BES00JR
BES00JR
    BALLUFF(巴鲁夫)
    Module
    DIMENSION= 4 X 27 MM, STYLE=D4.0
BES00JR 数据手册
Inductive Sensors BES 516-3008-E4-C-PU-05 Order Code: BES00JR 1) Sensing surface Basic features Electrical data Approval/Conformity cULus Load capacitance max. at Ue 1 µF CE Min. operating current Im 0 mA EAC No-load current Io max., damped 6 mA No-load current Io max., undamped 2 mA Operating voltage Ub 10...30 VDC Output resistance Ra Open drain Display/Operation Rated insulation voltage Ui 75 V DC Function indicator yes Rated operating current Ie 100 mA no Rated operating voltage Ue DC 24 V Rated short circuit current 100 A Ready delay tv max. 21 ms Residual current Ir max. 10 µA WEEE Basic standard IEC 60947-5-2 Power indicator Electrical connection Cable diameter D 3.00 mm Ripple max. (% of Ue) 10 % Cable length L 5m Switching frequency 5000 Hz Conductor cross-section 0.14 mm² Utilization category DC -13 Connection type Cable, 5.00 m, PUR Voltage drop static max. 2V Number of conductors 3 Polarity reversal protected yes Protection against device mix-ups yes Short-circuit protection yes Environmental conditions Ambient temperature -25...70 °C Contamination scale 3 EN 60068-2-27, Shock Half-sinus, 30 gn, 11 ms EN 60068-2-6, Vibration 55 Hz, amplitude 1 mm, 3x30 min IP rating IP67 Interface Switching output Internet www.balluff.com NPN normally open (NO) eCl@ss 9.1: 27-27-01-01 Subject to change without notice: 235767 ETIM 6.0: EC002714 BES00JR_0.76_2021-07-13 1/2 Inductive Sensors BES 516-3008-E4-C-PU-05 Order Code: BES00JR Material Range/Distance Housing material Stainless steel Assured operating distance Sa 0.65 mm Material jacket PUR Hysteresis H max. (% of Sr) 15.0 % Material sensing surface PBT Rated operating distance Sn 0.8 mm Real switching distance sr 0.8 mm Repeat accuracy max. (% of Sr) 5.0 % Switching distance marking ■ Temperature drift max. (% of Sr) 10 % Tolerance Sr ±10 % Mechanical data Dimension Ø 4 x 27 mm Installation for flush mounting Size D4.0 Remarks The sensor is functional again after the overload has been eliminated. EMC: Surge resistance External protection circuit is required. Document 825345, Section 2. Wiring Diagrams Internet www.balluff.com eCl@ss 9.1: 27-27-01-01 Subject to change without notice: 235767 ETIM 6.0: EC002714 BES00JR_0.76_2021-07-13 2/2
BES00JR 价格&库存
很抱歉,暂时无法提供与“BES00JR”相匹配的价格&库存,您可以联系我们找货
