NMB2-12GM85-US-FE-V12
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M12
    INDUCTIVE SEN 2MM NO
NMB2-12GM85-US-FE-V12 数据手册
Inductive sensor NMB2-12GM85-US-FE-V12 < < < < Stainless steel sensing face Sensing range 2 mm 2-wire AC/DC Ferrous targets Dimensions 69 56 61 17 4 2 M12x1 85 LED 8 LED 1/2”-20 Technical Data General specifications Switching function Normally open (NO) Output type Two-wire Rated operating distance 2 mm flush Output polarity AC/DC Assured operating distance Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 900126_eng.pdf sn Installation sa 0 ... 1.62 mm Actuating element Ferrous targets Reduction factor rAl 0 Reduction factor rCu 0 Reduction factor r304 0.4 - 0.7 Reduction factor rSt37 1 Reduction factor rBrass 0 Output type 2-wire Nominal ratings Operating voltage DC UB 20 ... 300 V Operating voltage AC UB 20 ... 250 V Switching frequency f 30 Hz Hysteresis H 3 ... 15 typ. 5 % Reverse polarity protection yes Short-circuit protection yes Voltage drop Ud ≤7V Operating current IL 8 ... 200 mA Off-state current Ir ≤ 1.3 mA Error indicator LED, green/yellow (Alternate Flashing) - Short circuit/overload indication Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NMB2-12GM85-US-FE-V12 Technical Data Indicators/operating means Operation indicator Dual LED Green: power Yellow: output Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector plug 1/2"-20 UN , 3-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face Stainless steel 1.4305 / AISI 303 Degree of protection IP67 / IP68 / IP69K - cordset dependent according to cable specification Connection 2 3 +/– –/+ 1 Connection Assignment 1 2 3 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 900126_eng.pdf Wire colors 1 2 3 GN (green) RD/BK (red/black) RD/WH (red/white) Accessories AB-12 Mounting aid Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NMB2-12GM85-US-FE-V12 价格&库存
很抱歉,暂时无法提供与“NMB2-12GM85-US-FE-V12”相匹配的价格&库存,您可以联系我们找货
