MIAD9FQ
MIAD9FQ
    BANNER(邦纳)
    SEN PHOTO VARIED RANGE NAMUR
MIAD9FQ 数据手册
MINI-BEAM® MIAD9 NAMUR Series Sensor Datasheet No revision without agency approval. To view or download the latest technical information about this product, including specifications, dimensions, accessories, and wiring, go to www.bannerengineering.com. • • • • Designed for use with approved amplifiers and intrinsically safe barriers in explosive environments NAMUR compliant sensors with MINI-BEAM performance and small size Output 1 mA or less in the dark condition and 2 mA or more in the light condition Models with integral cable or quick-disconnect WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Models Model1 Sensing Mode MI9E Opposed (Emitter) MIAD9R Opposed (Receiver) Sensing Beam Sensing Range Infrared, 880 nm 6 m (20 ft) Output Type MIAD9LVAG Polarized Retroreflective Visible red, 650 nm 50 mm to 2 m (2 in to 7 ft) MIAD9LV Retroreflective Visible red, 650 nm 5 m (16.4 ft) MIAD9D Diffuse Infrared, 880 nm 380 mm (15 in) MIAD9W Divergent Diffuse Infrared, 880 nm 75 mm (3 in) Convergent Visible red, 650 nm Fiber Optic (Glass) Infrared, 880 nm MIAD9CV MIAD9CV2 MIAD9F Constant Current ≤ 1.2 mA dark ≥ 2.1 mA light 16 mm (0.6 in) 43 mm (1.7 in) Range varies by sensing mode and fiber optics used Overview MIAD9 Series NAMUR Sensors are small, rugged, self-contained two-wire sensors designed for use with certified intrinsically safe switching amplifiers and barriers (Approved Apparatus) with intrinsically safe circuits. MIAD9 Series NAMUR sensors are designed in accordance with DIN 19234 (IEC/EN 60947-5-6) for operation via two-wire connection to an Approved Apparatus that is controlled by the variable internal resistance of the sensor. These sensors vary the impedance across the sensor output, which passes 1 mA or less in the “dark” condition and 2 mA or more in the “light” condition. A red LED on the rear of the sensor lights whenever the sensor sees the “light” condition. A rugged, clutched, 15-turn slotted brass screw Gain control potentiometer enables precise adjustment of system sensitivity. Models are available with either a 2 m (6.5 ft) or 9 m (30 ft) long attached PVC-covered cable, or a 4-pin Euro-style quick disconnect (QD) connector. Quick disconnect models (with “Q” in the model number suffix) use MQD9-4.. mating cable (either straight or right angle connector; see Quick-Disconnect (QD) Cables on p. 8). Contact Banner Engineering for availability of sensor models with 9 m (30 ft) long attached cable. Figure 1. Features (rear of sensor, quickdisconnect model shown) LED Indicator Gain Adjustment Blue (2) No Connection No Connection Brown (1) 1 Only standard 2 m (6.5 ft) cable models are listed. For 4-pin M12/Euro-style Integral QD models: add suffix “Q” to the model number (for example, MIAD9RQ); accessory mating cable required. Original Document 39616 Rev. M 6 November 2020 39616 MINI-BEAM® MIAD9 NAMUR Series Sensor Installation Instructions Ex/HazLoc Applications WARNING: • Explosive Atmospheres/Hazardous Locations • It is the user's responsibility to ensure that all local, state, and national laws, rules, codes, or regulations relating to the installation and use of this device in any particular application are satisfied. This device must be installed by a Qualified Person2, in accordance with this document and applicable regulations. WARNING: • Explosion Hazard • Do not disconnect equipment unless the power has been switched off or the area is known to be nonhazardous. CAUTION: Electrostatic Discharge (ESD) Special Conditions for Safe Use. Parts of the enclosure are non-conducting and may generate an ignitioncapable level of ESD. Cleaning of the equipment shall be done only with a damp cloth. General Notes and Conditions for Safe Use: • See Specifications and Wiring Diagrams for important information concerning entity parameters, permissible locations, electrical connections and certifications. • In addition to the warning above concerning user responsibility, the installation must comply with the following: ◦ All installations must comply with all manufacturer's instructions. ◦ U.S. Installations: The relevant requirements of the National Electrical Code® (ANSI/NFPA-70 (NEC®) and when appropriate ANSI/ISA-RP12.06.01 Installation of Intrinsically Safe Systems for Hazardous (Classified) Locations. ◦ Canadian Installations: The relevant requirements of the Canadian Electrical Code (CSA C22.1). ◦ ATEX and IECEx Installations: The relevant requirements of EN 60079-14 and applicable National regulations. • Do not attempt any repairs to this device; it contains no field-replaceable parts or components. Tampering and/or replacement with non-factory components may adversely affect the safe use of the system. • Approved Apparatus entity parameters must meet the following requirements: ◦ Voc or Vt ≤ Vmax ◦ Ca ≥ Ci + Ccable ◦ Isc or It ≤ Imax ◦ La ≥ Li + Lcable • Sensor Entity Parameters: ◦ Vmax (Ui) ≤ 15 V dc ◦ Imax (li) ≤ 60 mA ◦ Pi ≤ 225 mW ◦ Ci = 0.3 μF ◦ Li = 0 mH • Cable Entity Parameters (if unknown): ◦ Ccable = 60 pF/ft ◦ Lcable = 0.2 µH/ft • The ambient operating temperature range of the Sensors is –40 °C to +70 °C (–40 °F to +158 °F). • For U.S. installations, Class II and III, Division 2 applies only to model numbers ending in a Q suffix. • For intrinsically safe installations, sensors must be used with certified intrinsically safe switching amplifiers and barriers (Approved Apparatus) with intrinsically safe circuits that limit supply voltage and current in the event of failures. • Associated Apparatus is not required for installation of the devices within a Division 2 hazardous (classified) location when installed per the National Electrical Code. The maximum voltage for Division 2 installation is 15 V dc. In Division 2 installations (without Associated Apparatus), observe Explosion Hazard warning at the beginning of this section. • Associated Apparatus is not required for installation of the devices within a Division 2 hazardous (classified) location when installed in, or through the wall of a suitable enclosure with provision for connection of rigid metal conduit per the Canadian Electrical Code, as acceptable to the local inspection authority having jurisdiction. The maximum rating for Division 2 installation is 15 V dc, 60 mA. In Division 2 installations (without Associated Apparatus), observe Explosion Hazard warning at the beginning of this section. • Maximum non-hazardous area voltage that the Approved Apparatus (intrinsically safe circuit) is connected to must not exceed 250 V. • Intrinsic safety ground, if required for the Associated Apparatus, shall be less than 1 ohm. 2 2 A Qualified Person is a person who, by possession of a recognized degree or certificate of professional training, or who, by extensive knowledge, training and experience, has successfully demonstrated the ability to solve problems relating to the subject matter and work. www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 39616 Rev. M MINI-BEAM® MIAD9 NAMUR Series Sensor • Maximum connector torque: 6 ft-lbs. Wiring Connections MIAD9 Series NUMAR sensors are intrinsically safe ONLY when used with certified intrinsically safe switching amplifiers and barriers (Approved Apparatus) with intrinsically safe circuits. Banner does not manufacture such devices; however, our applications engineers can refer you to suppliers of certified devices that will interface with Banner sensors. The user is responsible for proper installation and maintenance of this equipment, and must conform with the certification requirements relating to barriers and to maximum allowable capacitance and inductance of the field wiring. If in doubt about these requirements, our applications engineers can refer you to the appropriate authority. NAMUR Sensors with Attached Cable Hazardous Area NAMUR Sensor NAMUR Sensors with Quick-Disconnect Non-hazardous Area Hazardous Area Approved Apparatus br bu Power + Sensor – Input Non-hazardous Area NAMUR Sensor + – ≤ 15 V dc Approved Apparatus 1 br 2 bu 3 + Sensor – Input + Power – ≤ 15 V dc 4 Output Output Specifications Supply Voltage and Current 5 to 15 V DC (provided by the amplifier to which the sensor is connected) Output Constant current output: ≤ 1.2 mA in the “dark” condition and ≥ 2.1 mA in the “light” condition Adjustments 15-turn slotted brass screw GAIN (sensitivity) adjustment potentiometer (clutched at both ends of travel); located on rear panel and protected by a clear gasketed acrylic cover Indicators Red LED Alignment Indicator Device (AID) located on rear panel lights when the sensor sees a “light” condition; pulse rate is proportional to signal strength (the stronger the signal, the faster the pulse rate). Construction Reinforced thermoplastic polyester housing, totally encapsulated, o-ring sealing, acrylic lenses, and stainless steel screws Output Response Time Opposed mode: 2 ms ON/400 μs OFF All other modes: 5 ms ON/OFF (does not include amplifier response) Environmental Rating Banner tested to NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12, and 13 IEC IP67 Operating Conditions –40 °C to +70 °C (–40 °F to +158 °F) Certifications 2809 Connections PVC-jacketed 2-conductor 2 m or 9 m cables, or special 4-pin M12/Eurostyle quick-disconnect (QD) fitting are available; QD cables are ordered separately. Application Note Special Conditions for Safe Use: Parts of the enclosure are nonconducting and may generate an ignition-capable level of ESD. Cleaning of the equipment must be done only with a damp cloth. IEC IECEx FMG 14.0029X ATEX FM12ATEX0094X FM20US0068X CoC 0003046293 (US) FM20CA0032X CoC 0003046293C (CAN) CCC 2020012315326661 Design Standards ATEX (European) EN 60079-0, EN 60079-11 Canada CAN/CSA C22.2: No.0-M91, No.142-M1987, No.157-92, No.213-M1987, No.1010.1, E60079-0 and E60079-11 United States FM Class 3600, 3610, and 3810; ANSI/ISA 61010-1 (82.02.01), 60079-0 and 60079-11 IECEx IEC 60079-0, IEC 60079-11 P/N 39616 Rev. M www.bannerengineering.com - Tel: + 1 888 373 6767 3 MINI-BEAM® MIAD9 NAMUR Series Sensor Approvals MIAD9(a)(b), MI9E(b) a = Sensing mode D, W, F, LV, LVAG, CV, CV2 or R. b = Connection method Q or blank. ATEX (European) II 1 G Ex ia IIC T5 Ga Ta = -40°C to 70°C - 39616; Entity Entity Parameters: U i = 15 V dc, I i = 60 mA, P i = 225 mW, C i = 0.3 μF, Li = 0 mH. Canadian IS / I,II,III / 1 / ABCDEFG / T5 Ta = -40°C to 70°C - 39616; Entity I / 0 / Ex ia / IIC / T5 Ta = -40°C to 70°C - 39616; Entity (Non-incendive) NI / I / 2 / ABCD / T5 Ta = -40°C to 70°C Entity Parameters: V Max = 15 V dc, I Max = 60 mA, P i = 225 mW, C i = 0.3 μF, L i = 0 mH United States IS / I,II,III / 1 / ABCDEFG / T5 Ta = 70°C - 39616; Entity I / 0 / AEx ia / IIC / T5 / Ga Ta = -40°C to 70°C - 39616; Entity (Non-incendive) NI / I / 2 / ABCD / T5 Ta = -40°C to 70°C S / II,III / 2 / FG* / T5 Ta = -40°C to 70°C *Class II and III, Division 2 applies only to model numbers ending in a Q suffix. Entity Parameters: V Max = 15 V dc, I Max = 60 mA, P i = 225 mW, C i = 0.3 μF, L i = 0 mH IECEx Ex ia IIC T5 Ta= -40 °C to +70 °C - 35331; Entity Entity Parameters: U i = 15 V dc, I i = 60 mA, C i = 0.3 μF, Li = 0 mH. 1G Ex ia IIC T5 Ga Ta = -40ºC to +70ºC FM12ATEX0094X IECEx FMG 14.0029X 2809 FM20US0068X FM20CA0032X CL I/II/III Div 1 Groups ABCDEFG T5 CL I Zn 0 AEx ia IIC T5 Ga Banner Engineering Corp. 9714 Tenth Ave. N. Mpls, MN 55441 USA KGS 15-GA4BO-0491X Ex ia IIC T5 Banner Eng. Europe Park Ln., Culliganlann 2F Diegem BE 1831 INSTALL PER DWG 39616 Performance Curves Excess Gain Mode Beam Pattern Diffuse mode performance based on 90% reflectance white test card 1000 Opposed EXCESS GAIN 100 150 mm 6 in 100 mm 4 in 50 mm 2 in 0 10 1 0.01 m (0.033') 0 50 mm 2 in 100 mm 4 in 150 mm 6 in 0 0.10 m (0.33') 1.0 m (3.3') 10 m (33') 1.2 m 4 ft 2.4 m 8 ft 3.6 m 12 ft 4.8 m 16 ft 6m 20 ft DISTANCE DISTANCE 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 39616 Rev. M MINI-BEAM® MIAD9 NAMUR Series Sensor Excess Gain Mode Beam Pattern Diffuse mode performance based on 90% reflectance white test card Polarized Retroreflective EXCESS GAIN 1000 100 With BRT-3 Reflector 75 mm 3.0" 50 mm 2.0" 25 mm 1.0" 0 0 25 mm 10 1.0" 50 mm 75 mm 1 0.01 m (0.033') 0 0.10 m (0.33') 1.0 m (3.3') 2.0" With BRT-3 Reflector 1m (3') 10 m (33') 2m (6') 3m (9') 4m (12') 3.0" 5m (15') DISTANCE DISTANCE Retroreflective EXCESS GAIN 1000 100 With BRT-3 Reflector 75 mm 3.0" 50 mm 2.0" 25 mm 1.0" 0 0 25 mm 10 1.0" 50 mm 0 1 0.01 m (0.033') 0.10 m (0.33') 1.0 m (3.3') 2.0" With BRT-3 Reflector 75 mm 1m (3') 2m (6') 3m (9') 4m (12') 3.0" 5m (15') DISTANCE 10 m (33') DISTANCE Diffuse EXCESS GAIN 1000 100 15 mm 0.6" 10 mm 0.4" 5 mm 0.2" 0 10 1 1 mm (0.04") 0 5 mm 0.2" 10mm 0.4" 15 mm 0.6" 0 10 mm (0.4") 100 mm (4") 1000 mm (40") 75 mm (3") 150 mm (6") 225 mm (9") 300 mm 375 mm (12") (15") DISTANCE DISTANCE P/N 39616 Rev. M www.bannerengineering.com - Tel: + 1 888 373 6767 5 MINI-BEAM® MIAD9 NAMUR Series Sensor Excess Gain Mode Beam Pattern Diffuse mode performance based on 90% reflectance white test card 1000 Divergent Diffuse EXCESS GAIN 100 15 mm 0.6" 10 mm 0.4" 5 mm 0.2" 0 10 1 0.01 mm (0.004") 0 5 mm 0.2" 10mm 0.4" 15 mm 0.6" 0 1 mm (0.04") 10 mm (0.4") 25 mm (1") 100 mm (4") 50 mm (2") 75 mm (3") 100 mm 125 mm (4") (5") DISTANCE DISTANCE 1000 EXCESS GAIN Convergent 16 mm (0.6 in) 100 3 mm 1.2 in 2 mm .08 in 1 mm .04 in 0 10 1 0.1 mm (0.004") 0 1 mm .04 in 2 mm .08 in 3 mm 1.2 in 0 1 mm (0.04") 10 mm (0.4") 100 mm (4") 25 mm 1 in 50 mm 2 in 75 mm 3 in 100 mm 125 mm 4 in 5 in DISTANCE DISTANCE Convergent 43 mm (1.7 in) EXCESS GAIN 1000 100 3 mm 1.2" 2 mm 0.08" 1 mm 0.04" 0 10 0 1 mm 0.04" 2 mm 0.08" 3 mm 1.2" 0 1 1 mm (0.04") 10 mm (0.4") 100 mm (4") 1000 mm (40") 25 mm (1") 50 mm (2") 75 mm (3") 100 mm 125 mm (4") (5") DISTANCE DISTANCE 6 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 39616 Rev. M MINI-BEAM® MIAD9 NAMUR Series Sensor Excess Gain Mode Beam Pattern Diffuse mode performance based on 90% reflectance white test card Glass Fiber Optic, Opposed EXCESS GAIN 1000 100 75 mm 3" 50 mm 2" 25 mm 10 1" 0 IT23S Fiber IT13S Fiber IT13S 10 mm (0.40") 100 mm (4.0") 0 25 mm 1" 50 mm 2" 75 mm 3" 0 1 1 mm (0.04") IT23S 100 mm (4") 1000 mm (40") 200 mm (8") 300 mm (12") 400 mm 500 mm (16") (20") DISTANCE DISTANCE 1000 Glass Fiber Optic, Diffuse EXCESS GAIN 100 1.8 mm .075" 1.2 mm .050" .06 mm .025" 0 BT23S Fiber 10 10 mm (0.40") 0 .025" 1.2 mm .050" 1.8 mm .075" 0 1 mm (0.04") BT23S .06 mm BT13S Fiber 1 0.1 mm (0.004") BT13S 100 mm (4") 7.5 mm (0.3") 15 mm (0.6") 22.5 mm (0.9") 30 mm (1.2") 37.5 mm (1.5") DISTANCE DISTANCE Dimensions Figure 2. Opposed, Retro, Diffuse, Convergent Models 3.2 mm (0.13") 12.2 mm (0.48") 30.7 mm (1.21") ø 3 mm Clearance (2) 24.1 mm (0.95") M18 x 1 x 15 mm Thread (Mounting Nut Supplied) 2 m (6.5') Cable Mounting Peg (ø 6.3 mm x 2.5 mm) 19.1 mm (0.75") 66.0 mm (2.60") P/N 39616 Rev. M 27.4 mm (1.08") www.bannerengineering.com - Tel: + 1 888 373 6767 7 MINI-BEAM® MIAD9 NAMUR Series Sensor Figure 4. Glass Fiber Models Figure 3. Diffuse Models M12 x 1 Thread Quick-disconnect Bezel 18.5 mm (0.73") 18.0 mm (0.71") Fiber Optic Fitting 69.9 mm (2.75") 13.2 mm (0.52") 51.8 mm (2.04") 31.2 mm (1.23") Accessories Quick-Disconnect (QD) Cables 4-Pin Threaded M12/Euro-Style Cordsets (for use with NAMUR sensors)—Single Ended Model Length MQD9-406 2 m (6.56 ft) MQD9-415 5 m (16.4 ft) MQD9-430 9 m (29.5 ft) MQD9-406RA 2 m (6.56 ft) MQD9-415RA 5 m (16.4 ft) Style Dimensions Pinout (Female) 44 Typ. Straight M12 x 1 ø 14.5 1 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQD9-430RA 4 2 3 1 = Brown 2 = Blue 9 m (29.5 ft) M12 x 1 ø 14.5 [0.57"] Brackets SMB312S • B Stainless steel 2-axis, sidemount bracket 46 C A SMB46U • Right-angle • U bracket for sensor protection • 14-ga. 316 stainless steel 70 B 54 Hole center spacing: A = 16.0 32 20 Hole size: A = 16.5 × 18.7, B = 34.0 × 13.0 A 65 A = 4.3 × 7.5, B = diam. 3, C = 3 × 15.3 8 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 39616 Rev. M MINI-BEAM® MIAD9 NAMUR Series Sensor SMB312B • • Stainless steel 2-axis, bottom-mount bracket Includes mounting foot 24 SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware 51 23 A B C A = diam. 6.9, B = 4.3 × 10.5, C = 3.1 × 15.2 SMB312PD • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware 30 C A 41 B 46 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 A 46 B 41 C 32 Note: Not for use with plastic fiber optic sensors B 69 A Model Bolt Thread (A) SMB18FA 3/8 - 16 × 2 in SMB18FAM10 M10 - 1.5 × 50 SMB18FAM12 n/a; no bolt included. Mounts directly to 12 mm (½ in) rods SMB18Q • Right-angle flanged bracket • 18 mm sensor mounting hole • 12-ga. stainless steel 54 65 Hole center spacing: A = 16.0 66 Hole size: B=ø 18.1 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17 × 4.6, C = ø 18.5 SMB46L • Right-angle • L bracket • 14-ga. 316 stainless steel SMB18FA.. • Swivel bracket with tilt and pan movement for precision adjustment • Easy sensor mounting to extruded rail T-slots • Metric and inch size bolts available • 18 mm sensor mounting hole Hole size: A = 16.5 × 18.7 46 A 41 B A 27 C 30 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 19.0 SMB46S • Right-angle • S bracket • 14-ga. 316 stainless steel Hole center spacing: A = 16.0 Hole size: A = 16.5 × 18.7, B = 34.0 × 10.0 27 65 54 A 16 SMB18SF • 18 mm swivel bracket with M18 × 1 internal thread • Black thermoplastic polyester • Stainless steel swivel locking hardware included 51 B 42 25 B A Hole center spacing: A = 36.0 Hole size: A = ø 5.3, B = ø 18.0 P/N 39616 Rev. M www.bannerengineering.com - Tel: + 1 888 373 6767 9 MINI-BEAM® MIAD9 NAMUR Series Sensor SMB3018SC • 18 mm swivel side or barrelmount bracket • Black reinforced thermoplastic polyester • Stainless steel swivel locking hardware included 67 B 59 29 C A 137 B 64 A Hole center spacing: A = 50.8 Hole size: A = ø 7.0, B = ø 18.0 SMB30SUS • Side-mount swivel with extended range of motion • Black reinforced thermoplastic polyester • Stainless steel swivel locking hardware included SMB18UR • 2-piece universal swivel bracket • 300 series stainless steel • Stainless steel swivel locking hardware included • Mounting hole for 18 mm sensor 42 Hole center spacing: A = 25.4, B = 46.7 Hole size: B = 6.9 × 32.0, C = ø 18.3 67 B 58 SMBAMS18P • Flat SMBAMS series bracket with 18 mm hole • Articulation slots for 90+° rotation • 12-ga. (2.6 mm) cold-rolled steel C 78 A B 29 A 45 Hole center spacing: A = 50.8, B = 24.1 Hole size: A = ø 7, B = ø 7.6 SMB30SK • Flat-mount swivel bracket with extended range of motion • Black reinforced thermoplastic polyester and 316 stainless steel • Stainless steel swivel locking hardware included Hole center spacing: A = 50.8 Hole size: A = ø 7, B = ø 18 Hole center spacing: A = 26.0, A to B = 13.0 Hole size: A = 26.8 × 7.0, B = ø 6.5, C = ø 19.0 A 68 B 57 78 SMBAMS18RA • Right-angle SMBAMS series bracket with 18 mm hole • Articulation slots for 90+° rotation • 12-ga. (2.6 mm) cold-rolled steel 40 C 48 A B 45 Hole center spacing: A = 26.0, A to B = 13.0 Hole size: A = 26.8 × 7.0, B = ø 6.5, C = ø 19.0 Repairs and Translations Obtain assistance with product repairs by contacting your local Banner Engineering Corp distributor or by calling Banner directly at (763) 544-3164. Access literature translated into your native language on the Banner website at www.bannerengineering.com or contact Banner directly at (763) 544-3164. Para reparaciones de productos, por favor contacte a su distribuidor local de Banner Engineering o llame a Banner directamente al (763) 544-3164. Vea la literatura traducida en su idioma en el sitio web Banner en www.bannerengineering.com o comuníquese con Banner directamente al (763) 544-3164. Pour vous aider lors de la réparation de produits, contactez votre distributeur Banner local our appelez directement Banner au (763) 544-3164. La documentation traduite dans votre langue est disponible sur le site internet de Banner www.bannerengineering.com ou contactez directement Banner au (763) 544-3164. 10 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 39616 Rev. M MINI-BEAM® MIAD9 NAMUR Series Sensor Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
MIAD9FQ 价格&库存
很抱歉,暂时无法提供与“MIAD9FQ”相匹配的价格&库存,您可以联系我们找货
