KT11-50/25/98A/103
KT11-50/25/98A/103
    PEPPERL+FUCHS(倍加福)
    PHOTO DIFFUSED 50MM PNP
KT11-50/25/98A/103 数据手册
Diffuse mode sensor KT11-50/25/98a/103 Dimensions 2.5 Optical axis LED M8 x 1 ø6.5 M5 x 0.5 7 26.5 30 45 Model Number KT11-50/25/98a/103 Diffuse mode sensor Electrical connection Option: with 3-pin, M8 x 1 connector Features 103 1 +UB 4 Q 3 0V • High operating distance up to 50 mm • Very small housing • Complete device, no amplifier needed • Voltage range 10 V ... 30 V DC, output current 100 mA short-circuit protected • Optical parts made of glass, easy cleaning • Degree of protection IP67 = Light on = Dark on Pinout Wire colors in accordance with EN 60947-5-2 4 3 BN BU BK (brown) (blue) (black) Release date: 2016-09-23 13:08 Date of issue: 2016-09-23 118357_eng.xml 1 1 3 4 Refer to “General Notes Relating to Pepperl+Fuchs Product Information”. Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 4411 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Diffuse mode sensor KT11-50/25/98a/103 Technical data Accessories General specifications Detection range Reference target Light source Light type Optical face Ambient light limit 0 ... 50 mm standard white, 100 mm x 100 mm LED modulated infrared light frontal 10000 Lux Indicators/operating means Function indicator switching state, LED yellow Electrical specifications Operating voltage Ripple No-load supply current Time delay before availability UB Other suitable accessories can be found at www.pepperl-fuchs.com 10 ... 30 V DC 10 % ≤ 15 mA ≤ 20 ms I0 tv Output Switching type Signal output Switching voltage Switching current Switching frequency Response time V3-WM-2M-PUR Cable socket, M8, 3-pin, PUR cable light on 1 switch output PNP max. 30 V DC max. 100 mA ≤ 250 Hz ≤ 3 ms f Ambient conditions Ambient temperature 0 ... 55 °C (32 ... 131 °F) Mechanical specifications Degree of protection Connection Material Housing Optical face Mass IP67 connector (M8 x 1), 3-pin Stainless steel 1.4305 / AISI 303 Scratch resistant mineral glass lens 9g Compliance with standards and directives Standard conformity Product standard EN 60947-5-2:2007 IEC 60947-5-2:2007 Curves/Diagrams KT11-50 Detection ranges Object colour black grey white 10 20 30 40 50 60 70 80 Distance X [mm] Release date: 2016-09-23 13:08 Date of issue: 2016-09-23 118357_eng.xml 0 x 2 Refer to “General Notes Relating to Pepperl+Fuchs Product Information”. Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 4411 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Diffuse mode sensor KT11-50/25/98a/103 KT9-50 KT11-50 Characteristic response curve Offset Y [mm] 20 10 0 -10 -20 10 20 30 40 50 Distance X [mm] Release date: 2016-09-23 13:08 Date of issue: 2016-09-23 118357_eng.xml -y y x Refer to “General Notes Relating to Pepperl+Fuchs Product Information”. Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 4411 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
KT11-50/25/98A/103 价格&库存
很抱歉,暂时无法提供与“KT11-50/25/98A/103”相匹配的价格&库存,您可以联系我们找货
