EC3016TBAPL-6
EC3016TBAPL-6
    CARLOGAVAZZI
    Cylinder,Threaded-M30
    SENSOR PROX CAPACITIVE 16MM CYL
EC3016TBAPL-6 数据手册
Proximity Sensors Capacitive LD™ E I Thermoplastic Polyester Housing SH PLE I R T Type EC, M30, AC • Featuring TRIPLESHIELD™ Sensor Protection • Rated operational voltage: 20-250 VAC • Adjustable sensing distance 2-16 mm or 4-25 mm • Output: SCR • Make and break switching function • LED indication • High noise immunity • Flush and non-flush types • Plug and Cable versions available • DC versions in the same housing Product Description Ordering Key Capacitive proximity switch­ es with either sensing distance 16 mm flush mount­ed or 25 mm sensing distance non-flush mount­ed. 2-wire AC output with a switch for choos­ ing NO and NC Capacitive prox­im­ity switch Housing diameter (mm) Rated operating dist. (mm) Output type Housing material Housing type Connection type switch­ ing. Grey M30 poly­ ester housing with 2 m PVC cable or plug. Ideal for use in level and plas­tic ma­chin­ ery applications. Both types are available in metal housings. EC 3025 TBA P L-6 Type Selection Housing diameter M 30 M30 1) Rated Mounting operating dist. (Sn) 1) Ordering no. SCR, cable Make & break switching Ordering no. SCR, plug Make & break switching 16 mm 25 mm EC 3016 TBAPL EC 3025 TBAPL EC 3016 TBAPL-6 EC 3025 TBAPL-6 Flush (built-in) Non-flush Object: Grounded steel plate Specifications Rated operating dist. (Sn) 3016: 3025: Sensitivity Effective operating dist. (Sr) Usable operating dist. (Su) Repeat accuracy (R) Hysteresis (H) Rated operational volt. (UB) Ripple Rated operational current (Ie) Continuous Short-time Min. load current OFF-state current (Ir) Voltage drop (Ud) Protection 2 to 16 mm factory set at 16 mm 4 to 25 mm factory set at 25 mm Adj. multiturn pot.meter 0.9 x Sn ≤ Sr ≤ 1.1 x S 0.8 x Sr ≤ Sn > 1.2 x Sr ≤ 5% 4 to 20% of sensing distance 20 to 250 VAC (ripple included) ≤ 10% ≤ 500 mA < 2.5 A (max. 20 ms) 10 mA < 2.5 mA (@ 240 VAC) 1.7 mA (@ 120 VAC) ≤ 10 VAC (at loads ≥ 20 mA) Transients Specifications are subject to change without notice (15.08.2018) Power ON delay Frequency of operating cycles (f) Indication for output ON Environment Degree of protection Temperature Operating temperature Storage temperature Housing material Body Cable end Nuts Connection Cable Plug (-6) Cable for plug (-6) Weight (incl. nuts) Approvals CE-marking ≤ 100 ms 10 Hz LED, yellow IP 67 (Nema 1, 3, 4, 6, 13) -25° to +80°C ( -13° to +176°F) -40° to +85°C (-40° to +185°F) Grey, thermoplastic polyester Polyester Black reinforced nylon Grey, 2 m, 2 x 0.5 mm2 Oil proof, PVC M12 x 1 double keyed CON.-6A-series 3016: 140 g 3025: 150 g UL, CSA Yes 1 EC, M30, AC Dimensions D E C D E B B C F SW M12x1 LED SW A Cable LED A Plug Type A B C D E F SW Ø mm mm mm mm mm mm EC 3016TBAPL(-6) M30 x 1.5 x 50 36 EC 3025TBAPL(-6) M30 x 1.5 x 50 28 50 13.6 15.4 10 28 62 13.6 15.4 10 36 Adjustment Guide The environments in which capacitive sensors are install­ ed can often be un­stable re­ garding temperature, humi­dity­, object distance and industrial (noise) interference. Because of this, Carlo Ga­ vazzi offers as standard features in all TRIP­LESHIELD™ capacitive sensors a user-friendly sensitivity adjustment instead of having a fixed sensing range, extend­ ed sen­ sing range to accommodate mechanically demand­­ing are­as, temperature stability to en­ sure minimum need for adjusting sensitivity if temperature varies and high immunity to elec­tro­magnetic interference (EMI). Note: Sensors are factory set (default) to maximum rated sensing range. EC3016TBAPL(-6) EC3025TBAPL(-6) Tripleshield Sensitivity Adjustment AC models Max. Min. Dist. Output Programmable NO or NC (by selector switch backview) (2-wire device backview) Sensitivity Installation Hints Capacitive sensors have the unique ability to detect al­ most all materials, either in li­ quid or solid form. Capa­ ci­ tive sensors can detect metallic as well as non-metallic ob­ jects, how­ ever, their traditional use is for non-metallic materials such as: • Plastic Industry Resins, regrinds or mould­ ed products. To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables • Chemical Industry Cleansers, fertilisers, liquid soaps, corrosives and pe­­­-­t­­ro­­­chemicals. • Wood Industry Saw dust, paper products, door and window frames. • Ceramic & Glass ­Industry Raw material, clay or finish­ed products, bottles. Relief of cable strain • Packaging Industry Package inspection for level or contents, dry goods, fruits and vegetables, dairy products. Materials are detected due to their dielectric constant. The bigger the size of an object, the higher the density of ma­ terial, the better or easier it is to detect the object. Nominal sensing di­stan­ce for a capac- itive sensor is refe­­r­enced to a grounded me­tal plate (ST37). For addi­ tional information regarding di­elec­­tric ratings of materials please re­fer to Technical Information. Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 2 Specifications are subject to change without notice (15.08.2018) EC, M30, AC Wiring Diagram Delivery Contents 2 BU NO, NC selector switch 20 - 265 VAC 10 - 500 mA 3 BN • Capacitive switch: EC 30.. TBAPL(-6) • Screw driver • 2 nuts • Packaging: Cardboard box • Installation & Adjustment Guide (MAN CAP ENG/GER) Accessories • Plugs CONH6A.. serie. Specifications are subject to change without notice (15.08.2018) 3
EC3016TBAPL-6 价格&库存
很抱歉,暂时无法提供与“EC3016TBAPL-6”相匹配的价格&库存,您可以联系我们找货
