NEB12-18GM50-E2-V1
NEB12-18GM50-E2-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    INDUCTIVE SEN 12MM PNP
NEB12-18GM50-E2-V1 数据手册
Inductive sensor NEB12-18GM50-E2-V1 < Increased operating distance < 12 mm quasi flush Dimensions 63.5 47 4 M18 x 1 24 8 LED (4x) M12 x 1 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 231731_eng.pdf Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation quasi flush Output polarity Assured operating distance 12 mm DC sa 0 ... 9.72 mm Actuating element mild steel, e. g. 1.0037, SR235JR (formerly St37-2) 36 mm x 36 mm x 1 mm Reduction factor rAl 0.26 Reduction factor rCu 0.2 Reduction factor r304 0.63 Reduction factor rBrass 0.33 Nominal ratings Installation conditions A in steel 1.0037 (St37): 4 mm B 14 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NEB12-18GM50-E2-V1 Technical Data C 36 mm F 36 mm Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 500 Hz Hysteresis H 0.12 ... 1.8 mm Reverse polarity protection yes Short-circuit protection pulsing Overload resistance yes Wire breakage protection yes Inductive overvoltage protection yes Surge suppression yes Ripple 10 % Voltage drop Ud ≤2V Repeat accuracy R 0.6 mm Operating current IL 0 ... 200 mA Off-state current Ir ≤ 10 µA No-load supply current I0 ≤ 11 mA Time delay before availability tv ≤ 50 ms Switching state indicator LED, yellow Functional safety related parameters MTTFd 2650 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates EAC conformity TR CU 020/2011 UL approval cULus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 85 °C (-13 ... 185 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 231731_eng.pdf Mechanical specifications Connection type Connector M12 x 1 , 3-pin Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Mass 50 g Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NEB12-18GM50-E2-V1 Connection Assignment 1 4 3 Wire colors in accordance with EN 60947-5-2 1 3 4 BN BU BK (brown) (blue) (black) Installation B F A sensing face C metal-free zone support Accessories Mounting flange, 18 mm V1-G-2M-PUR Female cordset, M12, 4-pin, PUR cable V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 231731_eng.pdf BF 18 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NEB12-18GM50-E2-V1 价格&库存
很抱歉,暂时无法提供与“NEB12-18GM50-E2-V1”相匹配的价格&库存,您可以联系我们找货
