NBN12-18GM50-E2
NBN12-18GM50-E2
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M18
    INDUCTIVE SEN 12MM PNP
NBN12-18GM50-E2 数据手册
Inductive sensor NBN12-18GM50-E2 < Basic series < 12 mm non-flush < Increased operating distance Dimensions 47 50 4 10 M18x1 24 Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 087779_eng.pdf LED Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation non-flush Output polarity Assured operating distance 12 mm DC sa 0 ... 9.72 mm Reduction factor rAl 0.5 Reduction factor rCu 0.4 Reduction factor r304 0.7 Output type 3-wire Nominal ratings Operating voltage UB 10 ... 30 V Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBN12-18GM50-E2 Technical Data Switching frequency f 0 ... 200 Hz Hysteresis H typ. 5% Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA No-load supply current I0 ≤ 10 mA Switching state indicator all direction LED, yellow Functional safety related parameters MTTFd 1570 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.34 mm2 Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Cable Cable diameter 4.8 mm ± 0.2 mm Bending radius > 10 x cable diameter Connection BN Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 087779_eng.pdf L+ BK BU L- Accessories BF 18 Mounting flange, 18 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBN12-18GM50-E2 价格&库存
很抱歉,暂时无法提供与“NBN12-18GM50-E2”相匹配的价格&库存,您可以联系我们找货
