BES01YZ
BES01YZ
    BALLUFF(巴鲁夫)
    Module
    DIMENSION=40 X 12 X 26 MM, STYLE
BES01YZ 数据手册
Inductive Sensors BES R05KB-NSC20B-EP05 Order Code: BES01YZ 1) Sensing surface Ø8 Basic features Electrical data Approval/Conformity CE Load capacitance max. at Ue 1 µF cULus Min. operating current Im 0 mA EAC No-load current Io max., damped 9 mA No-load current Io max., undamped 4 mA Operating voltage Ub 10...30 VDC Output resistance Ra 33.0 kOhm + D Display/Operation Protection class II Function indicator yes Rated insulation voltage Ui 250 V AC no Rated operating current Ie 200 mA Rated operating voltage Ue DC 24 V Rated short circuit current 100 A Ready delay tv max. 10 ms WEEE Basic standard IEC 60947-5-2 Power indicator Electrical connection Cable diameter D 4.60 mm Residual current Ir max. 80 µA Cable length L 5m Ripple max. (% of Ue) 15 % Conductor cross-section 0.34 mm² Switching frequency 2000 Hz Connection type Cable, 5.00 m, PUR Utilization category DC -13 Number of conductors 3 Voltage drop static max. 2.5 V Polarity reversal protected yes Protection against device mix-ups yes Short-circuit protection yes Environmental conditions Ambient temperature -25...70 °C Contamination scale 3 EN 60068-2-27, Shock Half-sinus, 30 gn, 11 ms EN 60068-2-6, Vibration 55 Hz, amplitude 1 mm, 3x30 min IP rating IP67 Interface Switching output Internet www.balluff.com NPN normally open (NO) eCl@ss 9.1: 27-27-01-01 Subject to change without notice: 243704 ETIM 6.0: EC002714 BES01YZ_0.11_2021-07-13 1/2 Inductive Sensors BES R05KB-NSC20B-EP05 Order Code: BES01YZ Material Range/Distance Housing material PA 12 Assured operating distance Sa 1.6 mm Material jacket PUR Hysteresis H max. (% of Sr) 15.0 % Material sensing surface PA 12 Rated operating distance Sn 2 mm Real switching distance sr 2 mm Repeat accuracy max. (% of Sr) 5.0 % Temperature drift max. (% of Sr) 10 % Tolerance Sr ±10 % Mechanical data Dimension 40 x 12 x 26 mm Installation for flush mounting Size 40x12x26 Tightening torque 0.25 Nm Remarks The sensor is functional again after the overload has been eliminated. Wiring Diagrams Internet www.balluff.com eCl@ss 9.1: 27-27-01-01 Subject to change without notice: 243704 ETIM 6.0: EC002714 BES01YZ_0.11_2021-07-13 2/2
BES01YZ 价格&库存
很抱歉,暂时无法提供与“BES01YZ”相匹配的价格&库存,您可以联系我们找货
