NBB5-18GM60-WS
NBB5-18GM60-WS
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    INDUCTIVE SEN 5MM NO
NBB5-18GM60-WS 数据手册
Inductive sensor NBB5-18GM60-WS < Basic series < 5 mm flush < 2-wire AC Dimensions 4 M18 x 1 60 24 LEDs Technical Data Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 124311_eng.pdf General specifications Switching function Normally open (NO) Output type Rated operating distance Two-wire sn Installation 5 mm flush Output polarity AC Assured operating distance sa 0 ... 4.05 mm Actual operating distance sr 4.5 ... 5.5 mm typ. 5 mm Reduction factor rAl 0.2 Reduction factor rCu 0.2 Reduction factor r304 0.6 Output type 2-wire Nominal ratings Operating voltage UB 20 ... 253 V Switching frequency f 0 ... 20 Hz Hysteresis H typ. 6 % Reverse polarity protection reverse polarity tolerant Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB5-18GM60-WS Technical Data Voltage drop Ud Momentary current (20 ms, 0.1 Hz) < 5 V (IL > 50 mA); < 8 V (IL < 50 mA) 0 ... 1600 mA Operating current IL 5 ... 200 mA Off-state current Ir 0 ... 1.7 mA typ. Time delay before availability tv ≤ 30 ms Operating voltage indicator LED, green Switching state indicator LED, yellow Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.34 mm2 Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Cable Cable diameter 4.6 mm ± 0.2 mm Bending radius > 10 x cable diameter 1) Note In the temperature range below 0 °C, permissible operating voltage Ub 80...253 V Safety fuse ≤ 0.8 A (quick-blow) according to IEC 60127-2 Sheet 1 Recommendation: after a short circuit, check that the device is functioning correctly. Connection BN L BU Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 124311_eng.pdf N GN/YE Accessories EXG-18 Quick mounting bracket with dead stop BF 18 Mounting flange, 18 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBB5-18GM60-WS 价格&库存
很抱歉,暂时无法提供与“NBB5-18GM60-WS”相匹配的价格&库存,您可以联系我们找货
