CA18CLN12TOM6
CA18CLN12TOM6
    CARLOGAVAZZI
    Cylinder,Threaded-M18
    SENSOR PROX CAPACITIVE 12MM CYL
CA18CLN12TOM6 数据手册
Proximity Sensors Capacitive LD™ E I Thermoplastic Polyester Housing SH PLE I R T Type CA, M18, AC • Featuring TRIPLESHIELD™ sensor protection • Rated operational voltage: 20-250 VAC • Adjustable sensing distance 3-8 mm or 3-12 mm • Output: SCR • Make or break switching function • LED indication • High noise immunity • Flush and non-flush types • Plug and cable versions • DC versions in the same housing Product Description Ordering Key Capacitive proximity switc­h­es with either sensing distance 8 mm flush mounted in metal or sensing distance 12 mm non-flush mounted. 2-wire AC output with ma­ke (NO) or bre- Capacitive proximity switch Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type ak (NC) switch­ ing. Grey M18 polyester housing with 2 m PVC cable or M12 plug. Ideal for use in level and plas­ tic ma­chin­ery applica­tions. CA18CLN12TOM6 Type Selection Housing Rated Mounting diameter operating dist. (Sn) 1) M18 M18 8 mm 12 mm Ordering no. SCR/cable Make switching Flush (built-in) CA18CLF08TO Non-flush CA18CLN12TO Ordering no. SCR/plug Make switching Ordering no. SCR/cable Break switching Ordering no. SCR/plug Break switching CA18CLF08TOM6 CA18CLF08TC CA18CLN12TOM6 CA18CLN12TC CA18CLF08TCM6 CA18CLN12TCM6 1) Object: Grounded steel plate Specifications Rated operating dist. (Sn) CA18CLF08 3 to 8 mm factory set at 8 mm CA18CLN12 3 to 12 mm factory set at 12 mm Sensitivity Adj. 270° turn pot. meter Effective operation dist. (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operation dist. (Su) 0.8 x Sr ≤ Su ≤ 1.2 x Sr Repeat accuracy (R) ≤ 5% Hysteresis (H) 4 to 20% of sensing distance Rated operational volt. (UB) 20 to 250 VAC (ripple incl.) Ripple ≤ 10% Rated operational current (Ie) Continuous ≤ 500 mA Short-time < 2.5 A (max. 20 ms) Min. load current 10 mA Voltage drop (Ud) ≤ 10 VAC (at loads ≥ 20 mA) Protection Transients Power ON delay ≤ 100 ms Freq. of operating cycles (f) 10 Hz Specifications are subject to change without notice (17.08.2018) Indication for output ON Environment Degree of protection Temperature Operating temperature Storage temperature Housing material Body Front Cable end Nuts Connection Cable LED, yellow IP 67 (Nema 1, 3, 4, 6, 13) -25° to +80°C ( -13° to +176°F) -40° to +85°C (-40° to +185°F) Grey, thermoplastic polyester Grey, polyester Polyester Black, reinforced nylon Grey, 2 m, 2 x 0.5 mm2 Oil proof PVC M12 x 1, double keyed CON.6A-series Plug (M6) Cable for plug (M6) Weight Cable version Plug version Approvals CE-marking 110 g 30 g UL, CSA Yes 1 EC, M18, AC Dimensions Wiring Diagrams 1) 1) BU (2) BU (2) BN (3) BN (3) 1 2 3 M12 x 1 CA18CLxxxTC 1) Note: Only CA18CLN CA18CLxxxTO Adjustment Guide The environments in which capacitive sensors are install­ ed can often be un­stable re­ garding temperature, humi­dity­, object distance and industrial (noise) interference. Because of this, Carlo Ga­ vazzi offers as standard features in all TRIP­LESHIELD™ capacitive sensors a user-friendly sensitivity adjustment instead of having a fixed sensing range, extend­ ed sen­ sing range to accommodate mechanically demand­ing are­as, temperature stability to en­sure minimum need for adjusting sensitivity if temperature varies and high immunity to elec­tro­magnetic interference (EMI). CA18CL... Max. Min. Note: Sensors are factory set (default) to maximum rated sensing range. Sensitivity Installation Hints Capacitive sensors have the unique ability to detect al­ most all materials, either in li­ quid or solid form. Capa­ci­tive sensors can detect metallic as well as non-metallic ob­ jects, how­ ever, their traditional use is for non-metallic materials such as: • Plastic Industry Resins, regrinds or moulded products. To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables • Chemical Industry Cleansers, fertilisers, liquid soaps, corrosives and petrochemicals. • Wood Industry Saw dust, paper products, door and window frames. • Ceramic & Glass ­Industry Raw material, clay or finish­ ed products, bottles. Relief of cable strain • Packaging Industry Package inspection for level or contents, dry goods, fruits and vegetables, dairy products. Materials are detected due to their dielectric constant. The bigger the size of an object, the higher the density of material, the better or easier it is to detect the object. Nominal sensing di­ stan­ ce for a capacitive sensor is referenced to a grounded me­ tal plate (ST37). For addi­ tional information regarding di­elec­­tric ratings of materials please re­ fer to Technical Information. Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 2 Specifications are subject to change without notice (17.08.2018) EC, M18, AC Delivery Contents Accessories • Capacitive switch: CA18CL... • Screw driver • 2 nuts • Packaging: Cardboard box • Installation & Adjustment Guide • Plugs CON.6A-..series. Specifications are subject to change without notice (17.08.2018) 3
CA18CLN12TOM6 价格&库存
很抱歉,暂时无法提供与“CA18CLN12TOM6”相匹配的价格&库存,您可以联系我们找货
