NBB1.5-5GM25-E2-V3
NBB1.5-5GM25-E2-V3
    PEPPERL+FUCHS(倍加福)
    Cylinder, Threaded - M5
    INDUCTIVE SEN 1.5MM PNP
NBB1.5-5GM25-E2-V3 数据手册
Inductive sensor NBB1,5-5GM25-E2-V3 < Basic series < 1.5 mm flush Dimensions 22.5 38 8 26.4 2.7 M5 x 0.5 LED M8 x 1 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 204745_eng.pdf Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation flush Output polarity Assured operating distance 1.5 mm DC sa 0 ... 1.215 mm Actuating element 5 mm x 5 mm x 1 mm Reduction factor rAl 0.41 Reduction factor rCu 0.38 Reduction factor r304 0.85 Reduction factor rBrass 0.54 Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 3000 Hz Hysteresis H 1 ... 15 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB1,5-5GM25-E2-V3 Technical Data Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.1 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 10 mA Switching state indicator LED, yellow Functional safety related parameters MTTFd 1245 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector M8 x 1 , 3-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face POM Degree of protection IP67 Connection 1 L+ 4 3 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 204745_eng.pdf L- Connection Assignment 4 1 3 Wire colors in accordance with EN 60947-5-2 1 3 4 BN BU BK (brown) (blue) (black) Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB1,5-5GM25-E2-V3 Accessories Mounting flange, 5 mm V3-WM-2M-PUR Female cordset single-ended, M8, 3-pin, PUR cable Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 204745_eng.pdf BF 5 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB1.5-5GM25-E2-V3 价格&库存
很抱歉,暂时无法提供与“NBB1.5-5GM25-E2-V3”相匹配的价格&库存,您可以联系我们找货
