BES00J7
BES00J7
    BALLUFF(巴鲁夫)
    Module
    DIMENSION= 4 X 27 MM, STYLE=D4.0
BES00J7 数据手册
Inductive Sensors BES 516-3007-G-E4-C-PU-05 Order Code: BES00J7 1) Sensing surface Basic features Electrical data Approval/Conformity cULus Load capacitance max. at Ue 1 µF CE Min. operating current Im 0 mA EAC No-load current Io max., damped 6 mA No-load current Io max., undamped 2 mA Operating voltage Ub 10...30 VDC Output resistance Ra Open drain Display/Operation Rated insulation voltage Ui 75 V DC Function indicator yes Rated operating current Ie 100 mA no Rated operating voltage Ue DC 24 V Rated short circuit current 100 A Ready delay tv max. 21 ms Residual current Ir max. 10 µA WEEE Basic standard IEC 60947-5-2 Power indicator Electrical connection Cable diameter D 3.00 mm Ripple max. (% of Ue) 10 % Cable length L 5m Switching frequency 5000 Hz Conductor cross-section 0.14 mm² Utilization category DC -13 Connection type Cable, 5.00 m, PUR Voltage drop static max. 2V Number of conductors 3 Polarity reversal protected yes Protection against device mix-ups yes Short-circuit protection yes Environmental conditions Ambient temperature -25...70 °C Contamination scale 3 EN 60068-2-27, Shock Half-sinus, 30 gn, 11 ms EN 60068-2-6, Vibration 55 Hz, amplitude 1 mm, 3x30 min IP rating IP67 Functional safety MTTF (40 °C) Internet www.balluff.com 305 a eCl@ss 9.1: 27-27-01-01 Subject to change without notice: 235887 ETIM 6.0: EC002714 BES00J7_0.8_2021-09-09 1/2 Inductive Sensors BES 516-3007-G-E4-C-PU-05 Order Code: BES00J7 Interface Range/Distance Switching output PNP normally open (NO) Material Housing material Stainless steel Material jacket PUR Material sensing surface PBT Assured operating distance Sa 1.21 mm Hysteresis H max. (% of Sr) 15.0 % Rated operating distance Sn 1.5 mm Real switching distance sr 1.5 mm Repeat accuracy max. (% of Sr) 5.0 % Switching distance marking ■■ Temperature drift max. (% of Sr) 10 % Tolerance Sr ±10 % Mechanical data Dimension Ø 4 x 27 mm Installation for flush mounting Size D4.0 Remarks The sensor is functional again after the overload has been eliminated. For more information about MTTF and B10d see MTTF / B10d Certificate Indication of the MTTF- / B10d value does not represent a binding composition and/or life expectancy assurance; these are simply experiential values with no warranty implications. These declared values also do not extend the expiration period for defect claims or affect it in any way. Wiring Diagrams Internet www.balluff.com eCl@ss 9.1: 27-27-01-01 Subject to change without notice: 235887 ETIM 6.0: EC002714 BES00J7_0.8_2021-09-09 2/2
BES00J7 价格&库存
很抱歉,暂时无法提供与“BES00J7”相匹配的价格&库存,您可以联系我们找货
