SFEM064GB1EA1TO-I-HG-111-STD
    SWISSBIT
    VFBGA153
    符合JEDEC e·MMC 5.0标准,采用153球BGA封装,支持多种数据总线宽度模式,具有高可靠性和长寿命,适用于POS/PLC/IoT等工业应用。
SFEM064GB1EA1TO-I-HG-111-STD 数据手册
Product Fact Sheet Industrial eMMC Memory EM-26 Series JEDEC eMMC 5.0 compliant, BGA 153 ball, Enhanced Mode (pSLC) Industrial Temperature Grade Date: Revision: December 02, 2019 1.02 Embedded MMC 5.0 EM-26 Industrial eMMC Memory 2GB to 32GB Main Features      Fully compliant with JEDEC eMMC 5.0 Standard (JESD84-B50) 153-ball BGA, 0.5mm pitch 11.5 x 13mm, RoHS compliant Enhanced Mode (pSLC) Single partition High performance eMMC 5.0 specification o Eleven-wire bus (clock, Data Strobe, 1 bit command, 8 bit data bus) and a hardware reset o Three different data bus width modes: 1-bit (default), 4-bit, and 8-bit o Clock frequencies 0-200MHz, High Speed Mode HS400 o Up to 270MB/s sequential read and up to 160MB/s sequential write  Power Supply: (Low-power CMOS technology) o VCCQ 1.7V…1.95V or 2.7V…3.6V eMMC supply o VCC 2.7V…3.6V NAND Flash supply  Optimized FW algorithms o Power-fail data loss protection o Wear Leveling technology Equal wear leveling of static and dynamic data. The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed o Read Disturb Management The read commands per region are monitored and the content is conditionally refreshed when critical levels have occurred o Auto Read Refresh The interruptible background process maintains the user data for Read Disturb effects or Retention degradation due to high temperature effects o Diagnostic features with Device Health Report according to eMMC Spec 5.0, and new Firmware FW2 with detailed Lifetime Monitor data. o Field Firmware update according to eMMC Spec 5.0 o Discard and Sanitize, Trim o Boot Operation Mode and Alternative Boot Operation Mode o Replay Protected Memory Block (RPMB)  High reliability o Designed with sophisticated firmware architecture for industrial and embedded markets. o Enhanced Mode (pSLC) with higher write performance and endurance than MLC configured products (EM-20). o Ideal for application like POS/POI, PLC, IoT, gaming, medical and use as general boot medium for embedded applications. o The product is optimized for long life cycle that requires superior data retention as well as power fail safety. o Industrial Temperature range, -40° up to 85°C  Controlled BOM & PCN process Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.02 www.swissbit.com industrial@swissbit.com EM-26_Fact_Sheet_Rev102 Page 2 of 3 Order Information for EM-26 Density Part Number 2GB SFEM4096B1EA1TO-I-GE-111-E02 4GB SFEM008GB1EA1TO-I-GE-111-E04 8GB SFEM016GB1EA1TO-I-GE-111-E08 16GB SFEM032GB1EA1TO-I-LF-111-E16 32GB SFEM064GB1EA1TO-I-HG-111-E32 2GB SFEM2048B1EA1TO-I-GE-12P-STD 4GB SFEM4096B1EA1TO-I-GE-12P-STD 8GB SFEM008GB1EA1TO-I-GE-12P-STD 16GB SFEM016GB1EA1TO-I-LF-12P-STD 32GB SFEM032GB1EA1TO-I-HG-12P-STD Temp. Range Firmware Flash Technology -40°C to 85°C FW1: default pSLC NAND Flash -40°C to 85°C FW2: detailed Lifetime Monitor data pSLC NAND Flash System Performance System Performance Typ. Sustained Max. Enhanced Mode Sequential Read 178 up to 270 Sequential Write 60 up to 160 Write Typ. ICCQ current @ VCCQ 1.8V 110 Typ. ICC current @ VCC 3.3V 83 Read 178 37 Idle - 0.2 Burst Data transfer Rate HS400 (max clock 200MHz) Current Consumption, 32GB device, HS400 Unit 400 MB/s Unit mA Physical Dimensions Physical Dimensions Value Length 13±0.1 Width 11.5±0.1 Thickness 1.0 max. Unit mm Recommended Temperature Conditions Parameter Min. Typ. Max. Unit Industrial Operating Temperature -40 25 85* °C Storage Temperature -40 25 85* °C * High temperature storage without operation reduces the data retention, in operation the data will be refreshed, if data error issues were detected. For more information on eMMC interface, please visit JEDEC homepage (www.jedec.org) Why Swissbit? Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled inhouse product research and development team. Swissbit maintains a marketing edge by continuing to manufacture world-class high quality memory products and providing customers with both high value and low cost of ownership achieved through efficient processes and procedures. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.02 www.swissbit.com industrial@swissbit.com EM-26_Fact_Sheet_Rev102 Page 3 of 3
SFEM064GB1EA1TO-I-HG-111-STD 价格&库存
很抱歉,暂时无法提供与“SFEM064GB1EA1TO-I-HG-111-STD”相匹配的价格&库存,您可以联系我们找货
