UB2000-30GM-E5-V15
UB2000-30GM-E5-V15
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M30
    ULTRASONIC SEN 80-2000MM PNP
UB2000-30GM-E5-V15 数据手册
Ultrasonic sensor UB2000-30GM-E5-V15 < < < < < < < Switch output 5 different output functions can be set Program input Synchronization options Deactivation option Temperature compensation Insensitive to compressed air Single head system Dimensions 5 M30 x 1.5 22 94 36 Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 097969_eng.pdf LED Technical Data General specifications Sensing range 80 ... 2000 mm Adjustment range 120 ... 2000 mm Dead band 0 ... 80 mm Standard target plate 100 mm x 100 mm Transducer frequency approx. 180 kHz Response delay approx. 150 ms Indicators/operating means LED green solid: Power-on flashing: program function object detected Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Ultrasonic sensor UB2000-30GM-E5-V15 Technical Data LED yellow solid: switching state switch output flashing: program function LED red normal operation: "fault" program function: no object detected Electrical specifications Operating voltage UB 10 ... 30 V DC , ripple 10 %SS No-load supply current I0 ≤ 50 mA Input/Output Synchronization bi-directional 0 level -UB...+1 V 1 level: +4 V...+UB input impedance: > 12 KOhm synchronization pulse: ≥ 100 µs, synchronization interpulse period: ≥ 2 ms Synchronization frequency Common mode operation max. 30 Hz Multiplex operation ≤ 30 Hz / n , n = number of sensors , n ≤ 5 Input Input type 1 program input, operating range 1: -UB ... +1 V, operating range 2: +4 V ... +UB input impedance: > 4.7 kΩ; program pulse: ≥ 1 s Output Output type 1 switch output PNP , Normally open/closed , programmable Rated operating current Ie 200 mA , short-circuit/overload protected Voltage drop Ud ≤ 2.5 V Repeat accuracy ≤ 0.5 % of switching point Switching frequency Range hysteresis Temperature influence f H ≤ 3.3 Hz 1 % of the set operating distance < 2 % of far switch point Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007+A1:2012 IEC 60947-5-2:2007 + A1:2012 Approvals and certificates EAC conformity TR CU 020/2011 TR CU 037/2016 UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 097969_eng.pdf Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Mechanical specifications Connection type Connector plug M12 x 1 , 5-pin Degree of protection IP65 Material Housing nickel plated brass; plastic components: PBT Transducer epoxy resin/hollow glass sphere mixture; polyurethane foam Mass 140 g Factory settings Output Switch point A1: 220 mm Switch point A2: 2100 mm output function: Window mode output behavior: NO contact Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Ultrasonic sensor UB2000-30GM-E5-V15 Connection Standard symbol/Connections: (version E5, pnp) 1 (BN) + UB 2 (WH) Program input U 5 4 3 (GY) Sync. input Switch output - UB (BK) (BU) Wire colors in accordance with EN 60947-5-2. Connection Assignment 1 5 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 5 BN WH BU BK GY (brown) (white) (blue) (black) (gray) Characteristic Curve Characteristic response curve Distance Y [m] 0.6 0.4 0.2 0.0 2 1 -0.2 -0.4 Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 097969_eng.pdf -0.6 -0.8 0.0 0.5 1.0 1.5 2.0 2.5 Y 3.0 3.5 4.0 Distance X [m] X Curve 1: flat surface 100 mm x 100 mm Curve 2: round bar, Ø 25 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Ultrasonic sensor UB2000-30GM-E5-V15 Programming Programmable output modes 1. Window mode, normally open mode A1 < A2: A1 object distance A2 2. Window mode, normally closed mode A2 < A1: A2 A1 3. One switch point, normally open mode A1 -> ∞: A2 4. One switch point, normally closed mode A2 -> ∞: A1 5. A1 -> ∞, A2 -> ∞: Object presence detection mode Object detected: Switch output closed No object detected: Switch output open Accessories Mounting flange, 30 mm BF 30-F Plastic mounting adapter, 30 mm BF 5-30 Universal mounting bracket for cylindrical sensors with a diameter of 5 ... 30 mm UB-PROG2 Programming unit UVW90-M30 Ultrasonic -deflector UVW90-K30 Ultrasonic -deflector M30K-VE Plastic nuts with centering ring for the vibration-free mounting of cylindrical sensors V15-G-2M-PVC Female cordset single-ended M12 straight A-coded, 5-pin, PVC cable grey Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 097969_eng.pdf BF 30 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4 Ultrasonic sensor UB2000-30GM-E5-V15 Programming Programming procedure The sensor features a programmable switch output with two programmable switch points. Programming the switch points and the operating mode is done by applying the supply voltage -UB or +UB to the Teach-In input. The supply voltage must be applied to the Teach-In input for at least 1 s. LEDs indicate whether the sensor has recognized the target during the programming procedure. Note: If a programming adapter UB-PROG2 is used for the programming procedure, button A1 is assigned to -UB and button A2 is assigned to +UB. Programming of the switch output Window Modes Normally open (NO) output 1. Place the target at the near end of the desired switch window 2. Program the window boundary by applying -UB to the Teach-In input (yellow and green LEDs flash) 3. Disconnect the Teach-In input from -UB to save the window boundary 4. Place the target at the far end of the desired switch window 5. Program the window boundary by applying +UB to the Teach-In input (yellow and green LEDs flash) 6. Disconnect the Teach-In input from +UB to save the window boundary Normally closed (NC) output 1. Place the target at the near end of the desired switch window 2. Program the window boundary by applying +UB to the Teach-In input (yellow and green LEDs flash) 3. Disconnect the Teach-In input from +UB to save the window boundary 4. Place the target at the far end of the desired switch window 5. Program the window boundary by applying -UB to the Teach-In input (yellow and green LEDs flash) 6. Disconnect the Teach-In input from -UB to save the window boundary Switch Point Modes Normally open (NO) output 1. Place the target at the desired switch point position 2. Program the switch point by applying +UB to the Teach-In input (yellow and green LEDs flash) 3. Disconnect the Teach-In input from +UB to save the switch point 4. Cover the sensor face with hand or remove all objects from sensing range 5. Program the switch point by applying -UB to the Teach-In input (red and yellow LEDs flash) 6. Disconnect the Teach-In input from -UB to save the switch point Normally closed (NC) output 1. Place the target at the desired switch point position 2. Program the switch point by applying -UB to the Teach-In input (yellow and green LEDs flash) 3. Disconnect the Teach-In input from -UB to save the switch point 4. Cover the sensor face with hand or remove all objects from sensing range 5. Program the switch point by applying +UB to the Teach-In input (red and yellow LEDs flash) 6. Disconnect the Teach-In input from +UB to save the switch point Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 097969_eng.pdf Object Detection Mode 1. Cover the sensor face with hand or remove all objects from sensing range 2. Apply -UB to the Teach-In input (red and yellow LEDs flash) 3. Disconnect the Teach-In input from +UB to save the setting 4. Apply +UB to the Teach-In input (red and yellow LEDs flash) 5. Disconnect the Teach-In input from +UB to save the setting Factory Setting Factory settings See technical data. Indication The sensor provides LEDs to indicate various conditions. During normal operation Proper operation Interference (e. g. compressed air) green LED red LED yellow LED On Off Off Flashing Switching state Previous state Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 5 Ultrasonic sensor During sensor programming Object detected No object detected Object uncertain (programming invalid) UB2000-30GM-E5-V15 Flashing Off Off Off Flashing Flashing Flashing Flashing Flashing Commissioning Synchronization This sensor features a synchronization input for suppressing ultrasonic mutual interference ("cross talk"). If this input is not connected, the sensor will operate using internally generated clock pulses. It can be synchronized by applying an external square wave. The pulse duration must be  100 µs. Each falling edge of the synchronization pulse triggers transmission of a single ultrasonic pulse. If the synchronization signal remains low for 1 second, the sensor will revert to normal operating mode. Normal operating mode can also be activated by opening the signal connection to the synchronization input (see note below). If the synchronization input goes to a high level for > 1 second, the sensor will switch to standby mode, indicated by the green LED. In this mode, the outputs will remain in the last valid output state. Note: If the option for synchronization is not used, the synchronization input has to be connected to ground (0 V) or the sensor must be operated via a V1 cordset (4-pin). The synchronization function cannot be activated during programming mode and vice versa. The following synchronization modes are possible: 1. Several sensors (max. number see technical data) can be synchronized together by interconnecting their respective synchronization inputs. In this case, each sensor alternately transmits ultrasonic pulses in a self multiplexing mode. No two sensors will transmit pulses at the same time (see note below). 2. Multiple sensors can be controlled by the same external synchronization signal. In this mode the sensors are triggered in parallel and are synchronized by a common external synchronization pulse. 3. A separate synchronization pulse can be sent to each individual sensor. In this mode the sensors operate in external multiplex mode (see note below). 4. A high level (+UB) on the synchronization input switches the sensor to standby mode. Note: Sensor response times will increase proportionally to the number of sensors that are in the synchronization string. This is a result of the multiplexing of the ultrasonic transmit and receive signal and the resulting increase in the measurement cycle time. Installation Conditions Release date: 2021-02-25 Date of issue: 2021-02-25 Filename: 097969_eng.pdf If the sensor is installed in an environment where the temperature can fall below 0 °C, one of these mounting flanges must be used for mounting: BF30, BF30-F, or BF 5-30. If it is intended to operate the sensor at - 25 °C, we recommend discussing the mounting situation with a Pepperl + Fuchs application specialist to ensure a trouble-free operation. If the sensor is mounted in a through hole using the included steel nuts, it must be mounted at the middle of the threaded housing. If it must be mounted at the front end of the threaded housing, plastic nuts with centering ring (optional accessories) must be used. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 6
UB2000-30GM-E5-V15 价格&库存
很抱歉,暂时无法提供与“UB2000-30GM-E5-V15”相匹配的价格&库存,您可以联系我们找货
