CM12-08EBP-KC1
CM12-08EBP-KC1
    SICK
    Cylinder,Threaded-M12
    SENSOR PROX CAP 8MM IP68 CYLIND
CM12-08EBP-KC1 数据手册
Product data sheet CM12-08EBP-KC1 CM CAPACITIVE PROXIMITY SENSORS CM12-08EBP-KC1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. CM12-08EBP-KC1 6051030 Other models and accessories www.sick.com/CM Illustration may differ Detailed technical data Features Housing Cylindrical thread design Thread size M12 x 1 Diameter Ø 12 mm Sensing range Sn 0.5 mm ... 8 mm 1) 0.5 mm ... 4 mm 2) Safe sensing range Sa 5.76 mm Installation type Non-flush / flush 3) Switching frequency 15 Hz Connection type Male connector M12, 4-pin Switching output PNP / NPN Output function Programmable Output characteristic Wire configurable 4) Electrical wiring DC 4-wire Adjustment Single teach-in button (Sensitivity) Cable (Sensitivity) Enclosure rating IP68 5) 6) 1) 2) 3) 4) 5) 6)  For non-flush installation.  For flush mounting.  For flush mounting, Teach-in necessary.  Automatic detection.  According to EN 60529.  1.3 m water depth / 60 min. Mechanics/electronics Supply voltage 1) 2) 3) 4) 5) 6) 2 10 V DC ... 36 V DC  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  For non-flush installation min. 1 x Sn and sensor grounded. PROXIMITY SENSORS | SICK Product data sheet | 2021-09-01 09:25:52 Subject to change without notice CM12-08EBP-KC1 | CM CAPACITIVE PROXIMITY SENSORS Ripple ≤ 10 % 1) Voltage drop ≤ 2.5 V DC 2) Current consumption 12 mA 3) Time delay before availability ≤ 120 ms Hysteresis 3 % ... 20 % Reproducibility ≤ 5 % 4) 5) EMC According to EN 60947-5-2 6) Continuous current Ia ≤ 200 mA Short-circuit protection ✔ Reverse polarity protection ✔ Power-up pulse protection ✔ Shock and vibration resistance 30 g, 11 ms / 10 ... 55 Hz, 1 mm Ambient operating temperature –20 °C ... +85 °C Ambient temperature, storage –40 °C ... +85 °C Housing material Plastic Housing length 84.7 mm Thread length 46.5 mm Tightening torque, max. ≤ 1 Nm Items supplied Mounting nut, PA12 plastic (2x) UL File No. NRKH.E191603 1) 2) 3) 4) 5) 6)  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  For non-flush installation min. 1 x Sn and sensor grounded. Safety-related parameters MTTFD 603 years DCavg 0 % TM (mission time) 20 years Reduction factors Note The values are reference values which may vary Metal 1 Water 1 PVC Approx. 0.4 Oil Approx. 0.25 Glass 0.6 Ceramics 0.5 Alcohol 0.7 Wood 0.2 ... 0.7 2021-09-01 09:25:52 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 3 CM12-08EBP-KC1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Installation note Remark Associated graphic see "Installation" B 12 mm C 12 mm D 12 mm E 8 mm Classifications ECl@ss 5.0 27270102 ECl@ss 5.1.4 27270102 ECl@ss 6.0 27270102 ECl@ss 6.2 27270102 ECl@ss 7.0 27270102 ECl@ss 8.0 27270102 ECl@ss 8.1 27270102 ECl@ss 9.0 27270102 ECl@ss 10.0 27270102 ECl@ss 11.0 27270102 ETIM 5.0 EC002715 ETIM 6.0 EC002715 ETIM 7.0 EC002715 ETIM 8.0 EC002715 UNSPSC 16.0901 39122230 Installation note Non-flush installation F B C A A D E 4 PROXIMITY SENSORS | SICK Product data sheet | 2021-09-01 09:25:52 Subject to change without notice CM12-08EBP-KC1 | CM CAPACITIVE PROXIMITY SENSORS Connection diagram Cd-235 BN 1 BK 4 WH 2 BU 3 + (L+) NO/NC Teach - (M) Characteristic curve CM12 mm (inch) 8 (0.31) 4 (0.16) 0 –4 (–0.16) –8 (-0.31) 0 2 4 6 8 10 (0.08) (0.16) (0.24) (0.31) (0.39) Distance in mm (inch) Dimensional drawing (Dimensions in mm (inch)) CM12, connector 80 (3.15) 10.7 24 (0.94) M12x1 LED (0.42) 40 (1.57) M12 1 ①  LED yellow: output active; LED green: Power and signal reserve 2021-09-01 09:25:52 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 5 CM12-08EBP-KC1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Recommended accessories Other models and accessories www.sick.com/CM Brief description Type Part no. BEF-KHS-N05 2051611 Mounting plate for M12 sensors, steel, zinc coated, without mounting hardware BEF-WG-M12 5321869 Mounting bracket for M12 sensors, steel, zinc coated, without mounting hardware BEF-WN-M12 5308447 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 2 m YF2A14020VB3XLEAX 2096234 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m YF2A14050VB3XLEAX 2096235 Head A: female connector, M12, 4-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 2 m YG2A14020VB3XLEAX 2095895 Head A: female connector, M12, 4-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m YG2A14050VB3XLEAX 2095897 Head A: female connector, M12, 4-pin, straight Head B: Cable: unshielded DOS-1204-G 6007302 Head A: female connector, M12, 4-pin, angled Head B: Cable: unshielded DOS-1204-W 6007303 Universal bar clamp systems Plate N05 for universal clamp bracket, M12, Zinc plated steel (sheet), Zinc die cast (clamping bracket), Universal clamp (5322626), mounting hardware Mounting brackets and plates Plug connectors and cables 6 PROXIMITY SENSORS | SICK Product data sheet | 2021-09-01 09:25:52 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
CM12-08EBP-KC1 价格&库存
很抱歉,暂时无法提供与“CM12-08EBP-KC1”相匹配的价格&库存,您可以联系我们找货
