Proximity Sensors Inductive
Rectangular Plastic Housings
Types IC, Cable
Plastic housing
Sensing distance: 4 mm
Non-flush mounting
Output: Transistor, NPN/PNP, normally open
Power supply: 10 to 30 VDC
2 m PVC cable
Product Description
Ordering Key
Inductive proximity sensor in
rectangular plast housing.
This series is suitable for the
control of axial and rotational movements. Output con-
Ind. prox. switch
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
figured as PNP or NPN, normally open. Connection with
2 m PVC cable.
IC 17 CNC 04 NO-K
Type Selection
Rated op. dist.
(Sn)
Connection
Housing
dimensions [mm]
Ordering no.
Transistor, NPN
Normally open
Ordering no.
Transistor, PNP
Normally open
4 mm
Cable
17.5 x 17 x 28.5
IC 17 CNC 04 NO-K
IC 17 CNC 04 PO-K
Sensing distance
Effective operating dist. (Sr)
Usable operating dist. (Su)
Ambient temperature
Operating
Storage
Degree of protection
Housing material
CE-marking
Connection
4 mm
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
0.85 x Sr ≤ Su ≤ 1.15 x Sr
Specifications
Rated operational volt. (UB)
Ripple
Rated operational current (Ie)
Continuous
No-load supply current (Io)
Voltage drop (Ud)
Frequency of op. cycles (f)
Indication for output ON
10 to 30 VDC (ripple included)
≤ 10%
≤ 100 mA @ 25°C
≤ 12 mA (ON)
< 1 V (@ Imax
500 Hz
LED, yellow
Specifications are subject to change without notice (18.05.10)
-25° to +70°C (-13° to +158°F)
-30° to +75°C (-22° to +167°F)
IP 67 (Nema 1, 3, 4, 6, 13)
Plastic
Yes
Cable, 2 m, PVC, AWG 26
1
IC, Cable
Wiring Diagrams
Dimensions
LED
1 BN
1 BN
2 x Ø 3,3
17,5
10
4 BK
25,5
28,5
4 BK
3 BU
3 BU
NPN - Normally open
17
PNP - Normally open
Installation Hints
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
2
很抱歉,暂时无法提供与“IC17CNC04NO-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1195.365741+154.56373
