......................... 18
Products ...................................................................... 18
Page 2 of 17
STK14CA8
Pinouts
Figure 1. 48-Pin SSOP
Figure 2. 32-Pin SOIC
VCAP
1
48
VCC
VCAP
1
32
VCC
A16
A14
2
47
A15
A16
2
31
A15
3
46
HSB
30
4
5
6
43
A5
6
27
42
HSB
W
A13
A8
7
NC
A7
A6
A5
A4
29
28
A6
W
A13
A8
4
5
45
44
A14
A12
3
A12
A7
7
26
8
25
A3
A2
9
24
10
23
A9
NC
8
41
A4
9
40
A11
NC
10
39
NC
NC
11
38
NC
A9
A11
G
A10
NC
12
37
NC
22
13
36
VSS
A1
A0
11
VSS
12
21
NC
NC
14
35
NC
DQ0
13
34
14
DQ6
DQ5
16
33
DQ4
17
32
G
15
18
A3
A2
DQ1
DQ2
VSS
19
DQ0
NC
DQ6
31
A10
17
18
16
DQ3
A1
19
30
E
A0
DQ1
DQ2
DQ7
21
28
DQ5
22
23
27
DQ4
NC
26
DQ3
NC
24
25
VCC
E
DQ7
Figure 3. Relative PCB Area Usage[2]
Pin Descriptions
Pin Name
I/O
Description
A16-A0
Input
DQ7-DQ0
I/O
E
Input
Chip Enable: The active low E input selects the device.
W
Input
Write Enable: The active low W allows to write the data on the DQ pins to the address location
latched by the falling edge of E.
G
Input
Output Enable: The active low G input enables the data output buffers during read cycles.
De-asserting G high causes the DQ pins to tri-state.
VCC
Power Supply
HSB
I/O
Hardware Store Busy: When low this output indicates a Store is in progress. When pulled low
external to the chip, it initiates a nonvolatile STORE operation. A weak pull up resistor keeps this
pin high if not connected. (Connection is optional).
VCAP
Power Supply
AutoStore Capacitor: Supplies power to nvSRAM during power loss to store data from SRAM to
nonvolatile storage elements.
VSS
Power Supply
Ground.
NC
No Connect
Address: The 17 address inputs select one of 131,072 bytes in the nvSRAM array.
Data: Bi-directional 8-bit data bus for accessing the nvSRAM.
Power: 3.0V, +20%, -10%.
Unlabeled pins have no internal connections.
Note
2. See Package Diagrams on page 16 for detailed package size specifications.
Page 3 of 17
STK14CA8
NF (SOP-32) PACKAGE THERMAL CHARACTERISTICS
Voltage on Input Relative to Ground.................–0.5V to 4.1V
Voltage on Input Relative to VSS ...........–0.5V to (VCC + 0.5V)
Voltage on DQ0-7 or HSB ......................–0.5V to (VCC + 0.5V)
Temperature under Bias ............................... –55C to 125C
Junction Temperature ................................... –55C to 140C
Storage Temperature .................................... –65C to 150C
Power Dissipation............................................................. 1W
DC Output Current (1 output at a time, 1s duration).... 15 mA
jc 5.4 C/W; ja 44.3 [0fpm], 37.9 [200fpm], 35.1 C/W [500fpm].
RF (SSOP-48) PACKAGE THERMAL CHARACTERISTICS
jc 6.2 C/W; ja 51.1 [0fpm], 44.7 [200fpm], 41.8 C/W [500fpm].
Note: Stresses greater than those listed under Absolute
Maximum Ratings may cause permanent damage to the device.
This is a stress rating only, and functional operation of the device
at conditions above those indicated in the operational sections
of this specification is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect
reliability.
DC Characteristics
(VCC = 2.7V to 3.6V)
Symbol
Parameter
Commercial
Min
Max
Industrial
Min
Max
Units
Notes
ICC1
Average VCC Current
65
55
50
70
60
55
mA
mA
mA
tAVAV = 25 ns
tAVAV = 35 ns
tAVAV = 45 ns
Dependent on output loading and cycle
rate. Values obtained without output
loads.
ICC2
Average VCC Current during
STORE
3
3
mA
All Inputs Don’t Care, VCC = max
Average current for duration of STORE
cycle (tSTORE)
ICC3
Average VCC Current at tAVAV =
200 ns
3V, 25°C, Typical
10
10
mA
ICC4
Average VCAP Current during
AutoStore Cycle
3
3
mA
ISB
VCC Standby Current
(Standby, Stable CMOS Levels)
3
3
mA
IILK
Input Leakage Current
1
1
A
VCC = max
VIN = VSS to VCC
IOLK
Off-State Output Leakage
Current
1
1
A
VCC = max
VIN = VSS to VCC, E or G VIH
VIH
Input Logic “1” Voltage
2.0
VCC+0.3
2.0
VCC+0.3
V
All Inputs
VIL
Input Logic “0” Voltage
VSS–0.5
0.8
VSS–0.5
0.8
V
All Inputs
VOH
Output Logic “1” Voltage
VOL
Output Logic “0” Voltage
TA
Operating Temperature
VCC
Operating Voltage
2.7
3.6
120
2.4
2.4
cycle (tSTORE)
E VCC -0.2V)
All Others VIN0.2V or (VCC-0.2V)
Standby current level after nonvolatile
cycle complete
V
IOUT = – 2 mA
0.4
V
IOUT = 4 mA
–40
85
C
2.7
3.6
V
3.0V +20%, -10%
17
120
F
Between VCAP pin and VSS, 5V rated.
0.4
VCAP
Storage Capacitance
17
NVC
Nonvolatile STORE operations
200
200
DATAR
Data Retention
Note
W (V CC – 0.2V)
All Other Inputs Cycling at CMOS Levels
loads.
K
Years At 55 C
The HSB pin has IOUT=-10 uA for VOH of 2.4 V, this parameter is characterized but not tested.
Page 4 of 17
STK14CA8
AC Test Conditions
Input Pulse Levels ....................................................0V to 3V
Input Rise and Fall Times 5 ns
Input and Output Timing Reference Levels .................... 1.5V
Output Load..................................See Figure 4 and Figure 5
Capacitance
(TA = 25C, f = 1.0 MHz)
Symbol
Parameter[3]
Max Units
CIN
Input Capacitance
7
pF
COUT
Output Capacitance
7
pF
Conditions
V = 0 to 3V
V = 0 to 3V
Figure 4. AC Output Loading
3.0V
577 Ohms
OUTPUT
30 pF
INCLUDING
SCOPE AND
FIXTURE
789 Ohms
Figure 5. AC Output Loading for Tristate Specifications
(tHZ, tLZ, tWLQZ, tWHQZ, tGLQX, tGHQZ)
3.0V
577 Ohms
OUTPUT
789 Ohms
5 pF
INCLUDING
SCOPE AND
FIXTURE
Note
3. These parameters are guaranteed but not tested.
Page 5 of 17
STK14CA8
Symbols
NO.
STK14CA8-25[1] STK14CA8-35
Parameter
#1
#2
Alt.
Min
Max
Min
Max
Min
tELQV
tACS
Chip Enable Access Time
2
tELEH[4]
tRC
Read Cycle Time
3
tAVQV[5]
tAVQV[5]
tAA
Address Access Time
25
35
45
ns
tGLQV
tOE
Output Enable to Data Valid
12
15
ns
tAXQX[5]
tOH
Output Hold after Address
Change
3
3
3
ns
6
tELQX
tLZ
Address Change or Chip Enable
to Output Active
3
3
3
ns
7
tEHQZ[6]
tHZ
Address Change or Chip Disable
to Output Inactive
8
tGLQX
tOLZ
Output Enable to Output Active
tGHQZ[6]
tELICCH[3]
tEHICCL[3]
tOHZ
Output Disable to Output Inactive
tPA
Chip Enable to Power Active
tPS
Chip Disable to Power Standby
4
5
9
10
11
tAXQX[5]
35
Units
Max
tAVAV[4]
1
25
STK14CA8-45
25
35
45
45
10
13
13
ns
ns
15
ns
ns
ns
ns
45
ns
Figure 6. SRAM READ Cycle #1: Address Controlled[4, 5, 7]
2
tAVAV
ADDRESS
3
tAVQV
5
tAXQX
DQ (DATA OUT)
DATA VALID
Figure 7. SRAM READ Cycle #2: E and G Controlled[4, 7]
2
29
1
11
6
7
3
9
4
8
10
Notes
4. W must be high during SRAM READ cycles.
5. Device is continuously selected with E and G both low
6. Measured 200mV from steady state output voltage.
7. HSB must remain high during READ and WRITE cycles
Page 6 of 17
STK14CA8
NO.
Symbols
#1
#2
Alt.
STK14CA8-25[1]
Parameter
Min
Max
STK14CA8-35
Min
Max
STK14CA8-45
Min
Max
Units
12
tAVAV
tAVAV
tWC
Write Cycle Time
25
35
45
ns
13
tWLWH
tWLEH
tWP
Write Pulse Width
30
ns
14
tELWH
tELEH
tCW
Chip Enable to End of Write
30
ns
15
tDVWH
tDVEH
tDW
Data Setup to End of Write
10
12
15
ns
16
tWHDX
tEHDX
tDH
Data Hold after End of Write
ns
17
tAVWH
tAVEH
tAW
Address Setup to End of Write
30
ns
18
tAVWL
tAVEL
tAS
Address Setup to Start of Write
ns
19
tWHAX
tEHAX
tWR
Address Hold after End of Write
ns
tWLQZ[6,8]
tWZ
Write Enable to Output Disable
21
tWHQX
tOW Output Active after End of Write
10
3
13
3
15
3
ns
ns
Figure 8. SRAM WRITE Cycle #1: W Controlled[8,9]
12
tAVAV
ADDRESS
19
tWHAX
14
tELWH
E
17
tAVWH
18
tAVWL
13
tWLWH
W
15
tDVWH
DATA IN
16
tWHDX
DATA VALID
tWLQZ
DATA OUT
HIGH IMPEDANCE
PREVIOUS DATA
21
tWHQX
Figure 9. SRAM WRITE Cycle #2: E Controlled[8,9]
12
tAVAV
ADDRESS
18
tAVEL
14
tELEH
19
tEHAX
E
17
tAVEH
13
tWLEH
W
15
tDVEH
DATA IN
DATA OUT
16
tEHDX
DATA VALID
HIGH IMPEDANCE
Notes
8. If W is low when E goes low, the outputs remain in the high impedance state.
9. E or W must be VIH during address transitions.
Page 7 of 17
STK14CA8
NO.
Symbols
STK14CA8
Parameter
Standard Alternate
Min
Power up RECALL Duration
Units
Notes
ms
10
11, 12
Max
22
tHRECALL
23
tSTORE
STORE Cycle Duration
12.5
ms
24
VSWITCH
Low Voltage Trigger Level
2.65
V
25
VCCRISE
VCC Rise Time
tHLHZ
150
s
t
Figure 10. AutoStore/POWER UP RECALL
25
23
22
23
22
Note Read and Write cycles are ignored during STORE, RECALL, and while VCC is below VSWITCH.
Notes
10. tHRECALL starts from the time VCC rises above VSWITCH
11. If an SRAM WRITE has not taken place since the last nonvolatile cycle, no STORE takes place
12. Industrial Grade devices require maximum 15 ms.
Page 8 of 17
STK14CA8
NO.
Symbols
E Cont G Cont
Parameter[13,14]
Alt
STK14CA8-25[1]
Min
Max
STK14CA8-35
Min
Max
STK14CA8-45
Min
Max
Units Notes
26
tAVAV
tAVAV
tRC
STORE/RECALL Initiation
Cycle Time
25
35
45
ns
27
tAVEL
tAVGL
tAS
Address Setup Time
ns
28
tELEH
tGLGH
tCW
Clock Pulse Width
30
ns
29
tEHAX
tGHAX
Address Hold Time
1
1
1
ns
30
tRECALL tRECALL
RECALL Duration
50
50
50
14
s
Figure 11. Software STORE/RECALL CYCLE: E Controlled[14]
26
26
27
28
29
23
30
Figure 12. Software STORE/RECALL CYCLE: G Controlled[14]
26
27
26
28
23
30
29
Notes
13. The software sequence is clocked on the falling edge of E controlled READs or G controlled READs
14. The six consecutive addresses must be read in the order listed in the Software STORE/RECALL Mode Selection Table. W must be high during all six consecutive cycles.
Page 9 of 17
STK14CA8
NO.
Symbols
Standard
31
tDELAY
32
tHLHX
Parameter
Alternate
tHLQZ
STK14CA8
Min
Max
Hardware STORE to SRAM Disabled
1
70
Hardware STORE Pulse Width
15
Units
Notes
s
15
ns
Figure 13. Hardware STORE Cycle
32
23
31
Symbols
NO.
33
Parameter
Standard
tSS
STK14CA8
Min
Soft Sequence Processing Time
Units
Notes
s
16, 17
Max
70
Figure 14. Software Sequence Commands
33
33
Notes
15. On a hardware STORE initiation, SRAM operation continues to be enabled for time tDELAY to allow read/write cycles to complete.
16. This is the amount of time that it takes to take action on a soft sequence command. Vcc power must remain high to effectively register command.
17. Commands such as Store and Recall lock out I/O until operation is complete which further increases this time. See specific command.
Page 10 of 17
STK14CA8
Mode Selection
E
W
G
A16-A0
Mode
I/O
Power
H
X
X
X
Not Selected
Output High Z
Standby
L
H
L
X
Read SRAM
Output Data
Active
L
L
X
X
Write SRAM
Input Data
Active
L
H
L
0x04E38
0x0B1C7
0x083E0
0x07C1F
0x0703F
0x08B45
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Read SRAM
AutoStore Disable
Output Data
Output Data
Output Data
Output Data
Output Data
Output Data
Active
0x04E38
0x0B1C7
0x083E0
0x07C1F
0x0703F
0x04B46
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Read SRAM
AutoStore Enable
Output Data
Output Data
Output Data
Output Data
Output Data
Output Data
Active
0x04E38
0x0B1C7
0x083E0
0x07C1F
0x0703F
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Output Data
Output Data
Output Data
Output Data
Output Data
Active
0x08FC0
Nonvolatile Store
Output High Z
ICC2
0x04E38
0x0B1C7
0x083E0
0x07C1F
0x0703F
0x04C63
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Nonvolatile Recall
Output Data
Output Data
Output Data
Output Data
Output Data
Output High Z
Active
L
L
L
H
H
H
L
L
L
Notes
18, 19, 20
18, 19, 20
18, 19, 20
18, 19, 20
Notes
18. The six consecutive addresses must be in the order listed. W must be high during all six consecutive cycles to enable a nonvolatile cycle.
19. While there are 17 addresses on the STK14CA8, only the lower 16 are used to control software modes
20. I/O state depends on the state of G. The I/O table shown assumes G low
Page 11 of 17
STK14CA8
SRAM READ
The STK14CA8 performs a READ cycle whenever E and G are
low while W and HSB are high. The address specified on pins
A0-16 determine which of the 131,072 data bytes are accessed.
When the READ is initiated by an address transition, the outputs
are valid after a delay of tAVQV (READ cycle #1). If the READ is
initiated by E and G, the outputs are valid at tELQV or at tGLQV,
whichever is later (READ cycle #2). The data outputs repeatedly
responds to address changes within the tAVQV access time
without the need for transitions on any control input pins, and
remains valid until another address change or until E or G is
brought high, or W and HSB is brought low.
To reduce unneeded nonvolatile stores, AutoStore and
Hardware Store operations are ignored unless at least one
WRITE operation has taken place since the most recent STORE
or RECALL cycle. Software initiated STORE cycles are
performed regardless of whether a WRITE operation has taken
place. The HSB signal can be monitored by the system to detect
an AutoStore cycle is in progress.
Figure 15. AutoStore Mode
VCC
VCAP
VCC
W
0.1µF
The STK14CA8 nvSRAM has two functional components paired
in the same physical cell. These are the SRAM memory cell and
a nonvolatile QuantumTrap cell. The SRAM memory cell
operates similar to a standard fast static RAM. Data in the SRAM
can be transferred to the nonvolatile cell (the STORE operation),
or from the nonvolatile cell to SRAM (the RECALL operation).
This unique architecture allows all cells to be stored and recalled
in parallel. During the STORE and RECALL operations, SRAM
READ and WRITE operations are inhibited. The STK14CA8
supports unlimited read and writes similar to a typical SRAM. In
addition, it provides unlimited RECALL operations from the
nonvolatile cells and up to 200K STORE operations.
10k Ohm
nvSRAM
on page 4 for the size of the capacitor. The voltage on the VCAP
pin is driven to 5V by a charge pump internal to the chip. A pull
up should be placed on W to hold it inactive during power up.
VCAP
nvSRAM Operation
SRAM WRITE
A WRITE cycle is performed whenever E and W are low and HSB
is high. The address inputs must be stable prior to entering the
WRITE cycle and must remain stable until either E or W goes
high at the end of the cycle. The data on the common I/O pins
DQ0-7 are written into memory if it is valid tDVWH before the end
of a W controlled WRITE or tDVEH before the end of an E
controlled WRITE.
The STK14CA8 provides the HSB pin for controlling and
acknowledging the STORE operations. The HSB pin is used to
request a hardware STORE cycle. When the HSB pin is driven
low, the STK14CA8 conditionally initiates a STORE operation
after tDELAY. An actual STORE cycle only begins if a WRITE to
the SRAM took place since the last STORE or RECALL cycle.
The HSB pin has a very resistive pull up and is internally driven
low to indicate a busy condition while the STORE (initiated by
any means) is in progress. This pin should be externally pulled
up if it is used to drive other inputs.
It is recommended that G be kept high during the entire WRITE
cycle to avoid data bus contention on common I/O lines. If G is
left low, internal circuitry turns off the output buffers tWLQZ after
W goes low.
AutoStore Operation
The STK14CA8 stores data to nvSRAM using one of three
storage operations. These three operations are Hardware Store
(activated by HSB), Software Store (activated by an address
sequence), and AutoStore (on power down).
AutoStore operation is a unique feature of Cypress Quantum
Trap technology is enabled by default on the STK14CA8.
During normal operation, the device draws current from VCC to
charge a capacitor connected to the VCAP pin. This stored
charge is used by the chip to perform a single STORE operation.
If the voltage on the VCC pin drops below VSWITCH, the part
automatically disconnects the VCAP pin from VCC. A STORE
operation is initiated with power provided by the VCAP capacitor.
Figure 15 shows the proper connection of the storage capacitor
(VCAP) for automatic store operation. Refer to DC Characteristics
SRAM READ and WRITE operations that are in progress when
HSB is driven low by any means are given time to complete
before the STORE operation is initiated. After HSB goes low, the
STK14CA8 continues to allow SRAM operations for tDELAY.
During tDELAY, multiple SRAM READ operations may take place.
If a WRITE is in progress when HSB is pulled low, it is allowed a
time tDELAY to complete. However, any SRAM WRITE cycles
requested after HSB goes low are inhibited until HSB returns
high.
If HSB is not used, it should be left unconnected.
During power up or after any low power condition
(VCC
