IA12ELN04UC
IA12ELN04UC
    CARLOGAVAZZI
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 4MM CYLIND
IA12ELN04UC 数据手册
Proximity Sensors Inductive Stainless Steel Housing Types IA, M12, M18 and M30, NAMUR • Stainless steel housing, cylindrical • Diameter: M12, M18, M30 • Short or long versions • Sensing distance: 2 to 15 mm • Output: NAMUR EN 50 227 • Protection: Reverse polarity • LED-indication • 2 m cable or plug M12 Product Description Ordering Key Proximity switch in M12, M18 and M30 stainless steel housing. Made in accordance with Euronorm EN 50 227 and EN 60 947-5-2. For thermoplastic housing refer to type IA 12C.... Amplifier relay SD.... is available. Type Housing size Housing type Sensing function Sensing distance Output type Plug IA 12 ESF 02 UC M1 Type Selection Housing diameter Body style Connection Rated operating distance (Sn) Ordering no. Namur M12 M12 M12 M12 M12 M12 M12 M12 Short Short Long Long Short Short Long Long Cable Plug Cable Plug Cable Plug Cable Plug 2 mm 1) 2 mm 1) 2 mm 1) 2 mm 1) 4 mm 2) 4 mm 2) 4 mm 2) 4 mm 2) IA 12 ESF 02 UC IA 12 ESF 02 UC M1 IA 12 ELF 02 UC IA 12 ELF 02 UC M1 IA 12 ESN 04 UC IA 12 ESN 04 UC M1 IA 12 ELN 04 UC IA 12 ELN 04 UC M1 M18 M18 M18 M18 M18 M18 M18 M18 Short Short Long Long Short Short Long Long Cable Plug Cable Plug Cable Plug Cable Plug 5 mm 1) 5 mm 1) 5 mm 1) 5 mm 1) 8 mm 2) 8 mm 2) 8 mm 2) 8 mm 2) IA 18 ESF 05 UC IA 18 ESF 05 UC M1 IA 18 ELF 05 UC IA 18 ELF 05 UC M1 IA 18 ESN 08 UC IA 18 ESN 08 UC M1 IA 18 ELN 08 UC IA 18 ELN 08 UC M1 M30 M30 M30 M30 M30 M30 M30 M30 Short Short Long Long Short Short Long Long Cable Plug Cable Plug Cable Plug Cable Plug 10 mm 1) 10 mm 1) 10 mm 1) 10 mm 1) 15 mm 2) 15 mm 2) 15 mm 2) 15 mm 2) IA 30 ESF 10 UC IA 30 ESF 10 UC M1 IA 30 ELF 10 UC IA 30 ELF 10 UC M1 IA 30 ESN 15 UC IA 30 ESN 15 UC M1 IA 30 ELN 15 UC IA 30 ELN 15 UC M1 1) 2) For flush mounting in metal For non-flush mounting in metal Specifications are subject to change without notice (19.05.05) 1 IA 12, IA 18, IA 30, NAMUR Specifications Rated operational volt. (Ue) (UB) Self-inductance Self-capacitance No-load supply current (Io) Protection Transient voltage EMC Power ON delay Frequency of operating cycles (f) Indication not activated Assured operating dist. (Sa) Repeat accuracy (R) Hysteresis (H) (Differential travel) Effective operating dist. (Sr) Usable operating dist. (S) Ambient temperature Operating Storage Degree of protection Housing material Body Front Back Connection Cable 8.2 VDC 7 to 9 VDC (6 to 35 VDC, all specifications not observed in extended supply range) ≤ 500µH ≤ 120 nF Activated: ≤1 mA Not activated: ≥ 2.2 mA Max. 9.35 mA Reverse polarity ≤ 1 kV/0.5 J Approved according to EN 50 080, EN 50 081 < 10 ms Plug Cables for plug (-1) Weight (cable excluded) IA12xxF02 1.400 Hz IA12xxN04 1.200 Hz IA18xxF05 500 Hz IA18xxN08 200 Hz IA30xxF10 300 Hz IA30xxF15 100 Hz LED, yellow 0 ≤ Sa ≤ 0.81 Sn ≤ 5% Tightening torque Approvals CE-marking 1 to 15% of sensing distance 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IP 67 (Nema 1, 3, 4, 6, 13) Stainless Steel (1.4301) Grey thermoplastic polyester Black thermoplastic polyester 2 m, 2 x 0.5 mm2, grey PVC, oil proof M12 x 1 CONH1A series IA 12xx 20 g IA 18xxF05 26 g IA 18xxN08 30 g IA 30xxF10 75 g IA 30xxN15 80 g IA 12 7.5 Nm IA 18 27.5 Nm IA 30 100 Nm UL Yes Dimensions Type A B C Ø mm mm D mm E mm F SW mm mm IA 12 ESF 02 UC IA 12 ELF 02 UC IA 12 ESF 02 UC M1 IA 12 ELF 02 UC M1 IA 12 ESN 04 UC IA 12 ELN 04 UC IA 12 ESN 04 UC M1 IA 12 ELN 04 UC M1 M12 x 1 x 30 M12 x 1 x 50 M12 x 1 x 30 M12 x 1 x 50 M12 x 1 x 30 M12 x 1 x 50 M12 x 1 x 30 M12 x 1 x 50 10.7 10.7 10.7 10.7 10.7 10.7 10.7 10.7 30 50 30 50 34 54 34 54 11 11 12.6 12.6 11 11 12.6 12.6 5.0 5.0 11.9 11.9 5.0 5.0 11.9 11.9 4 4 4 4 4 4 4 4 17 17 17 17 17 17 17 17 IA 18 ESF 05 UC IA 18 ELF 05 UC IA 18 ESF 05 UC M1 IA 18 ELF 05 UC M1 IA 18 ESN 08 UC IA 18 ELN 08 UC IA 18 ESN 08 UC M1 IA 18 ELN 08 UC M1 M18 x 1 x 30 M18 x 1 x 50 M18 x 1 x 30 M18 x 1 x 50 M18 x 1 x 30 M18 x 1 x 50 M18 x 1 x 30 M18 x 1 x 50 16.7 16.7 16.7 16.7 16.7 16.7 16.7 16.7 30 50 30 50 38 58 38 58 11.6 11.6 13.1 13.1 11.6 11.6 13.1 13.1 15.4 15.4 11.9 11.9 15.4 15.4 11.9 11.9 4 4 4 4 4 4 4 4 24 24 24 24 24 24 24 24 IA 30 ESF 10 UC IA 30 ELF 10 UC IA 30 ESF 10 UC M1 IA 30 ELF 10 UC M1 IA 30 ESN 15 UC IA 30 ELN 15 UC IA 30 ESN 15 UC M1 IA 30 ELN 15 UC M1 M30 x 1.5 x 30 M30 x 1.5 x 50 M30 x 1.5 x 30 M30 x 1.5 x 50 M30 x 1.5 x 30 M30 x 1.5 x 50 M30 x 1.5 x 30 M30 x 1.5 x 50 28 28 28 28 28 28 28 28 30 50 30 50 42 62 42 62 13.6 13.6 13.6 13.6 13.6 13.6 13.6 13.6 15.4 15.4 11.9 11.9 15.4 15.4 11.9 11.9 5 5 5 5 5 5 5 5 36 36 36 36 36 36 36 36 2 Specifications are subject to change without notice (19.05.05) IA 12, IA 18, IA 30, NAMUR Dimensions (cont.) C E C D E B B D F Cable type M12 x 1 F SW A LED Plug type SW A LED Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Wiring Diagram Power Supplies > SD 110/210 > SD 170/270 BN Refer to Technical information. + R 1K 8.2 V BU - Specifications are subject to change without notice (19.05.05) 3
IA12ELN04UC 价格&库存
很抱歉,暂时无法提供与“IA12ELN04UC”相匹配的价格&库存,您可以联系我们找货
