NCB50-FP-E2-C-P3-V1
NCB50-FP-E2-C-P3-V1
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 50MM PNP
NCB50-FP-E2-C-P3-V1 数据手册
Inductive sensor NCB50-FP-E2-C-P3-V1 < < < < 50 mm flush 3-wire DC Weld Immune Optimum use at a distance >50 cm Dimensions 40 15 ø 9.5 22 7 M12 x 1 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 187584_eng.pdf 80 65 84 10 ø 5.3 65 LEDs Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation flush Output polarity Assured operating distance 50 mm DC sa 0 ... 40.5 mm Reduction factor rAl 0.38 Reduction factor rCu 0.35 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NCB50-FP-E2-C-P3-V1 Technical Data Reduction factor r304 0.83 Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 1 Hz Hysteresis H typ. 3 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA No-load supply current I0 ≤ 20 mA Time delay before availability tv ≤1s Tuning-out ≥ 50 ms Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 940 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector M12 x 1 , 4-pin Housing material PBT/metal Sensing face PBT, active surface PTFE coated Housing base metal Degree of protection IP68 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 187584_eng.pdf Connection 1 L+ 4 3 L- Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NCB50-FP-E2-C-P3-V1 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Mounting These sensors are especially designed for embeddable mounting in conveyor floors. Due to its precise location in metal base plates the sensor is afforded a high degree of mechanical protection. No clearance is required between the sensor and the base plate, avoiding the need for protective guarding to prevent possible foot injury. The large sensing range ensures positive detection, and thus provides consistent control and monitoring of the conveyor. > 95 m m Warning! Once the metal screening has been removed, the sensor can no longer be embeddable mounted. Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 187584_eng.pdf Accessories V1-G-2M-PUR Female cordset, M12, 4-pin, PUR cable V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NCB50-FP-E2-C-P3-V1 价格&库存
很抱歉,暂时无法提供与“NCB50-FP-E2-C-P3-V1”相匹配的价格&库存,您可以联系我们找货
