NMB1.5-8GM35-E2-C-FE-150MM-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M8
    IND SEN 1.5MM PNP XYLAN COATED
NMB1.5-8GM35-E2-C-FE-150MM-V1 数据手册
Inductive sensor NMB1,5-8GM35-E2-C-FE-150MM-V1 < < < < < < Stainless steel sensing face 1.5 mm flush 3-wire DC Weld field immune Weld slag resistant coating Ferrous targets Dimensions M12 x 1 13 25 35 4 M8x1 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 909311_eng.pdf LED 150 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn 1.5 mm Installation flush in mild steel Output polarity DC Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NMB1,5-8GM35-E2-C-FE-150MM-V1 Technical Data Assured operating distance sa 0 ... 1.215 mm Actuating element Ferrous targets Reduction factor rAl 0 Reduction factor rCu 0 Reduction factor r304 0.4 - 0.7 Reduction factor rSt37 1 Reduction factor rBrass 0 Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 5 Hz Hysteresis H 5 ... 15 typ. 10 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤2V Operating current IL 0 ... 100 mA Current consumption Off-state current ≤ 10 mA Ir ≤ 10 µA Switching state indicator LED, red Mag. Field strength, AC fields 250 mT Mag. Field strength, DC fields 250 mT Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 75 °C (-13 ... 167 °F) Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 909311_eng.pdf Mechanical specifications Connection type Cable connector M12 x 1 , 3-pin with PVC Cable, 150 mm Core cross-section 0.14 mm2 Housing material Xylan coated - Stainless steel 1.4305 / AISI 303 Sensing face Xylan coated - Stainless steel 1.4305 / AISI 303 Degree of protection IP67 Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NMB1,5-8GM35-E2-C-FE-150MM-V1 Connection Assignment 1 4 3 Wire colors in accordance with EN 60947-5-2 1 3 4 BN BU BK (brown) (blue) (black) Accessories Mounting flange, 8 mm V1-G-OR2M-POC Female cordset single-ended M12 A-coded 4-pin, TPE cable welding-bead resistant orange Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 909311_eng.pdf BF 8 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NMB1.5-8GM35-E2-C-FE-150MM-V1 价格&库存
很抱歉,暂时无法提供与“NMB1.5-8GM35-E2-C-FE-150MM-V1”相匹配的价格&库存,您可以联系我们找货
