NBB2-V3-US
NBB2-V3-US
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 2MM NO
NBB2-V3-US 数据手册
Inductive sensor NBB2-V3-US < Sensing range 2 mm < 2-wire AC/DC Dimensions 22.2 LED 4 10.4 16 Ø3.1 4 Ø3.1 28 Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 094347_eng.pdf 10 5.5 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance Two-wire sn 2 mm Installation flush mountable Output polarity AC/DC Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB2-V3-US Technical Data Reduction factor rAl 0.5 Reduction factor rCu 0.46 Reduction factor r304 0.9 Reduction factor rSt37 1 Reduction factor rBrass 0.8 Nominal ratings Operating voltage DC UB 10 ... 140 V Operating voltage AC UB 20 ... 140 V Switching frequency f 25 Hz Reverse polarity protection no Short-circuit protection no Voltage drop Ud ≤7V Operating current IL 5 ... 200 mA max Off-state current Ir ≤ 0.8 mA Switching state indicator LED, red Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PUR , 2 m Core cross-section 0.25 mm2 Housing material PBT Sensing face PBT Degree of protection IP67 Connection BN AC/DC Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 094347_eng.pdf BU Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBB2-V3-US 价格&库存
很抱歉,暂时无法提供与“NBB2-V3-US”相匹配的价格&库存,您可以联系我们找货
